[GRASS-QA] GRASS QA: martinl |dig_externs.h file.c portable.c
port_init.c ...| 39 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Jun 4 17:07:39 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/vect/dig_externs.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/vector/diglib/file.c
Function
dig_fflush(Begins at: 85, Ends at:93)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 9 | | OK | 9 |
Conclusion: | this function is a OK |
metrics are OK
dig_file_free(Begins at: 232, Ends at:239)
LOC: | 8 | | OK | 8 |
metrics are OK
dig_file_init(Begins at: 138, Ends at:147)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 10 | | OK | 10 |
metrics are OK
dig_file_load(Begins at: 154, Ends at:226)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 73 | * | WARNING | 73 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
dig_fread(Begins at: 99, Ends at:119)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 21 | | OK | 21 |
at least 1 values are close to an outlier please consider revising code!
dig_fseek(Begins at: 47, Ends at:65)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 19 | | OK | 19 |
at least 2 values are close to an outlier please consider revising code!
dig_ftell(Begins at: 35, Ends at:41)
LOC: | 7 | | OK | 7 |
metrics are OK
dig_fwrite(Begins at: 125, Ends at:132)
dig_rewind(Begins at: 71, Ends at:79)
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/vector/diglib/portable.c
Function
buf_alloc(Begins at: 47, Ends at:61)
Complexity: | 3 | | OK | 3 |
LOC: | 15 | | OK | 15 |
metrics are OK
dig__byte_order_out(Begins at: 652, Ends at:658)
ParamNBR: | 0 | | OK | 0 |
metrics are OK
dig__fread_port_C(Begins at: 353, Ends at:361)
dig__fread_port_D(Begins at: 75, Ends at:103)
CalledNBR: | 3 | | OK | 3 |
LOC: | 29 | | OK | 29 |
dig__fread_port_F(Begins at: 106, Ends at:134)
dig__fread_port_I(Begins at: 209, Ends at:278)
Complexity: | 16 | ** | BABY-MONSTER | 16 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 70 | * | WARNING | 70 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
dig__fread_port_L(Begins at: 137, Ends at:206)
dig__fread_port_P(Begins at: 365, Ends at:372)
dig__fread_port_S(Begins at: 281, Ends at:350)
Complexity: | 17 | ** | BABY-MONSTER | 17 |
dig__fwrite_port_C(Begins at: 564, Ends at:571)
dig__fwrite_port_D(Begins at: 376, Ends at:400)
LOC: | 25 | | OK | 25 |
dig__fwrite_port_F(Begins at: 402, Ends at:426)
dig__fwrite_port_I(Begins at: 471, Ends at:512)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 42 | * | WARNING | 42 |
dig__fwrite_port_L(Begins at: 428, Ends at:469)
dig__fwrite_port_P(Begins at: 558, Ends at:562)
LOC: | 5 | | OK | 5 |
dig__fwrite_port_S(Begins at: 514, Ends at:555)
dig_init_portable(Begins at: 574, Ends at:643)
ParamNBR: | 2 | | OK | 2 |
dig_set_cur_port(Begins at: 646, Ends at:650)
metrics are OK
Clone analysis:
This file has 10 potentially cloned functions:
dig__fread_port_D dig__fread_port_L dig__fread_port_I dig__fwrite_port_L dig__fwrite_port_S dig__fwrite_port_I dig__fwrite_port_S dig__fwrite_port_L dig__fwrite_port_I
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/portable.c clones of dig__fread_port_D are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/portable.c dig__fread_port_F
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/portable.c clones of dig__fread_port_F are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/portable.c dig__fread_port_D
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/portable.c clones of dig__fread_port_I are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/portable.c dig__fread_port_L
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/portable.c clones of dig__fread_port_L are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/portable.c dig__fread_port_I
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/portable.c clones of dig__fwrite_port_I are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/portable.c dig__fwrite_port_L
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/portable.c dig__fwrite_port_S
