[GRASS-QA] GRASS QA: ejtizado |landsat_set.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Tue Jun 30 12:00:10 EDT 2009
Hello ejtizado,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass-addons/imagery/i.landsat.toar/landsat_set.c
Function
sensor_ETM(Begins at: 63, Ends at:87)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 25 | | OK | 25 |
Conclusion: | this function is a OK |
metrics are OK
sensor_MSS(Begins at: 12, Ends at:36)
metrics are OK
sensor_TM(Begins at: 38, Ends at:61)
LOC: | 24 | | OK | 24 |
metrics are OK
set_ETM(Begins at: 393, Ends at:443)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 51 | * | WARNING | 51 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
set_MSS1(Begins at: 102, Ends at:126)
CalledNBR: | 2 | | OK | 2 |
metrics are OK
set_MSS2(Begins at: 132, Ends at:165)
Complexity: | 3 | | OK | 3 |
LOC: | 34 | | OK | 34 |
metrics are OK
set_MSS3(Begins at: 173, Ends at:206)
metrics are OK
set_MSS4(Begins at: 212, Ends at:248)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 37 | | OK | 37 |
metrics are OK
set_MSS5(Begins at: 300, Ends at:336)
metrics are OK
set_TM4(Begins at: 250, Ends at:293)
LOC: | 44 | * | WARNING | 44 |
set_TM5(Begins at: 338, Ends at:386)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 49 | * | WARNING | 49 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Jun 30 11:48:02 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
