[GRASS-QA] GRASS QA: mmetz |allocation.c angle.c box.c cindex.c
...| 103 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Tue Jun 30 12:08:17 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/vector/diglib/allocation.c
Function
dig__alloc_space(Begins at: 50, Ends at:88)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 39 | | OK | 39 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
dig__falloc(Begins at: 118, Ends at:131)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 14 | | OK | 14 |
Conclusion: | this function is a OK |
metrics are OK
dig__frealloc(Begins at: 133, Ends at:164)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 32 | | OK | 32 |
dig_alloc_space(Begins at: 33, Ends at:48)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 16 | | OK | 16 |
dig_falloc(Begins at: 91, Ends at:101)
CalledNBR: | 4 | | OK | 4 |
LOC: | 11 | | OK | 11 |
metrics are OK
dig_frealloc(Begins at: 103, Ends at:113)
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/vector/diglib/angle.c
Function
d_atan2(Begins at: 212, Ends at:218)
LOC: | 7 | | OK | 7 |
metrics are OK
dig_calc_begin_angle(Begins at: 31, Ends at:80)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 50 | * | WARNING | 50 |
at least 2 values are close to an outlier please consider revising code!
dig_calc_end_angle(Begins at: 82, Ends at:133)
LOC: | 52 | * | WARNING | 52 |
dig_is_line_degenerate(Begins at: 135, Ends at:173)
metrics are OK
dig_line_degenerate(Begins at: 180, Ends at:210)
ParamNBR: | 1 | | OK | 1 |
LOC: | 31 | | OK | 31 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/diglib/box.c
Function
dig_box_copy(Begins at: 69, Ends at:80)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 12 | | OK | 12 |
metrics are OK
dig_box_extend(Begins at: 86, Ends at:103)
Complexity: | 7 | * | WARNING | 7 |
LOC: | 18 | | OK | 18 |
dig_line_box(Begins at: 24, Ends at:63)
Complexity: | 9 | * | WARNING | 9 |
LOC: | 40 | | OK | 40 |
Clone analysis:
This file has 2 potentially cloned functions:
Vect_box_extend
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/box.c clones of dig_box_copy are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/box.c Vect_box_copy
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/box.c clones of dig_box_extend are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/box.c Vect_box_extend
File :grass/trunk/lib/vector/diglib/cindex.c
Function
cmp_cat(Begins at: 134, Ends at:144)
metrics are OK
cmp_field(Begins at: 147, Ends at:157)
metrics are OK
dig_cidx_add_cat(Begins at: 67, Ends at:131)
Complexity: | 10 | * | WARNING | 10 |
LOC: | 65 | * | WARNING | 65 |
at least 3 values are close to an outlier please consider revising code!
dig_cidx_add_cat_sorted(Begins at: 166, Ends at:252)
Complexity: | 13 | ** | BABY-MONSTER | 13 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 87 | * | WARNING | 87 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
dig_cidx_del_cat(Begins at: 261, Ends at:316)
CalledNBR: | 6 | | OK | 6 |
LOC: | 56 | * | WARNING | 56 |
dig_cidx_free(Begins at: 44, Ends at:58)
LOC: | 15 | | OK | 15 |
metrics are OK
dig_cidx_init(Begins at: 29, Ends at:41)
LOC: | 13 | | OK | 13 |
metrics are OK
dig_cidx_sort(Begins at: 323, Ends at:350)
LOC: | 28 | | OK | 28 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/diglib/frmt.c
Function
dig_read_frmt_ascii(Begins at: 27, Ends at:92)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 66 | * | WARNING | 66 |
dig_write_frmt_ascii(Begins at: 100, Ends at:107)
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 8 | | OK | 8 |
Clone analysis:
File :grass/trunk/lib/vector/diglib/inside.c
Function
dig_in_area_bbox(Begins at: 32, Ends at:49)
dig_x_intersect(Begins at: 21, Ends at:30)
LOC: | 10 | | OK | 10 |
Clone analysis:
File :grass/trunk/lib/vector/diglib/line_dist.c
Function
dig_distance2_point_to_line(Begins at: 45, Ends at:118)
ParamNBR: | 15 | *** | MONSTER | 15 |
LOC: | 74 | * | WARNING | 74 |
Conclusion: | this function is a MONSTER |
dig_set_distance_to_line_tolerance(Begins at: 24, Ends at:31)
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/diglib/list.c
Function
dig_init_list(Begins at: 23, Ends at:30)
metrics are OK
dig_list_add(Begins at: 33, Ends at:51)
LOC: | 19 | | OK | 19 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/diglib/plus_area.c
Function
dig_add_area(Begins at: 161, Ends at:230)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 70 | * | WARNING | 70 |
at least 4 values are close to an outlier please consider revising code!
dig_add_isle(Begins at: 610, Ends at:684)
LOC: | 75 | * | WARNING | 75 |
dig_angle_next_line(Begins at: 461, Ends at:538)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 78 | * | WARNING | 78 |
dig_area_add_isle(Begins at: 241, Ends at:267)
LOC: | 27 | | OK | 27 |
dig_area_del_isle(Begins at: 278, Ends at:309)
dig_area_set_box(Begins at: 429, Ends at:443)
dig_build_area_with_line(Begins at: 48, Ends at:145)
Complexity: | 15 | ** | BABY-MONSTER | 15 |
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 98 | ** | BABY-MONSTER | 98 |
dig_del_area(Begins at: 329, Ends at:418)
CalledNBR: | 15 | * | WARNING | 15 |
LOC: | 90 | * | WARNING | 90 |
dig_del_isle(Begins at: 722, Ends at:762)
CalledNBR: | 9 | | OK | 9 |
LOC: | 41 | | OK | 41 |
dig_isle_set_box(Begins at: 696, Ends at:710)
dig_node_angle_check(Begins at: 554, Ends at:593)
Clone analysis:
This file has 6 potentially cloned functions:
dig_line_set_box dig_line_get_box dig_area_set_box dig_line_set_box dig_line_get_box
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_area.c clones of dig_area_set_box are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_area.c dig_isle_set_box