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/portable.c clones of dig__fwrite_port_L are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/portable.c dig__fwrite_port_I
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/portable.c clones of dig__fwrite_port_S are:
File :grass/trunk/lib/vector/diglib/port_init.c
Function
find_offset(Begins at: 102, Ends at:112)
LOC: | 11 | | OK | 11 |
find_offsets(Begins at: 114, Ends at:146)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
LOC: | 33 | | OK | 33 |
port_init(Begins at: 148, Ends at:188)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 41 | | OK | 41 |
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/port_init.c clones of find_offset are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/port_test.c find_offset
File :grass/trunk/lib/vector/diglib/spindex.c
Function
_add_item(Begins at: 368, Ends at:372)
metrics are OK
_add_node(Begins at: 405, Ends at:409)
metrics are OK
dig_find_node(Begins at: 420, Ends at:441)
LOC: | 22 | | OK | 22 |
dig_select_areas(Begins at: 481, Ends at:499)
dig_select_isles(Begins at: 510, Ends at:528)
dig_select_lines(Begins at: 452, Ends at:470)
dig_select_nodes(Begins at: 384, Ends at:402)
dig_spidx_add_area(Begins at: 174, Ends at:189)
LOC: | 16 | | OK | 16 |
dig_spidx_add_isle(Begins at: 201, Ends at:216)
dig_spidx_add_line(Begins at: 148, Ends at:163)
dig_spidx_add_node(Begins at: 119, Ends at:137)
ParamNBR: | 5 | * | WARNING | 5 |
dig_spidx_del_area(Begins at: 303, Ends at:330)
LOC: | 28 | | OK | 28 |
metrics are OK
dig_spidx_del_isle(Begins at: 342, Ends at:365)
CalledNBR: | 4 | | OK | 4 |
LOC: | 24 | | OK | 24 |
metrics are OK
dig_spidx_del_line(Begins at: 263, Ends at:291)
metrics are OK
dig_spidx_del_node(Begins at: 228, Ends at:251)
metrics are OK
dig_spidx_free(Begins at: 101, Ends at:107)
metrics are OK
dig_spidx_free_areas(Begins at: 79, Ends at:83)
metrics are OK
dig_spidx_free_isles(Begins at: 90, Ends at:94)
metrics are OK
dig_spidx_free_lines(Begins at: 68, Ends at:72)
metrics are OK
dig_spidx_free_nodes(Begins at: 57, Ends at:61)
metrics are OK
dig_spidx_init(Begins at: 31, Ends at:50)
CalledNBR: | 5 | | OK | 5 |
LOC: | 20 | | OK | 20 |
metrics are OK
Clone analysis:
This file has 20 potentially cloned functions:
dig_select_lines dig_select_isles dig_select_nodes dig_select_lines dig_select_areas dig_select_nodes dig_select_areas dig_select_isles dig_select_lines dig_select_areas dig_select_isles dig_spidx_add_line dig_spidx_add_isle dig_spidx_add_line dig_spidx_add_area dig_spidx_add_area dig_spidx_add_isle dig_spidx_del_node dig_spidx_del_isle
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_select_areas are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_select_nodes
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_select_lines
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_select_isles
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_select_isles are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_select_areas
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_select_lines are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_select_nodes are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_spidx_add_area are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_spidx_add_line
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_spidx_add_isle
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_spidx_add_isle are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_spidx_add_area
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_spidx_add_line are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_spidx_del_isle are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_spidx_del_node
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_spidx_del_node are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_spidx_del_isle
File :grass/trunk/lib/vector/diglib/spindex_rw.c
Function
dig_Rd_spindx_head(Begins at: 79, Ends at:162)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
CalledNBR: | 22 | * | WARNING | 22 |
LOC: | 84 | * | WARNING | 84 |
dig_Wr_spindx_head(Begins at: 23, Ends at:76)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 54 | * | WARNING | 54 |
