[GRASS-QA] GRASS QA: hamish |local_proto.h main.c write_grid.c | no
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Jun 4 22:44:50 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/vector/v.mkgrid/local_proto.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/vector/v.mkgrid/main.c
Function
main(Begins at: 30, Ends at:286)
| New Metrics |Old Metrics|
Complexity: | 23 | *** | MONSTER | 23 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 96 | *** | MONSTER | 96 |
LOC: | 257 | *** | MONSTER | 257 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/vector/v.mkgrid/write_grid.c
Function
write_grid(Begins at: 8, Ends at:109)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 102 | ** | BABY-MONSTER | 102 |
Conclusion: | this function is a BABY-MONSTER |
write_vect(Begins at: 116, Ends at:136)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 21 | | OK | 21 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Jun 04 22:42:16 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