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_line.c dig_line_set_box
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_line.c dig_line_get_box
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_area.c clones of dig_isle_set_box are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_area.c dig_area_set_box
File :grass/trunk/lib/vector/diglib/plus_node.c
Function
dig_add_node(Begins at: 106, Ends at:138)
LOC: | 33 | | OK | 33 |
dig_node_add_line(Begins at: 41, Ends at:94)
LOC: | 54 | * | WARNING | 54 |
dig_node_line_angle(Begins at: 202, Ends at:221)
LOC: | 20 | | OK | 20 |
dig_which_node(Begins at: 150, Ends at:187)
LOC: | 38 | | OK | 38 |
dist_squared(Begins at: 223, Ends at:230)
Clone analysis:
File :grass/trunk/lib/vector/diglib/poly.c
Function
dig_find_area_poly(Begins at: 93, Ends at:116)
LOC: | 24 | | OK | 24 |
metrics are OK
dig_get_poly_points(Begins at: 34, Ends at:86)
LOC: | 53 | * | WARNING | 53 |
Clone analysis:
File :grass/trunk/lib/vector/diglib/prune.c
Function
dig_prune(Begins at: 74, Ends at:238)
Complexity: | 19 | ** | BABY-MONSTER | 19 |
LOC: | 165 | *** | MONSTER | 165 |
Clone analysis:
File :grass/trunk/lib/vector/diglib/spindex.c
Function
_add_item(Begins at: 368, Ends at:372)
LOC: | 5 | | OK | 5 |
metrics are OK
_add_node(Begins at: 405, Ends at:409)
metrics are OK
dig_find_node(Begins at: 420, Ends at:441)
LOC: | 22 | | OK | 22 |
dig_select_areas(Begins at: 481, Ends at:499)
dig_select_isles(Begins at: 510, Ends at:528)
dig_select_lines(Begins at: 452, Ends at:470)
dig_select_nodes(Begins at: 384, Ends at:402)
dig_spidx_add_area(Begins at: 174, Ends at:189)
dig_spidx_add_isle(Begins at: 201, Ends at:216)
dig_spidx_add_line(Begins at: 148, Ends at:163)
dig_spidx_add_node(Begins at: 119, Ends at:137)
dig_spidx_del_area(Begins at: 303, Ends at:330)
metrics are OK
dig_spidx_del_isle(Begins at: 342, Ends at:365)
metrics are OK
dig_spidx_del_line(Begins at: 263, Ends at:291)
LOC: | 29 | | OK | 29 |
metrics are OK
dig_spidx_del_node(Begins at: 228, Ends at:251)
metrics are OK
dig_spidx_free(Begins at: 101, Ends at:107)
metrics are OK
dig_spidx_free_areas(Begins at: 79, Ends at:83)
metrics are OK
dig_spidx_free_isles(Begins at: 90, Ends at:94)
metrics are OK
dig_spidx_free_lines(Begins at: 68, Ends at:72)
metrics are OK
dig_spidx_free_nodes(Begins at: 57, Ends at:61)
metrics are OK
dig_spidx_init(Begins at: 31, Ends at:50)
metrics are OK
Clone analysis:
This file has 20 potentially cloned functions:
dig_select_lines dig_select_isles dig_select_nodes dig_select_lines dig_select_areas dig_select_nodes dig_select_areas dig_select_isles dig_select_lines dig_select_areas dig_select_isles dig_spidx_add_line dig_spidx_add_isle dig_spidx_add_line dig_spidx_add_area dig_spidx_add_area dig_spidx_add_isle dig_spidx_del_node dig_spidx_del_isle
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_select_areas are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_select_nodes
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_select_lines
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_select_isles
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_select_isles are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_select_areas
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_select_lines are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_select_nodes are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_spidx_add_area are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_spidx_add_line
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_spidx_add_isle
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_spidx_add_isle are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_spidx_add_area
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_spidx_add_line are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_spidx_del_isle are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_spidx_del_node
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_spidx_del_node are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c dig_spidx_del_isle
File :grass/trunk/lib/vector/diglib/struct_alloc.c
Function
dig_alloc_area(Begins at: 189, Ends at:208)
ParamNBR: | 0 | | OK | 0 |
metrics are OK
dig_alloc_areas(Begins at: 149, Ends at:163)
metrics are OK
dig_alloc_cats(Begins at: 272, Ends at:296)
LOC: | 25 | | OK | 25 |
metrics are OK
dig_alloc_isle(Begins at: 211, Ends at:226)
metrics are OK
dig_alloc_isles(Begins at: 171, Ends at:186)
metrics are OK
dig_alloc_line(Begins at: 110, Ends at:119)
metrics are OK
dig_alloc_lines(Begins at: 127, Ends at:141)
metrics are OK
dig_alloc_node(Begins at: 40, Ends at:54)
metrics are OK
dig_alloc_nodes(Begins at: 93, Ends at:107)
metrics are OK
dig_alloc_points(Begins at: 232, Ends at:266)
LOC: | 35 | | OK | 35 |
metrics are OK
dig_area_alloc_isle(Begins at: 325, Ends at:340)
metrics are OK
dig_area_alloc_line(Begins at: 303, Ends at:318)
metrics are OK
dig_isle_alloc_line(Begins at: 348, Ends at:364)
LOC: | 17 | | OK | 17 |
metrics are OK
dig_node_alloc_line(Begins at: 63, Ends at:84)
metrics are OK
dig_out_of_memory(Begins at: 369, Ends at:373)
metrics are OK
Clone analysis:
This file has 16 potentially cloned functions:
dig_alloc_lines dig_area_alloc_line dig_alloc_node dig_isle_alloc_line dig_alloc_nodes dig_alloc_areas dig_area_alloc_line dig_alloc_isle dig_alloc_lines dig_alloc_areas dig_area_alloc_line dig_alloc_nodes dig_alloc_lines dig_alloc_areas dig_alloc_isles
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_areas are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c dig_alloc_nodes
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c dig_alloc_lines
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c dig_area_alloc_line
