[GRASS-QA] GRASS QA: glynn |main.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Tue Jun 30 12:37:27 EDT 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/general/g.parser/main.c
Class
context(Begins at: 36, Ends at:46)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
main(Begins at: 258, Ends at:421)
| New Metrics |Old Metrics|
Complexity: | 21 | *** | MONSTER | 21 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 42 | *** | MONSTER | 42 |
LOC: | 164 | *** | MONSTER | 164 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
parse_boolean(Begins at: 171, Ends at:183)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 13 | | OK | 13 |
Conclusion: | this function is a OK |
metrics are OK
parse_flag(Begins at: 118, Ends at:153)
Complexity: | 7 | * | WARNING | 7 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 36 | | OK | 36 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
parse_module(Begins at: 89, Ends at:116)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 28 | | OK | 28 |
at least 2 values are close to an outlier please consider revising code!
parse_option(Begins at: 185, Ends at:256)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
CalledNBR: | 30 | ** | BABY-MONSTER | 30 |
LOC: | 72 | * | WARNING | 72 |
Conclusion: | this function is a BABY-MONSTER |
parse_toplevel(Begins at: 62, Ends at:87)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 26 | | OK | 26 |
at least 1 values are close to an outlier please consider revising code!
parse_type(Begins at: 155, Ends at:169)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 15 | | OK | 15 |
metrics are OK
translate(Begins at: 52, Ends at:60)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
LOC: | 9 | | OK | 9 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Jun 30 12:25:18 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
