[GRASS-QA] GRASS QA: glynn |parser.c | 2 clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Tue Jun 30 11:38:35 EDT 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/gis/parser.c
Class
Item(Begins at: 109, Ends at:114)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
G_define_flag(Begins at: 176, Ends at:213)
| New Metrics |Old Metrics|
Complexity: | 3 | * | WARNING | 3 |
ParamNBR: | 1 | * | WARNING | 1 |
CalledNBR: | 4 | * | WARNING | 4 |
LOC: | 38 | * | WARNING | 38 |
Conclusion: | this function is a WARNING |
at least 4 values are close to an outlier please consider revising code!
G_define_module(Begins at: 649, Ends at:662)
Complexity: | 1 | ** | BABY-MONSTER | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 14 | | OK | 14 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
G_define_option(Begins at: 232, Ends at:283)
Complexity: | 3 | ** | BABY-MONSTER | 3 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 52 | | OK | 52 |
G_define_standard_option(Begins at: 312, Ends at:640)
Complexity: | 38 | * | WARNING | 38 |
CalledNBR: | 43 | | OK | 43 |
LOC: | 329 | | OK | 329 |
at least 1 values are close to an outlier please consider revising code!
G_disable_interactive(Begins at: 155, Ends at:160)
Complexity: | 1 | * | WARNING | 1 |
LOC: | 6 | | OK | 6 |
G_gui(Begins at: 1973, Ends at:1988)
CalledNBR: | 5 | * | WARNING | 5 |
LOC: | 16 | * | WARNING | 16 |
at least 3 values are close to an outlier please consider revising code!
G_gui_tcltk(Begins at: 1918, Ends at:1947)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 12 | | OK | 12 |
LOC: | 30 | | OK | 30 |
Conclusion: | this function is a OK |
metrics are OK
G_gui_wx(Begins at: 1952, Ends at:1964)
CalledNBR: | 6 | | OK | 6 |
LOC: | 13 | | OK | 13 |
G_parser(Begins at: 701, Ends at:955)
Complexity: | 41 | | OK | 41 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 83 | | OK | 83 |
LOC: | 255 | | OK | 255 |
metrics are OK
G_recreate_command(Begins at: 2600, Ends at:2699)
Complexity: | 14 | * | WARNING | 14 |
CalledNBR: | 26 | ** | BABY-MONSTER | 26 |
LOC: | 100 | ** | BABY-MONSTER | 100 |
G_script(Begins at: 1696, Ends at:1808)
Complexity: | 24 | * | WARNING | 24 |
CalledNBR: | 46 | * | WARNING | 46 |
LOC: | 113 | * | WARNING | 113 |
G_tcltk(Begins at: 1993, Ends at:2001)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 9 | | OK | 9 |
metrics are OK
G_usage(Begins at: 1008, Ends at:1179)
Complexity: | 34 | | OK | 34 |
CalledNBR: | 53 | | OK | 53 |
LOC: | 172 | | OK | 172 |
metrics are OK
G_usage_html(Begins at: 1472, Ends at:1691)
Complexity: | 42 | | OK | 42 |
CalledNBR: | 85 | | OK | 85 |
LOC: | 220 | * | WARNING | 220 |
G_usage_xml(Begins at: 1234, Ends at:1467)
Complexity: | 31 | *** | MONSTER | 31 |
CalledNBR: | 87 | *** | MONSTER | 87 |
LOC: | 234 | *** | MONSTER | 234 |
Conclusion: | this function is a MONSTER |
check_an_opt(Begins at: 2201, Ends at:2243)
Complexity: | 10 | | OK | 10 |
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 13 | | OK | 13 |
LOC: | 43 | | OK | 43 |
metrics are OK
check_double(Begins at: 2309, Ends at:2345)
Complexity: | 14 | | OK | 14 |
LOC: | 37 | | OK | 37 |
metrics are OK
check_int(Begins at: 2245, Ends at:2281)
CalledNBR: | 6 | * | WARNING | 6 |
at least 2 values are close to an outlier please consider revising code!
check_multiple_opts(Begins at: 2457, Ends at:2492)
Complexity: | 8 | | OK | 8 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 36 | | OK | 36 |
metrics are OK
check_opts(Begins at: 2165, Ends at:2199)
Complexity: | 7 | *** | MONSTER | 7 |
CalledNBR: | 3 | *** | MONSTER | 3 |
LOC: | 35 | *** | MONSTER | 35 |
check_overwrite(Begins at: 2495, Ends at:2560)
Complexity: | 12 | ** | BABY-MONSTER | 12 |
CalledNBR: | 16 | ** | BABY-MONSTER | 16 |
LOC: | 66 | ** | BABY-MONSTER | 66 |
check_required(Begins at: 2373, Ends at:2395)
Complexity: | 4 | *** | MONSTER | 4 |
CalledNBR: | 2 | *** | MONSTER | 2 |
LOC: | 23 | ** | BABY-MONSTER | 23 |
check_string(Begins at: 2347, Ends at:2371)
Complexity: | 9 | | OK | 9 |
LOC: | 25 | | OK | 25 |
metrics are OK
contains(Begins at: 2083, Ends at:2091)
Complexity: | 3 | *** | MONSTER | 3 |
CalledNBR: | 0 | *** | MONSTER | 0 |
LOC: | 9 | *** | MONSTER | 9 |
generate_tcl(Begins at: 1815, Ends at:1913)
Complexity: | 12 | *** | MONSTER | 12 |
CalledNBR: | 34 | *** | MONSTER | 34 |
LOC: | 99 | *** | MONSTER | 99 |
is_option(Begins at: 2093, Ends at:2106)
LOC: | 14 | *** | MONSTER | 14 |
print_escaped_for_html(Begins at: 1213, Ends at:1227)
Complexity: | 4 | * | WARNING | 4 |
LOC: | 15 | | OK | 15 |
print_escaped_for_xml(Begins at: 1189, Ends at:1206)
Complexity: | 7 | | OK | 7 |
LOC: | 18 | | OK | 18 |
metrics are OK
set_flag(Begins at: 2054, Ends at:2078)
CalledNBR: | 4 | *** | MONSTER | 4 |
LOC: | 25 | ** | BABY-MONSTER | 25 |
set_option(Begins at: 2108, Ends at:2163)
LOC: | 56 | | OK | 56 |
metrics are OK
show(Begins at: 2040, Ends at:2052)
CalledNBR: | 3 | | OK | 3 |
metrics are OK
show_options(Begins at: 2010, Ends at:2038)
CalledNBR: | 11 | | OK | 11 |
LOC: | 29 | | OK | 29 |
split_gisprompt(Begins at: 2562, Ends at:2590)
metrics are OK
split_opts(Begins at: 2397, Ends at:2455)
Complexity: | 10 | * | WARNING | 10 |
LOC: | 59 | * | WARNING | 59 |
uses_new_gisprompt(Begins at: 958, Ends at:983)
LOC: | 26 | | OK | 26 |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
check_double
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c clones of check_double are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c check_int
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c clones of check_int are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c check_double
____________________________________________
Threshold grass key metrics values at Tue Jun 30 11:26:27 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
