[GRASS-QA] GRASS QA: ejtizado |cat_val.c colors.c colors.h
conversion.h ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Jun 4 21:52:55 EDT 2009
Hello ejtizado,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass-addons/ps/ps.output/cat_val.c
The system don't find class, method and function
in this file during analysis!
File :grass-addons/ps/ps.output/colors.c
File :grass-addons/ps/ps.output/colors.h
File :grass-addons/ps/ps.output/conversion.h
File :grass-addons/ps/ps.output/draws.h
File :grass-addons/ps/ps.output/eps.c
File :grass-addons/ps/ps.output/fonts.c
File :grass-addons/ps/ps.output/fonts.h
File :grass-addons/ps/ps.output/frames.c
File :grass-addons/ps/ps.output/frames.h
File :grass-addons/ps/ps.output/grids.h
File :grass-addons/ps/ps.output/input.c
File :grass-addons/ps/ps.output/legends.c
File :grass-addons/ps/ps.output/legends.h
File :grass-addons/ps/ps.output/lines.c
File :grass-addons/ps/ps.output/lines.h
File :grass-addons/ps/ps.output/load_raster.c
File :grass-addons/ps/ps.output/local_proto.h
File :grass-addons/ps/ps.output/main.c
File :grass-addons/ps/ps.output/notes.h
File :grass-addons/ps/ps.output/palettes.c
File :grass-addons/ps/ps.output/palettes.h
File :grass-addons/ps/ps.output/papers.c
File :grass-addons/ps/ps.output/papers.h
File :grass-addons/ps/ps.output/proj_geo.c
File :grass-addons/ps/ps.output/ps3_map.c
File :grass-addons/ps/ps.output/ps_info.h
File :grass-addons/ps/ps.output/raster.c
File :grass-addons/ps/ps.output/raster.h
File :grass-addons/ps/ps.output/rlegend.h
File :grass-addons/ps/ps.output/r_draw.c
File :grass-addons/ps/ps.output/r_font.c
File :grass-addons/ps/ps.output/r_frame.c
File :grass-addons/ps/ps.output/r_grid.c
File :grass-addons/ps/ps.output/r_line.c
File :grass-addons/ps/ps.output/r_maparea.c
File :grass-addons/ps/ps.output/r_note.c
File :grass-addons/ps/ps.output/r_palette.c
File :grass-addons/ps/ps.output/r_paper.c
File :grass-addons/ps/ps.output/r_raster.c
File :grass-addons/ps/ps.output/r_rlegend.c
File :grass-addons/ps/ps.output/r_scalebar.c
File :grass-addons/ps/ps.output/r_vareas.c
File :grass-addons/ps/ps.output/r_vlegend.c
File :grass-addons/ps/ps.output/r_vlines.c
File :grass-addons/ps/ps.output/r_vpoints.c
File :grass-addons/ps/ps.output/scalebar.h
File :grass-addons/ps/ps.output/scanners.c
File :grass-addons/ps/ps.output/set_draw.c
File :grass-addons/ps/ps.output/set_geogrid.c
File :grass-addons/ps/ps.output/set_grid.c
File :grass-addons/ps/ps.output/set_mask.c
File :grass-addons/ps/ps.output/set_note.c
File :grass-addons/ps/ps.output/set_outline.c
File :grass-addons/ps/ps.output/set_ps.c
File :grass-addons/ps/ps.output/set_raster.c
File :grass-addons/ps/ps.output/set_rlegend.c
File :grass-addons/ps/ps.output/set_scalebar.c
File :grass-addons/ps/ps.output/set_vector.c
File :grass-addons/ps/ps.output/set_vlegend.c
File :grass-addons/ps/ps.output/start_map.c
File :grass-addons/ps/ps.output/symbol.c
File :grass-addons/ps/ps.output/val_list.c
File :grass-addons/ps/ps.output/vareas.h
File :grass-addons/ps/ps.output/vector.c
File :grass-addons/ps/ps.output/vector.h
File :grass-addons/ps/ps.output/vlegend.h
File :grass-addons/ps/ps.output/vlines.h
File :grass-addons/ps/ps.output/vpoints.h
____________________________________________
Threshold grass key metrics values at Thu Jun 04 21:50:22 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
