[GRASS-QA] GRASS QA: hamish |TcholBand.c main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Jun 30 12:44:40 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/vector/lidar/lidarlib/TcholBand.c
          Function
tcholDec(Begins at: 10, Ends at:32)
              |          New Metrics           |Old Metrics|
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      23 |       |           OK |        23 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
tcholInv(Begins at: 110, Ends at:149)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      40 |       |           OK |        40 |
tcholSolve(Begins at: 37, Ends at:72)
ParamNBR:     |       5 |     * |      WARNING |         5 |
LOC:          |      36 |       |           OK |        36 |
tcholSolve2(Begins at: 79, Ends at:105)
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      27 |       |           OK |        27 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
tcholSolveInv(Begins at: 154, Ends at:214)
Complexity:   |      12 |     * |      WARNING |        12 |
LOC:          |      61 |     * |      WARNING |        61 |
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/vector/lidar/v.lidar.edgedetection/main.c
          Function
main(Begins at: 41, Ends at:389)
Complexity:   |      24 |   *** |      MONSTER |        24 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     138 |   *** |      MONSTER |       138 |
LOC:          |     349 |   *** |      MONSTER |       349 |
Conclusion:   | this function is a       MONSTER           |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Jun 30 12:32:31 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
