[GRASS-QA] GRASS QA: hamish |cell_stats.c stats.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Jun 5 05:20:19 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.stats/cell_stats.c
          Function
cell_stats(Begins at: 4, Ends at:67)
              |          New Metrics           |Old Metrics|
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      64 |     * |      WARNING |        64 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/raster/r.stats/stats.c
          Class
Node(Begins at: 19, Ends at:27)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
NewNode(Begins at: 65, Ends at:88)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      24 |       |           OK |        24 |
Conclusion:   | this function is a            OK           |
metrics are OK
allocate_values(Begins at: 56, Ends at:63)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
initialize_cell_stats(Begins at: 33, Ends at:54)
Complexity:   |       2 |       |           OK |         2 |
LOC:          |      22 |       |           OK |        22 |
metrics are OK
node_compare(Begins at: 157, Ends at:169)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
print_cell_stats(Begins at: 195, Ends at:314)
Complexity:   |      26 |   *** |      MONSTER |        26 |
CalledNBR:    |      32 |    ** | BABY-MONSTER |        32 |
LOC:          |     120 |    ** | BABY-MONSTER |       120 |
Conclusion:   | this function is a       MONSTER           |
print_node_count(Begins at: 188, Ends at:193)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
reset_null_vals(Begins at: 90, Ends at:98)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
sort_cell_stats(Begins at: 171, Ends at:186)
LOC:          |      16 |       |           OK |        16 |
metrics are OK
update_cell_stats(Begins at: 100, Ends at:155)
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      56 |     * |      WARNING |        56 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Jun 05 05:17:40 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