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_isle are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_isles are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c dig_isle_alloc_line
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_lines are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c dig_alloc_areas
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_node are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c dig_alloc_isle
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_nodes are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_area_alloc_line are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_isle_alloc_line are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c dig_alloc_isles
File :grass/trunk/lib/vector/diglib/type.c
Function
dig_type_from_store(Begins at: 58, Ends at:80)
LOC: | 23 | | OK | 23 |
dig_type_to_store(Begins at: 27, Ends at:49)
Clone analysis:
File :grass/trunk/lib/vector/diglib/update.c
Function
dig_line_add_updated(Begins at: 37, Ends at:58)
metrics are OK
dig_line_reset_updated(Begins at: 26, Ends at:29)
LOC: | 4 | | OK | 4 |
metrics are OK
dig_node_add_updated(Begins at: 76, Ends at:97)
metrics are OK
dig_node_reset_updated(Begins at: 65, Ends at:68)
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/vedit/break.c
Function
Vedit_connect_lines(Begins at: 151, Ends at:194)
Complexity: | 7 | ** | BABY-MONSTER | 7 |
ParamNBR: | 3 | ** | BABY-MONSTER | 3 |
CalledNBR: | 8 | ** | BABY-MONSTER | 8 |
LOC: | 44 | ** | BABY-MONSTER | 44 |
Vedit_split_lines(Begins at: 33, Ends at:132)
Complexity: | 13 | * | WARNING | 13 |
CalledNBR: | 23 | | OK | 23 |
LOC: | 100 | * | WARNING | 100 |
connect_lines(Begins at: 196, Ends at:325)
ParamNBR: | 6 | * | WARNING | 6 |
CalledNBR: | 34 | ** | BABY-MONSTER | 34 |
LOC: | 130 | ** | BABY-MONSTER | 130 |
Clone analysis:
File :grass/trunk/lib/vector/vedit/cats.c
Function
Vedit_modify_cats(Begins at: 32, Ends at:100)
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 69 | * | WARNING | 69 |
Clone analysis:
File :grass/trunk/lib/vector/vedit/zbulk.c
Function
Vedit_bulk_labeling(Begins at: 35, Ends at:138)
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
LOC: | 104 | ** | BABY-MONSTER | 104 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/area.c
Function
Vect_area_perimeter(Begins at: 328, Ends at:331)
metrics are OK
Vect_get_area_area(Begins at: 379, Ends at:413)
metrics are OK
Vect_get_area_boundaries(Begins at: 178, Ends at:201)
Vect_get_area_cat(Begins at: 453, Ends at:474)
Vect_get_area_cats(Begins at: 425, Ends at:441)
Vect_get_area_centroid(Begins at: 153, Ends at:167)
metrics are OK
Vect_get_area_isle(Begins at: 275, Ends at:291)
Vect_get_area_num_isles(Begins at: 246, Ends at:263)
metrics are OK
Vect_get_area_points(Begins at: 36, Ends at:86)
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 51 | * | WARNING | 51 |
Vect_get_isle_area(Begins at: 302, Ends at:318)
metrics are OK
Vect_get_isle_boundaries(Begins at: 212, Ends at:235)
Vect_get_isle_points(Begins at: 97, Ends at:142)
LOC: | 46 | * | WARNING | 46 |
Vect_point_in_area(Begins at: 344, Ends at:369)
LOC: | 26 | | OK | 26 |
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/area.c clones of Vect_get_area_num_isles are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/area.c Vect_get_isle_area
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/area.c clones of Vect_get_isle_area are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/area.c Vect_get_area_num_isles
File :grass/trunk/lib/vector/Vlib/array.c
Function
Vect_new_varray(Begins at: 44, Ends at:62)
metrics are OK
Vect_set_varray_from_cat_list(Begins at: 129, Ends at:200)
Complexity: | 13 | | OK | 13 |
CalledNBR: | 18 | | OK | 18 |
LOC: | 72 | | OK | 72 |
Vect_set_varray_from_cat_string(Begins at: 83, Ends at:108)
ParamNBR: | 6 | | OK | 6 |
CalledNBR: | 8 | | OK | 8 |
metrics are OK
Vect_set_varray_from_db(Begins at: 248, Ends at:368)
Complexity: | 16 | ** | BABY-MONSTER | 16 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 27 | * | WARNING | 27 |
LOC: | 121 | * | WARNING | 121 |
cmp(Begins at: 203, Ends at:213)
ParamNBR: | 2 | ** | BABY-MONSTER | 2 |
in_array(Begins at: 216, Ends at:226)
Complexity: | 2 | ** | BABY-MONSTER | 2 |
CalledNBR: | 2 | ** | BABY-MONSTER | 2 |
LOC: | 11 | ** | BABY-MONSTER | 11 |
Clone analysis:
This file has 12 potentially cloned functions:
cmp cmpcatkey cmp cmp fcmp dcmp dcmp cmp_exist cmp srch srch_cat
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/array.c clones of cmp are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/copy_tab.c cmp
/var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/select.c cmp
/var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/select.c cmpcatkey
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/cats.c cmp
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.coin/make_coin.c cmp
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/xmedian.c fcmp
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/xmedian.c dcmp
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/xmode.c dcmp
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.distance/main.c cmp_exist
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.extract/extract.c cmp
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.to.db/update.c srch
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.what.rast/main.c srch_cat
File :grass/trunk/lib/vector/Vlib/box.c
Function
Vect_box_clip(Begins at: 137, Ends at:194)
Complexity: | 17 | ** | BABY-MONSTER | 17 |
LOC: | 58 | * | WARNING | 58 |
Vect_box_copy(Begins at: 72, Ends at:83)
metrics are OK
Vect_box_extend(Begins at: 93, Ends at:110)
Vect_box_overlap(Begins at: 53, Ends at:62)
