[GRASS-QA] GRASS QA: hamish |r_plt.c r_vareas.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Tue Jun 30 11:15:20 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/ps/ps.map/r_plt.c
Function
add_to_plfile(Begins at: 337, Ends at:355)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 19 | | OK | 19 |
Conclusion: | this function is a OK |
metrics are OK
read_eps(Begins at: 107, Ends at:178)
Complexity: | 12 | * | WARNING | 12 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 72 | * | WARNING | 72 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
read_line(Begins at: 180, Ends at:247)
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 68 | * | WARNING | 68 |
at least 4 values are close to an outlier please consider revising code!
read_point(Begins at: 7, Ends at:105)
Complexity: | 16 | ** | BABY-MONSTER | 16 |
LOC: | 99 | ** | BABY-MONSTER | 99 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
read_rectangle(Begins at: 249, Ends at:335)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 87 | * | WARNING | 87 |
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/ps/ps.map/r_vareas.c
Function
read_vareas(Begins at: 34, Ends at:203)
Complexity: | 27 | *** | MONSTER | 27 |
CalledNBR: | 50 | *** | MONSTER | 50 |
LOC: | 170 | *** | MONSTER | 170 |
Conclusion: | this function is a MONSTER |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Jun 30 11:03:12 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
