[GRASS-QA] GRASS QA: hamish |printwindow.c wind_format.c report.c formspecific.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Jun 30 13:53:28 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/general/g.region/printwindow.c
          Function
print_window(Begins at: 8, Ends at:653)
              |          New Metrics           |Old Metrics|
Complexity:   |      71 |   *** |      MONSTER |        71 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     232 |   *** |      MONSTER |       232 |
LOC:          |     646 |   *** |      MONSTER |       646 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/gis/wind_format.c
          Function
G_format_easting(Begins at: 59, Ends at:67)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       9 |       |           OK |         9 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_format_northing(Begins at: 36, Ends at:44)
ParamNBR:     |       3 |     * |      WARNING |         3 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
G_format_resolution(Begins at: 82, Ends at:90)
format_double(Begins at: 92, Ends at:98)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |     * |      WARNING |         2 |
LOC:          |       7 |       |           OK |         7 |
Clone analysis:
          File :grass/trunk/raster/r.distance/report.c
          Function
report(Begins at: 21, Ends at:79)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      22 |     * |      WARNING |        22 |
LOC:          |      59 |     * |      WARNING |        59 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/raster/r.out.ascii/formspecific.c
          Function
writeGRASSheader(Begins at: 5, Ends at:24)
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      20 |       |           OK |        20 |
writeGSheader(Begins at: 129, Ends at:158)
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      30 |       |           OK |        30 |
writeMFheader(Begins at: 70, Ends at:78)
ParamNBR:     |       4 |     * |      WARNING |         4 |
write_GRASS(Begins at: 27, Ends at:68)
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      42 |     * |      WARNING |        42 |
Conclusion:   | this function is a  BABY-MONSTER           |
write_GSGRID(Begins at: 161, Ends at:212)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      52 |     * |      WARNING |        52 |
write_MODFLOW(Begins at: 81, Ends at:126)
Complexity:   |      12 |     * |      WARNING |        12 |
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      46 |     * |      WARNING |        46 |
Clone analysis:
          File :grass/trunk/raster/r.stats/raw_stats.c
          Function
raw_stats(Begins at: 5, Ends at:113)
Complexity:   |      22 |   *** |      MONSTER |        22 |
CalledNBR:    |      35 |    ** | BABY-MONSTER |        35 |
LOC:          |     109 |    ** | BABY-MONSTER |       109 |
Clone analysis:
          File :grass/trunk/sites/s.out.ascii/main.c
          Function
main(Begins at: 22, Ends at:138)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
CalledNBR:    |      36 |    ** | BABY-MONSTER |        36 |
LOC:          |     117 |    ** | BABY-MONSTER |       117 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Jun 30 13:41:19 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