metrics are OK
Vect_get_area_box(Begins at: 247, Ends at:274)
Vect_get_isle_box(Begins at: 286, Ends at:313)
Vect_get_line_box(Begins at: 208, Ends at:235)
Vect_get_map_box(Begins at: 323, Ends at:337)
metrics are OK
Vect_point_in_box(Begins at: 33, Ends at:42)
Vect_region_box(Begins at: 348, Ends at:359)
metrics are OK
Clone analysis:
This file has 8 potentially cloned functions:
dig_box_extend Vect_get_line_box Vect_get_isle_box Vect_get_line_box Vect_get_area_box Vect_get_area_box Vect_get_isle_box
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/box.c clones of Vect_box_copy are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/box.c dig_box_copy
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/box.c clones of Vect_box_extend are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/box.c dig_box_extend
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/box.c clones of Vect_get_area_box are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/box.c Vect_get_line_box
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/box.c Vect_get_isle_box
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/box.c clones of Vect_get_isle_box are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/box.c Vect_get_area_box
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/box.c clones of Vect_get_line_box are:
File :grass/trunk/lib/vector/Vlib/break_lines.c
Function
Vect_break_lines(Begins at: 36, Ends at:43)
Vect_break_lines_list(Begins at: 68, Ends at:392)
Complexity: | 56 | *** | MONSTER | 56 |
CalledNBR: | 75 | *** | MONSTER | 75 |
LOC: | 325 | *** | MONSTER | 325 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/break_polygons.c
Function
Vect_break_polygons(Begins at: 62, Ends at:352)
Complexity: | 37 | | OK | 37 |
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 66 | | OK | 66 |
LOC: | 291 | | OK | 291 |
metrics are OK
srch(Begins at: 39, Ends at:42)
Complexity: | 1 | *** | MONSTER | 1 |
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 0 | *** | MONSTER | 0 |
LOC: | 4 | *** | MONSTER | 4 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/bridges.c
Function
Vect_chtype_bridges(Begins at: 67, Ends at:71)
Complexity: | 1 | ** | BABY-MONSTER | 1 |
CalledNBR: | 1 | *** | MONSTER | 1 |
LOC: | 5 | ** | BABY-MONSTER | 5 |
Vect_remove_bridges(Begins at: 45, Ends at:49)
remove_bridges(Begins at: 86, Ends at:212)
Complexity: | 19 | | OK | 19 |
CalledNBR: | 40 | | OK | 40 |
LOC: | 127 | | OK | 127 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/buffer.c
Function
Vect_line_buffer(Begins at: 379, Ends at:481)
Complexity: | 10 | *** | MONSTER | 10 |
CalledNBR: | 26 | * | WARNING | 26 |
LOC: | 103 | ** | BABY-MONSTER | 103 |
Vect_line_parallel(Begins at: 353, Ends at:366)
Complexity: | 1 | * | WARNING | 1 |
ParamNBR: | 5 | ** | BABY-MONSTER | 5 |
clean_parallel(Begins at: 132, Ends at:262)
Complexity: | 21 | * | WARNING | 21 |
LOC: | 131 | * | WARNING | 131 |
find_cross(Begins at: 53, Ends at:91)
Complexity: | 6 | | OK | 6 |
ParamNBR: | 7 | * | WARNING | 7 |
parallel_line(Begins at: 271, Ends at:340)
Complexity: | 9 | | OK | 9 |
ParamNBR: | 4 | ** | BABY-MONSTER | 4 |
CalledNBR: | 20 | | OK | 20 |
LOC: | 70 | | OK | 70 |
point_in_buf(Begins at: 97, Ends at:115)
Complexity: | 3 | * | WARNING | 3 |
CalledNBR: | 1 | ** | BABY-MONSTER | 1 |
LOC: | 19 | ** | BABY-MONSTER | 19 |
vect(Begins at: 29, Ends at:44)
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/buffer.c clones of vect are:
/var/project-manager/grass/grassSVN/grass-addons/vector/v.parallel2/vlib_buffer.c norm_vector
File :grass/trunk/lib/vector/Vlib/buffer2.c
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/vector/Vlib/build.c
Function
Vect_build(Begins at: 73, Ends at:76)
metrics are OK
Vect_build_partial(Begins at: 128, Ends at:248)
Complexity: | 20 | | OK | 20 |
ParamNBR: | 3 | | OK | 3 |
CalledNBR: | 46 | | OK | 46 |
LOC: | 121 | | OK | 121 |
metrics are OK
Vect_get_built(Begins at: 86, Ends at:89)
metrics are OK
Vect_save_spatial_index(Begins at: 408, Ends at:440)
Complexity: | 3 | ** | BABY-MONSTER | 3 |
ParamNBR: | 1 | * | WARNING | 1 |
CalledNBR: | 14 | *** | MONSTER | 14 |
LOC: | 33 | ** | BABY-MONSTER | 33 |
Vect_save_topo(Begins at: 257, Ends at:289)
CalledNBR: | 14 | | OK | 14 |
metrics are OK
Vect_spatial_index_dump(Begins at: 451, Ends at:462)
CalledNBR: | 3 | * | WARNING | 3 |
Vect_topo_dump(Begins at: 300, Ends at:398)
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 99 | | OK | 99 |
format(Begins at: 29, Ends at:33)
metrics are OK
prnmsg(Begins at: 48, Ends at:62)
CalledNBR: | 5 | * | WARNING | 5 |
LOC: | 15 | ** | BABY-MONSTER | 15 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/build_ogr.c
Function
Vect_build_ogr(Begins at: 329, Ends at:398)
CalledNBR: | 27 | *** | MONSTER | 27 |
LOC: | 70 | *** | MONSTER | 70 |
add_geometry(Begins at: 156, Ends at:317)
Complexity: | 20 | * | WARNING | 20 |
CalledNBR: | 62 | ** | BABY-MONSTER | 62 |
LOC: | 162 | * | WARNING | 162 |
add_line(Begins at: 114, Ends at:153)
add_part(Begins at: 74, Ends at:84)
metrics are OK
add_parts_to_offset(Begins at: 93, Ends at:111)
metrics are OK
del_part(Begins at: 87, Ends at:90)
metrics are OK
free_parts(Begins at: 67, Ends at:71)
metrics are OK
init_parts(Begins at: 54, Ends at:58)
metrics are OK
reset_parts(Begins at: 61, Ends at:64)
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/Vlib/cats.c
Function
Vect__new_cats_struct(Begins at: 58, Ends at:72)
metrics are OK
Vect_array_to_cat_list(Begins at: 401, Ends at:430)
LOC: | 30 | | OK | 30 |
metrics are OK
Vect_cat_del(Begins at: 190, Ends at:214)
Vect_cat_get(Begins at: 157, Ends at:179)
metrics are OK
Vect_cat_in_array(Begins at: 462, Ends at:473)
