[GRASS-QA] GRASS QA: hamish |cat_val.c colors.c colors.h conversion.h ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Jun 4 22:30:02 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass-addons/ps/ps.output/cat_val.c
The system don't find class, method and function
 in this file during analysis!
          File :grass-addons/ps/ps.output/colors.c
          File :grass-addons/ps/ps.output/colors.h
          File :grass-addons/ps/ps.output/conversion.h
          File :grass-addons/ps/ps.output/draws.h
          File :grass-addons/ps/ps.output/eps.c
          File :grass-addons/ps/ps.output/fonts.c
          File :grass-addons/ps/ps.output/fonts.h
          File :grass-addons/ps/ps.output/frames.c
          File :grass-addons/ps/ps.output/frames.h
          File :grass-addons/ps/ps.output/grids.h
          File :grass-addons/ps/ps.output/input.c
          File :grass-addons/ps/ps.output/legends.c
          File :grass-addons/ps/ps.output/legends.h
          File :grass-addons/ps/ps.output/lines.c
          File :grass-addons/ps/ps.output/lines.h
          File :grass-addons/ps/ps.output/load_raster.c
          File :grass-addons/ps/ps.output/local_proto.h
          File :grass-addons/ps/ps.output/main.c
          File :grass-addons/ps/ps.output/notes.h
          File :grass-addons/ps/ps.output/palettes.c
          File :grass-addons/ps/ps.output/palettes.h
          File :grass-addons/ps/ps.output/papers.c
          File :grass-addons/ps/ps.output/papers.h
          File :grass-addons/ps/ps.output/proj_geo.c
          File :grass-addons/ps/ps.output/ps3_map.c
          File :grass-addons/ps/ps.output/ps_info.h
          File :grass-addons/ps/ps.output/raster.c
          File :grass-addons/ps/ps.output/raster.h
          File :grass-addons/ps/ps.output/rlegend.h
          File :grass-addons/ps/ps.output/r_draw.c
          File :grass-addons/ps/ps.output/r_font.c
          File :grass-addons/ps/ps.output/r_frame.c
          File :grass-addons/ps/ps.output/r_grid.c
          File :grass-addons/ps/ps.output/r_line.c
          File :grass-addons/ps/ps.output/r_maparea.c
          File :grass-addons/ps/ps.output/r_note.c
          File :grass-addons/ps/ps.output/r_palette.c
          File :grass-addons/ps/ps.output/r_paper.c
          File :grass-addons/ps/ps.output/r_raster.c
          File :grass-addons/ps/ps.output/r_rlegend.c
          File :grass-addons/ps/ps.output/r_scalebar.c
          File :grass-addons/ps/ps.output/r_vareas.c
          File :grass-addons/ps/ps.output/r_vlegend.c
          File :grass-addons/ps/ps.output/r_vlines.c
          File :grass-addons/ps/ps.output/r_vpoints.c
          File :grass-addons/ps/ps.output/scalebar.h
          File :grass-addons/ps/ps.output/scanners.c
          File :grass-addons/ps/ps.output/set_draw.c
          File :grass-addons/ps/ps.output/set_geogrid.c
          File :grass-addons/ps/ps.output/set_grid.c
          File :grass-addons/ps/ps.output/set_mask.c
          File :grass-addons/ps/ps.output/set_note.c
          File :grass-addons/ps/ps.output/set_outline.c
          File :grass-addons/ps/ps.output/set_ps.c
          File :grass-addons/ps/ps.output/set_raster.c
          File :grass-addons/ps/ps.output/set_rlegend.c
          File :grass-addons/ps/ps.output/set_scalebar.c
          File :grass-addons/ps/ps.output/set_vector.c
          File :grass-addons/ps/ps.output/set_vlegend.c
          File :grass-addons/ps/ps.output/start_map.c
          File :grass-addons/ps/ps.output/symbol.c
          File :grass-addons/ps/ps.output/val_list.c
          File :grass-addons/ps/ps.output/vareas.h
          File :grass-addons/ps/ps.output/vector.c
          File :grass-addons/ps/ps.output/vector.h
          File :grass-addons/ps/ps.output/vlegend.h
          File :grass-addons/ps/ps.output/vlines.h
          File :grass-addons/ps/ps.output/vpoints.h
____________________________________________
Threshold grass key metrics values at Thu Jun 04 22:27:29 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