dig_dump_spidx(Begins at: 383, Ends at:399)
CalledNBR: | 8 | | OK | 8 |
LOC: | 17 | | OK | 17 |
metrics are OK
dig_read_spidx(Begins at: 356, Ends at:380)
CalledNBR: | 13 | * | WARNING | 13 |
dig_write_spidx(Begins at: 330, Ends at:353)
rtree_dump_branch(Begins at: 167, Ends at:183)
rtree_dump_node(Begins at: 186, Ends at:205)
rtree_read_branch(Begins at: 268, Ends at:302)
CalledNBR: | 7 | | OK | 7 |
LOC: | 35 | | OK | 35 |
rtree_read_node(Begins at: 305, Ends at:327)
Complexity: | 5 | | OK | 5 |
LOC: | 23 | | OK | 23 |
rtree_write_branch(Begins at: 210, Ends at:237)
rtree_write_node(Begins at: 240, Ends at:263)
Clone analysis:
File :grass/trunk/lib/vector/Vlib/cindex.c
Function
Vect_cidx_dump(Begins at: 388, Ends at:433)
CalledNBR: | 17 | | OK | 17 |
LOC: | 46 | | OK | 46 |
metrics are OK
Vect_cidx_find_all(Begins at: 342, Ends at:374)
ParamNBR: | 5 | | OK | 5 |
CalledNBR: | 4 | * | WARNING | 4 |
LOC: | 33 | * | WARNING | 33 |
Vect_cidx_find_next(Begins at: 268, Ends at:328)
Complexity: | 8 | | OK | 8 |
ParamNBR: | 7 | * | WARNING | 7 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 61 | | OK | 61 |
Vect_cidx_get_cat_by_index(Begins at: 224, Ends at:239)
Complexity: | 2 | * | WARNING | 2 |
CalledNBR: | 3 | * | WARNING | 3 |
LOC: | 16 | * | WARNING | 16 |
Vect_cidx_get_field_index(Begins at: 75, Ends at:91)
ParamNBR: | 2 | ** | BABY-MONSTER | 2 |
Vect_cidx_get_field_number(Begins at: 56, Ends at:64)
metrics are OK
Vect_cidx_get_num_cats_by_index(Begins at: 121, Ends at:128)
metrics are OK
Vect_cidx_get_num_fields(Begins at: 41, Ends at:46)
LOC: | 6 | | OK | 6 |
metrics are OK
Vect_cidx_get_num_types_by_index(Begins at: 139, Ends at:146)
ParamNBR: | 2 | * | WARNING | 2 |
Vect_cidx_get_num_unique_cats_by_index(Begins at: 102, Ends at:110)
LOC: | 9 | * | WARNING | 9 |
Vect_cidx_get_type_count(Begins at: 184, Ends at:209)
ParamNBR: | 3 | | OK | 3 |
CalledNBR: | 6 | * | WARNING | 6 |
LOC: | 26 | | OK | 26 |
Vect_cidx_get_type_count_by_index(Begins at: 160, Ends at:172)
LOC: | 13 | | OK | 13 |
metrics are OK
Vect_cidx_open(Begins at: 487, Ends at:528)
CalledNBR: | 12 | | OK | 12 |
LOC: | 42 | | OK | 42 |
metrics are OK
Vect_cidx_save(Begins at: 443, Ends at:475)
CalledNBR: | 15 | | OK | 15 |
metrics are OK
check_status(Begins at: 28, Ends at:32)
metrics are OK
cmp_cat(Begins at: 242, Ends at:252)
Clone analysis:
This file has 7 potentially cloned functions:
sort_new cmp_field comp_array cmp_near cmp cmpcat
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/cindex.c clones of cmp_cat are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/select.c cmpcat
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/snap.c sort_new
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/cindex.c cmp_field
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.random.cells/init.c comp_array
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.distance/main.c cmp_near
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.overlay/util.c cmp
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.reclass/main.c cmpcat
File :grass/trunk/lib/vector/Vlib/sindex.c
Function
Vect_build_sidx_from_topo(Begins at: 145, Ends at:236)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 92 | ** | BABY-MONSTER | 92 |
Vect_build_spatial_index(Begins at: 124, Ends at:134)
metrics are OK
Vect_spatial_index_add_item(Begins at: 66, Ends at:79)
LOC: | 14 | | OK | 14 |
Vect_spatial_index_del_item(Begins at: 89, Ends at:110)
metrics are OK
Vect_spatial_index_destroy(Begins at: 50, Ends at:55)
metrics are OK
Vect_spatial_index_init(Begins at: 34, Ends at:39)
metrics are OK
Vect_spatial_index_select(Begins at: 255, Ends at:275)
_add_item(Begins at: 240, Ends at:244)
metrics are OK
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/sindex.c clones of Vect_build_spatial_index are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_driver/d_mkdir.c make_dir
____________________________________________
Threshold grass key metrics values at Thu Jun 04 17:05:09 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