Vect_cat_in_cat_list(Begins at: 441, Ends at:450)
Vect_cat_set(Begins at: 106, Ends at:143)
metrics are OK
Vect_destroy_cat_list(Begins at: 300, Ends at:311)
Vect_destroy_cats_struct(Begins at: 81, Ends at:92)
metrics are OK
Vect_field_cat_del(Begins at: 226, Ends at:249)
metrics are OK
Vect_new_cat_list(Begins at: 274, Ends at:290)
ParamNBR: | 0 | * | WARNING | 0 |
Vect_new_cats_struct(Begins at: 40, Ends at:48)
LOC: | 9 | | OK | 9 |
metrics are OK
Vect_reset_cats(Begins at: 261, Ends at:266)
LOC: | 6 | | OK | 6 |
metrics are OK
Vect_str_to_cat_list(Begins at: 324, Ends at:390)
LOC: | 67 | | OK | 67 |
metrics are OK
cmp(Begins at: 475, Ends at:485)
CalledNBR: | 0 | * | WARNING | 0 |
LOC: | 11 | * | WARNING | 11 |
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/cats.c clones of cmp are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/array.c cmp
File :grass/trunk/lib/vector/Vlib/cindex.c
Function
Vect_cidx_dump(Begins at: 388, Ends at:433)
CalledNBR: | 17 | | OK | 17 |
LOC: | 46 | | OK | 46 |
metrics are OK
Vect_cidx_find_all(Begins at: 342, Ends at:374)
ParamNBR: | 5 | | OK | 5 |
CalledNBR: | 4 | * | WARNING | 4 |
LOC: | 33 | * | WARNING | 33 |
Vect_cidx_find_next(Begins at: 268, Ends at:328)
Complexity: | 8 | | OK | 8 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 61 | | OK | 61 |
Vect_cidx_get_cat_by_index(Begins at: 224, Ends at:239)
Complexity: | 2 | * | WARNING | 2 |
LOC: | 16 | * | WARNING | 16 |
Vect_cidx_get_field_index(Begins at: 75, Ends at:91)
Vect_cidx_get_field_number(Begins at: 56, Ends at:64)
metrics are OK
Vect_cidx_get_num_cats_by_index(Begins at: 121, Ends at:128)
metrics are OK
Vect_cidx_get_num_fields(Begins at: 41, Ends at:46)
metrics are OK
Vect_cidx_get_num_types_by_index(Begins at: 139, Ends at:146)
Vect_cidx_get_num_unique_cats_by_index(Begins at: 102, Ends at:110)
LOC: | 9 | * | WARNING | 9 |
Vect_cidx_get_type_count(Begins at: 184, Ends at:209)
CalledNBR: | 6 | * | WARNING | 6 |
Vect_cidx_get_type_count_by_index(Begins at: 160, Ends at:172)
metrics are OK
Vect_cidx_open(Begins at: 487, Ends at:528)
CalledNBR: | 12 | | OK | 12 |
LOC: | 42 | | OK | 42 |
metrics are OK
Vect_cidx_save(Begins at: 443, Ends at:475)
CalledNBR: | 15 | | OK | 15 |
metrics are OK
check_status(Begins at: 28, Ends at:32)
metrics are OK
cmp_cat(Begins at: 242, Ends at:252)
Clone analysis:
This file has 7 potentially cloned functions:
sort_new cmp_field comp_array cmp_near cmp cmpcat
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/cindex.c clones of cmp_cat are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/snap.c sort_new
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/cindex.c cmp_field
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.random.cells/init.c comp_array
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.distance/main.c cmp_near
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.overlay/util.c cmp
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.reclass/main.c cmpcat
File :grass/trunk/lib/vector/Vlib/clean_nodes.c
Function
Vect_clean_small_angles_at_nodes(Begins at: 39, Ends at:264)
Complexity: | 26 | *** | MONSTER | 26 |
CalledNBR: | 58 | *** | MONSTER | 58 |
LOC: | 226 | *** | MONSTER | 226 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/close.c
Function
Vect_close(Begins at: 64, Ends at:148)
CalledNBR: | 33 | ** | BABY-MONSTER | 33 |
LOC: | 85 | * | WARNING | 85 |
clo_dummy(Begins at: 30, Ends at:33)
metrics are OK
format(Begins at: 36, Ends at:40)
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/Vlib/close_ogr.c
Function
V1_close_ogr(Begins at: 27, Ends at:53)
metrics are OK
V2_close_ogr(Begins at: 61, Ends at:120)
Complexity: | 8 | * | WARNING | 8 |
LOC: | 60 | * | WARNING | 60 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/dangles.c
Function
Vect_chtype_dangles(Begins at: 81, Ends at:86)
LOC: | 6 | *** | MONSTER | 6 |
Vect_remove_dangles(Begins at: 54, Ends at:59)
Vect_select_dangles(Begins at: 106, Ends at:111)
dangles(Begins at: 132, Ends at:288)
Complexity: | 25 | | OK | 25 |
CalledNBR: | 45 | | OK | 45 |
LOC: | 157 | | OK | 157 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/dbcolumns.c
Function
Vect_get_column_names(Begins at: 40, Ends at:88)
CalledNBR: | 23 | ** | BABY-MONSTER | 23 |
LOC: | 49 | * | WARNING | 49 |
Vect_get_column_names_types(Begins at: 161, Ends at:213)
CalledNBR: | 29 | ** | BABY-MONSTER | 29 |
Vect_get_column_types(Begins at: 99, Ends at:149)
CalledNBR: | 25 | ** | BABY-MONSTER | 25 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/dgraph.c
File :grass/trunk/lib/vector/Vlib/error.c
Function
Vect_get_fatal_error(Begins at: 53, Ends at:56)
metrics are OK
Vect_set_fatal_error(Begins at: 38, Ends at:42)
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/Vlib/field.c
Function
Vect_add_dblink(Begins at: 209, Ends at:261)
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
Vect_check_dblink(Begins at: 181, Ends at:193)
metrics are OK
Vect_default_field_info(Begins at: 273, Ends at:347)
CalledNBR: | 27 | ** | BABY-MONSTER | 27 |
Vect_get_dblink(Begins at: 360, Ends at:386)
CalledNBR: | 10 | * | WARNING | 10 |
Vect_get_field(Begins at: 400, Ends at:415)
metrics are OK
Vect_map_add_dblink(Begins at: 81, Ends at:110)
Vect_map_check_dblink(Begins at: 167, Ends at:170)
metrics are OK
Vect_map_del_dblink(Begins at: 121, Ends at:156)
LOC: | 36 | | OK | 36 |
Vect_new_dblinks_struct(Begins at: 41, Ends at:53)
metrics are OK
Vect_read_dblinks(Begins at: 427, Ends at:657)
Complexity: | 20 | ** | BABY-MONSTER | 20 |
CalledNBR: | 78 | *** | MONSTER | 78 |
LOC: | 231 | *** | MONSTER | 231 |
Vect_reset_dblinks(Begins at: 62, Ends at:65)
metrics are OK
Vect_set_db_updated(Begins at: 771, Ends at:778)
metrics are OK
