[GRASS-QA] GRASS QA: hamish |ps_header.c | no clones | 0 monsters
|0 warnings
soccerlab.info at gmail.com
Tue Jun 30 11:52:31 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/ps/ps.map/ps_header.c
Function
write_PS_header(Begins at: 14, Ends at:33)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 20 | | OK | 20 |
Conclusion: | this function is a OK |
metrics are OK
write_bounding_box(Begins at: 35, Ends at:65)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 31 | | OK | 31 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Jun 30 11:40:23 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
