[GRASS-QA] GRASS QA: neteler |rem_io.c | no clones | 0 monsters |0
	warnings
    soccerlab.info at gmail.com
    Fri Jun  5 01:57:57 EDT 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/lib/raster/rem_io.c
          Function
REM__open_quiet(Begins at: 181, Ends at:186)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       6 |       |           OK |         6 |
Conclusion:   | this function is a            OK           |
metrics are OK
REM_close_driver(Begins at: 319, Ends at:326)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
REM_kill_driver(Begins at: 300, Ends at:308)
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
REM_release_driver(Begins at: 328, Ends at:333)
CalledNBR:    |       2 |       |           OK |         2 |
metrics are OK
REM_stabilize(Begins at: 291, Ends at:298)
metrics are OK
_get(Begins at: 35, Ends at:51)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |      17 |       |           OK |        17 |
metrics are OK
_get_char(Begins at: 122, Ends at:128)
LOC:          |       7 |       |           OK |         7 |
metrics are OK
_get_float(Begins at: 138, Ends at:144)
metrics are OK
_get_int(Begins at: 130, Ends at:136)
metrics are OK
_get_text(Begins at: 146, Ends at:156)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      11 |       |           OK |        11 |
metrics are OK
_get_text_2(Begins at: 158, Ends at:179)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      22 |       |           OK |        22 |
metrics are OK
_hold_signals(Begins at: 256, Ends at:276)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      21 |       |           OK |        21 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
_send_char(Begins at: 77, Ends at:86)
LOC:          |      10 |       |           OK |        10 |
metrics are OK
_send_char_array(Begins at: 88, Ends at:94)
metrics are OK
_send_float(Begins at: 112, Ends at:115)
LOC:          |       4 |       |           OK |         4 |
metrics are OK
_send_float_array(Begins at: 101, Ends at:105)
LOC:          |       5 |       |           OK |         5 |
metrics are OK
_send_ident(Begins at: 63, Ends at:75)
LOC:          |      13 |       |           OK |        13 |
metrics are OK
_send_int(Begins at: 107, Ends at:110)
metrics are OK
_send_int_array(Begins at: 96, Ends at:99)
metrics are OK
_send_text(Begins at: 117, Ends at:120)
metrics are OK
dead(Begins at: 251, Ends at:254)
metrics are OK
flushout(Begins at: 53, Ends at:61)
metrics are OK
sync_driver(Begins at: 188, Ends at:249)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |      62 |     * |      WARNING |        62 |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Fri Jun 05 01:55:21 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