Vect_subst_var(Begins at: 718, Ends at:758)
CalledNBR: | 16 | * | WARNING | 16 |
Vect_write_dblinks(Begins at: 667, Ends at:708)
LOC: | 42 | * | WARNING | 42 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/find.c
Function
Vect_find_area(Begins at: 247, Ends at:282)
Vect_find_island(Begins at: 294, Ends at:352)
LOC: | 59 | * | WARNING | 59 |
Vect_find_line(Begins at: 109, Ends at:127)
Vect_find_line_list(Begins at: 144, Ends at:235)
ParamNBR: | 9 | *** | MONSTER | 9 |
LOC: | 92 | ** | BABY-MONSTER | 92 |
Vect_find_node(Begins at: 37, Ends at:90)
Clone analysis:
File :grass/trunk/lib/vector/Vlib/graph.c
Function
Vect_graph_add_edge(Begins at: 128, Ends at:144)
Vect_graph_build(Begins at: 102, Ends at:111)
metrics are OK
Vect_graph_init(Begins at: 76, Ends at:89)
metrics are OK
Vect_graph_set_node_costs(Begins at: 159, Ends at:169)
Vect_graph_shortest_path(Begins at: 188, Ends at:262)
clipper(Begins at: 31, Ends at:66)
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/graph.c clones of clipper are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/net.c clipper
File :grass/trunk/lib/vector/Vlib/header.c
Function
Vect__read_head(Begins at: 122, Ends at:192)
Complexity: | 18 | ** | BABY-MONSTER | 18 |
CalledNBR: | 62 | *** | MONSTER | 62 |
LOC: | 71 | * | WARNING | 71 |
Vect__write_head(Begins at: 86, Ends at:112)
CalledNBR: | 24 | ** | BABY-MONSTER | 24 |
Vect_get_comment(Begins at: 437, Ends at:440)
metrics are OK
Vect_get_date(Begins at: 303, Ends at:306)
metrics are OK
Vect_get_full_name(Begins at: 225, Ends at:232)
metrics are OK
Vect_get_map_date(Begins at: 384, Ends at:387)
metrics are OK
Vect_get_map_name(Begins at: 357, Ends at:360)
metrics are OK
Vect_get_mapset(Begins at: 213, Ends at:216)
metrics are OK
Vect_get_name(Begins at: 201, Ends at:204)
metrics are OK
Vect_get_organization(Begins at: 270, Ends at:273)
metrics are OK
Vect_get_person(Begins at: 330, Ends at:333)
metrics are OK
Vect_get_proj(Begins at: 479, Ends at:482)
metrics are OK
Vect_get_proj_name(Begins at: 497, Ends at:512)
Vect_get_scale(Begins at: 410, Ends at:413)
metrics are OK
Vect_get_thresh(Begins at: 536, Ends at:540)
metrics are OK
Vect_get_zone(Begins at: 464, Ends at:467)
metrics are OK
Vect_is_3d(Begins at: 242, Ends at:245)
metrics are OK
Vect_print_header(Begins at: 37, Ends at:46)
metrics are OK
Vect_read_header(Begins at: 56, Ends at:60)
metrics are OK
Vect_set_comment(Begins at: 423, Ends at:428)
metrics are OK
Vect_set_date(Begins at: 286, Ends at:291)
metrics are OK
Vect_set_map_date(Begins at: 370, Ends at:375)
metrics are OK
Vect_set_map_name(Begins at: 343, Ends at:348)
metrics are OK
Vect_set_organization(Begins at: 255, Ends at:261)
metrics are OK
Vect_set_person(Begins at: 316, Ends at:321)
metrics are OK
Vect_set_scale(Begins at: 397, Ends at:401)
metrics are OK
Vect_set_thresh(Begins at: 522, Ends at:527)
metrics are OK
Vect_set_zone(Begins at: 450, Ends at:454)
metrics are OK
Vect_write_header(Begins at: 70, Ends at:75)
metrics are OK
lookup(Begins at: 544, Ends at:550)
Clone analysis:
File :grass/trunk/lib/vector/Vlib/hist.c
Function
Vect_hist_command(Begins at: 33, Ends at:52)
CalledNBR: | 14 | * | WARNING | 14 |
Vect_hist_copy(Begins at: 125, Ends at:161)
LOC: | 37 | | OK | 37 |
Vect_hist_read(Begins at: 84, Ends at:99)
Vect_hist_rewind(Begins at: 108, Ends at:114)
metrics are OK
Vect_hist_write(Begins at: 62, Ends at:71)
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/Vlib/init_head.c
Function
Vect__init_head(Begins at: 35, Ends at:63)
Vect_copy_head_data(Begins at: 73, Ends at:87)
Clone analysis:
File :grass/trunk/lib/vector/Vlib/intersect.c
Function
Vect_line_check_intersection(Begins at: 1110, Ends at:1248)
Complexity: | 18 | | OK | 18 |
LOC: | 139 | | OK | 139 |
Vect_line_intersection(Begins at: 600, Ends at:1066)
Complexity: | 44 | | OK | 44 |
ParamNBR: | 7 | | OK | 7 |
CalledNBR: | 48 | | OK | 48 |
LOC: | 467 | | OK | 467 |
metrics are OK
Vect_segment_intersection(Begins at: 109, Ends at:456)
Complexity: | 41 | | OK | 41 |
ParamNBR: | 19 | | OK | 19 |
CalledNBR: | 43 | | OK | 43 |
LOC: | 348 | | OK | 348 |
metrics are OK
add_cross(Begins at: 474, Ends at:498)
cmp_cross(Begins at: 500, Ends at:515)
metrics are OK
cross_seg(Begins at: 545, Ends at:580)
Complexity: | 4 | ** | BABY-MONSTER | 4 |
LOC: | 36 | ** | BABY-MONSTER | 36 |
dist2(Begins at: 517, Ends at:524)
LOC: | 8 | *** | MONSTER | 8 |
find_cross(Begins at: 1073, Ends at:1096)
Complexity: | 2 | *** | MONSTER | 2 |
ParamNBR: | 2 | *** | MONSTER | 2 |
LOC: | 24 | *** | MONSTER | 24 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/legal_vname.c
Function
Vect_check_input_output_name(Begins at: 94, Ends at:157)
LOC: | 64 | * | WARNING | 64 |
Vect_legal_filename(Begins at: 36, Ends at:76)
Clone analysis:
File :grass/trunk/lib/vector/Vlib/level_two.c
Function
Vect_get_centroid_area(Begins at: 312, Ends at:319)
metrics are OK
Vect_get_line_areas(Begins at: 231, Ends at:245)
Vect_get_line_nodes(Begins at: 206, Ends at:220)
Vect_get_node_coor(Begins at: 181, Ends at:195)
Vect_get_node_line(Begins at: 275, Ends at:282)
Vect_get_node_line_angle(Begins at: 293, Ends at:300)
Vect_get_node_n_lines(Begins at: 255, Ends at:264)
metrics are OK
Vect_get_num_areas(Begins at: 81, Ends at:84)
metrics are OK
Vect_get_num_dblinks(Begins at: 117, Ends at:120)
metrics are OK
Vect_get_num_faces(Begins at: 93, Ends at:96)
metrics are OK
Vect_get_num_islands(Begins at: 105, Ends at:108)
metrics are OK
Vect_get_num_lines(Begins at: 69, Ends at:72)
metrics are OK
Vect_get_num_nodes(Begins at: 29, Ends at:32)
metrics are OK
Vect_get_num_primitives(Begins at: 42, Ends at:60)
Vect_get_num_updated_lines(Begins at: 129, Ends at:132)
metrics are OK
Vect_get_num_updated_nodes(Begins at: 154, Ends at:157)
metrics are OK
Vect_get_updated_line(Begins at: 142, Ends at:145)
metrics are OK
Vect_get_updated_node(Begins at: 167, Ends at:170)
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/Vlib/line.c
Function
Vect__new_line_struct(Begins at: 65, Ends at:79)
metrics are OK
Vect_append_point(Begins at: 166, Ends at:179)
Vect_append_points(Begins at: 309, Ends at:340)
Vect_copy_pnts_to_xyz(Begins at: 356, Ends at:371)
Vect_copy_xyz_to_pnts(Begins at: 112, Ends at:132)
LOC: | 21 | | OK | 21 |
Vect_destroy_line_struct(Begins at: 88, Ends at:100)
metrics are OK
Vect_get_line_cat(Begins at: 812, Ends at:827)
Vect_line_box(Begins at: 768, Ends at:772)
metrics are OK
Vect_line_delete_point(Begins at: 225, Ends at:244)
metrics are OK
Vect_line_distance(Begins at: 627, Ends at:728)
ParamNBR: | 11 | *** | MONSTER | 11 |
LOC: | 102 | ** | BABY-MONSTER | 102 |
Vect_line_geodesic_length(Begins at: 580, Ends at:606)
metrics are OK
Vect_line_insert_point(Begins at: 191, Ends at:215)
Vect_line_length(Begins at: 552, Ends at:568)
metrics are OK
Vect_line_prune(Begins at: 253, Ends at:273)
metrics are OK
Vect_line_prune_thresh(Begins at: 283, Ends at:293)
metrics are OK
Vect_line_reverse(Begins at: 781, Ends at:800)
metrics are OK
Vect_line_segment(Begins at: 494, Ends at:541)
LOC: | 48 | * | WARNING | 48 |
Vect_new_line_struct(Begins at: 55, Ends at:63)
metrics are OK
Vect_point_on_line(Begins at: 390, Ends at:475)
LOC: | 86 | * | WARNING | 86 |
Vect_points_distance(Begins at: 742, Ends at:758)
Vect_reset_line(Begins at: 146, Ends at:151)
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/Vlib/list.c
Function
Vect_destroy_list(Begins at: 74, Ends at:85)
metrics are OK
Vect_list_append(Begins at: 96, Ends at:119)
metrics are OK
Vect_list_append_list(Begins at: 130, Ends at:141)
metrics are OK
Vect_list_delete(Begins at: 152, Ends at:170)
metrics are OK
Vect_list_delete_list(Begins at: 181, Ends at:192)
metrics are OK
Vect_new_list(Begins at: 34, Ends at:47)
metrics are OK
Vect_reset_list(Begins at: 59, Ends at:64)
metrics are OK
Vect_val_in_list(Begins at: 203, Ends at:216)
metrics are OK
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/list.c clones of Vect_list_append_list are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/list.c Vect_list_delete_list
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/list.c clones of Vect_list_delete_list are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/list.c Vect_list_append_list
File :grass/trunk/lib/vector/Vlib/map.c
Function
Vect_copy(Begins at: 156, Ends at:285)
Complexity: | 15 | * | WARNING | 15 |
CalledNBR: | 60 | | OK | 60 |
LOC: | 130 | | OK | 130 |
Vect_copy_map_lines(Begins at: 44, Ends at:99)
Complexity: | 10 | ** | BABY-MONSTER | 10 |
CalledNBR: | 20 | *** | MONSTER | 20 |
LOC: | 56 | ** | BABY-MONSTER | 56 |
Vect_copy_table(Begins at: 644, Ends at:650)
CalledNBR: | 1 | * | WARNING | 1 |
LOC: | 7 | * | WARNING | 7 |
Vect_copy_table_by_cats(Begins at: 667, Ends at:720)
CalledNBR: | 13 | | OK | 13 |
LOC: | 54 | | OK | 54 |
Vect_copy_tables(Begins at: 567, Ends at:629)
CalledNBR: | 22 | * | WARNING | 22 |
LOC: | 63 | * | WARNING | 63 |
Vect_delete(Begins at: 430, Ends at:553)
Complexity: | 16 | * | WARNING | 16 |
ParamNBR: | 1 | ** | BABY-MONSTER | 1 |
CalledNBR: | 62 | * | WARNING | 62 |
LOC: | 124 | * | WARNING | 124 |
Vect_rename(Begins at: 302, Ends at:420)
CalledNBR: | 50 | *** | MONSTER | 50 |
LOC: | 119 | ** | BABY-MONSTER | 119 |
Vect_set_category_index_update(Begins at: 746, Ends at:749)
LOC: | 4 | ** | BABY-MONSTER | 4 |
Vect_set_release_support(Begins at: 731, Ends at:734)
metrics are OK
copy_file(Begins at: 110, Ends at:141)
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/Vlib/merge_lines.c
File :grass/trunk/lib/vector/Vlib/net.c
Function
Vect_net_build_graph(Begins at: 90, Ends at:442)
Complexity: | 51 | | OK | 51 |
ParamNBR: | 9 | * | WARNING | 9 |
CalledNBR: | 126 | * | WARNING | 126 |
LOC: | 353 | | OK | 353 |
Vect_net_get_line_cost(Begins at: 551, Ends at:594)
Complexity: | 5 | *** | MONSTER | 5 |
ParamNBR: | 4 | *** | MONSTER | 4 |
CalledNBR: | 4 | *** | MONSTER | 4 |
LOC: | 44 | *** | MONSTER | 44 |
Vect_net_get_node_cost(Begins at: 605, Ends at:614)
LOC: | 10 | * | WARNING | 10 |
Vect_net_nearest_nodes(Begins at: 634, Ends at:832)
Complexity: | 45 | | OK | 45 |
ParamNBR: | 14 | * | WARNING | 14 |
CalledNBR: | 39 | | OK | 39 |
LOC: | 199 | | OK | 199 |
Vect_net_shortest_path(Begins at: 463, Ends at:537)
Complexity: | 13 | *** | MONSTER | 13 |
ParamNBR: | 5 | *** | MONSTER | 5 |
CalledNBR: | 12 | *** | MONSTER | 12 |
LOC: | 75 | *** | MONSTER | 75 |
Vect_net_shortest_path_coor(Begins at: 852, Ends at:1055)
Complexity: | 34 | ** | BABY-MONSTER | 34 |
ParamNBR: | 16 | * | WARNING | 16 |
CalledNBR: | 47 | * | WARNING | 47 |
LOC: | 204 | * | WARNING | 204 |
clipper(Begins at: 30, Ends at:65)
Complexity: | 4 | *** | MONSTER | 4 |
LOC: | 36 | *** | MONSTER | 36 |
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/net.c clones of clipper are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/graph.c clipper
File :grass/trunk/lib/vector/Vlib/open_ogr.c
Function
V1_open_old_ogr(Begins at: 45, Ends at:104)
CalledNBR: | 17 | * | WARNING | 17 |
V2_open_old_ogr(Begins at: 114, Ends at:190)
LOC: | 77 | * | WARNING | 77 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/overlap.c
Function
V__map_overlap(Begins at: 21, Ends at:34)
Clone analysis:
File :grass/trunk/lib/vector/Vlib/overlay.c
Function
Vect_overlay(Begins at: 64, Ends at:78)
ParamNBR: | 10 | *** | MONSTER | 10 |
Vect_overlay_and(Begins at: 101, Ends at:242)
Complexity: | 27 | *** | MONSTER | 27 |
CalledNBR: | 48 | *** | MONSTER | 48 |
LOC: | 142 | *** | MONSTER | 142 |
Vect_overlay_str_to_operator(Begins at: 39, Ends at:48)
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/Vlib/poly.c
Class
Slink(Begins at: 28, Ends at:32)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
V__within(Begins at: 111, Ends at:122)
Vect__divide_and_conquer(Begins at: 266, Ends at:304)
Vect__intersect_line_with_poly(Begins at: 140, Ends at:167)
Vect_find_poly_centroid(Begins at: 329, Ends at:366)
Vect_get_point_in_area(Begins at: 60, Ends at:98)
Vect_get_point_in_poly(Begins at: 180, Ends at:242)
Vect_get_point_in_poly_isl(Begins at: 423, Ends at:547)
LOC: | 125 | ** | BABY-MONSTER | 125 |
Vect_point_in_area_outer_ring(Begins at: 694, Ends at:747)
Vect_point_in_island(Begins at: 760, Ends at:805)
Vect_point_in_poly(Begins at: 665, Ends at:681)
comp_double(Begins at: 100, Ends at:109)
metrics are OK
destroy_links(Begins at: 306, Ends at:317)
metrics are OK
segments_x_ray(Begins at: 554, Ends at:653)
LOC: | 100 | ** | BABY-MONSTER | 100 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/read_ogr.c
Function
V1_read_next_line_ogr(Begins at: 142, Ends at:228)
CalledNBR: | 19 | ** | BABY-MONSTER | 19 |
V2_read_line_ogr(Begins at: 324, Ends at:402)
Complexity: | 12 | ** | BABY-MONSTER | 12 |
LOC: | 79 | * | WARNING | 79 |
V2_read_next_line_ogr(Begins at: 241, Ends at:249)
cache_feature(Begins at: 39, Ends at:124)
Complexity: | 16 | | OK | 16 |
CalledNBR: | 26 | | OK | 26 |
LOC: | 86 | | OK | 86 |
read_line(Begins at: 262, Ends at:310)
Clone analysis:
File :grass/trunk/lib/vector/Vlib/remove_areas.c
Function
Vect_remove_small_areas(Begins at: 39, Ends at:190)
Complexity: | 23 | *** | MONSTER | 23 |
CalledNBR: | 45 | *** | MONSTER | 45 |
LOC: | 152 | *** | MONSTER | 152 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/remove_duplicates.c
Function
Vect_line_check_duplicate(Begins at: 141, Ends at:179)
Vect_remove_duplicates(Begins at: 38, Ends at:130)
CalledNBR: | 30 | ** | BABY-MONSTER | 30 |
LOC: | 93 | ** | BABY-MONSTER | 93 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/rewind_ogr.c
Function
V1_rewind_ogr(Begins at: 27, Ends at:37)
metrics are OK
V2_rewind_ogr(Begins at: 39, Ends at:46)
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/Vlib/select.c
Function
Vect_select_areas_by_box(Begins at: 91, Ends at:115)
Vect_select_areas_by_polygon(Begins at: 293, Ends at:351)
Vect_select_isles_by_box(Begins at: 130, Ends at:147)
Vect_select_lines_by_box(Begins at: 37, Ends at:77)
Vect_select_lines_by_polygon(Begins at: 197, Ends at:274)
Vect_select_nodes_by_box(Begins at: 158, Ends at:181)
Clone analysis:
File :grass/trunk/lib/vector/Vlib/sindex.c
Function
Vect_build_sidx_from_topo(Begins at: 145, Ends at:236)
Vect_build_spatial_index(Begins at: 124, Ends at:134)
metrics are OK
Vect_spatial_index_add_item(Begins at: 66, Ends at:79)
Vect_spatial_index_del_item(Begins at: 89, Ends at:110)
metrics are OK
Vect_spatial_index_destroy(Begins at: 50, Ends at:55)
metrics are OK
Vect_spatial_index_init(Begins at: 34, Ends at:39)
metrics are OK
Vect_spatial_index_select(Begins at: 255, Ends at:275)
_add_item(Begins at: 240, Ends at:244)
metrics are OK
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/sindex.c clones of Vect_build_spatial_index are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_driver/d_mkdir.c make_dir
File :grass/trunk/lib/vector/Vlib/snap.c
Function
Vect_snap_lines(Begins at: 460, Ends at:491)
metrics are OK
Vect_snap_lines_list(Begins at: 80, Ends at:432)
CalledNBR: | 79 | | OK | 79 |
metrics are OK
add_item(Begins at: 44, Ends at:48)
sort_new(Begins at: 435, Ends at:445)
Complexity: | 3 | *** | MONSTER | 3 |
LOC: | 11 | *** | MONSTER | 11 |
Clone analysis:
This file has 10 potentially cloned functions:
cmpcatkey cmp_cat cmp_field comp_array cmp_near cmp_along cmp cmp cmpcat
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/snap.c clones of sort_new are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/cindex.c cmp_cat
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.lrs/v.lrs.label/main.c cmp_along
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.net.path/path.c cmp
File :grass/trunk/lib/vector/Vlib/type.c
Function
Vect_option_to_types(Begins at: 31, Ends at:67)
Clone analysis:
File :grass/trunk/lib/vector/Vlib/write_nat.c
Function
V1__rewrite_line_nat(Begins at: 444, Ends at:531)
Complexity: | 21 | | OK | 21 |
LOC: | 88 | | OK | 88 |
metrics are OK
V1_delete_line_nat(Begins at: 542, Ends at:571)
metrics are OK
V1_rewrite_line_nat(Begins at: 354, Ends at:399)
Complexity: | 5 | * | WARNING | 5 |
V1_write_line_nat(Begins at: 97, Ends at:111)
LOC: | 15 | * | WARNING | 15 |
V2_delete_line_nat(Begins at: 582, Ends at:770)
Complexity: | 35 | | OK | 35 |
LOC: | 189 | | OK | 189 |
V2_rewrite_line_nat(Begins at: 415, Ends at:430)
CalledNBR: | 2 | * | WARNING | 2 |
V2_write_line_nat(Begins at: 124, Ends at:332)
Complexity: | 37 | *** | MONSTER | 37 |
CalledNBR: | 41 | *** | MONSTER | 41 |
LOC: | 209 | *** | MONSTER | 209 |
add_area_cats_to_cidx(Begins at: 56, Ends at:81)
delete_area_cats_from_cidx(Begins at: 29, Ends at:54)
CalledNBR: | 6 | *** | MONSTER | 6 |
LOC: | 26 | *** | MONSTER | 26 |
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/write_nat.c clones of add_area_cats_to_cidx are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/write_nat.c delete_area_cats_from_cidx
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/write_nat.c clones of delete_area_cats_from_cidx are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/write_nat.c add_area_cats_to_cidx
____________________________________________
Threshold grass key metrics values at Tue Jun 30 11:56:07 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
