[GRASS-QA] GRASS QA: martinl |display_raster.h draw2.c raster.c
raster2.c ...| 12 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Tue Jun 30 14:08:14 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/display_raster.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/display/draw2.c
Class
plane(Begins at: 22, Ends at:25)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
rectangle(Begins at: 9, Ends at:15)
Class
vector(Begins at: 17, Ends at:20)
Function
D_box(Begins at: 894, Ends at:906)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 13 | | OK | 13 |
Conclusion: | this function is a OK |
metrics are OK
D_box_clip(Begins at: 827, Ends at:836)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 10 | | OK | 10 |
metrics are OK
D_clip_to_display(Begins at: 289, Ends at:293)
ParamNBR: | 1 | * | WARNING | 1 |
CalledNBR: | 5 | * | WARNING | 5 |
LOC: | 5 | | OK | 5 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
D_clip_to_map(Begins at: 323, Ends at:327)
CalledNBR: | 5 | | OK | 5 |
at least 1 values are close to an outlier please consider revising code!
D_clip_to_screen(Begins at: 305, Ends at:311)
CalledNBR: | 2 | | OK | 2 |
LOC: | 7 | | OK | 7 |
D_cont(Begins at: 846, Ends at:852)
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 3 | | OK | 3 |
D_cont_abs(Begins at: 865, Ends at:868)
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 4 | | OK | 4 |
metrics are OK
D_cont_abs_clip(Begins at: 466, Ends at:479)
Complexity: | 2 | | OK | 2 |
LOC: | 14 | * | WARNING | 14 |
D_cont_clip(Begins at: 442, Ends at:458)
LOC: | 17 | * | WARNING | 17 |
D_line(Begins at: 854, Ends at:858)
ParamNBR: | 4 | * | WARNING | 4 |
D_line_abs(Begins at: 870, Ends at:874)
D_line_abs_clip(Begins at: 481, Ends at:485)
Complexity: | 1 | * | WARNING | 1 |
D_line_clip(Begins at: 460, Ends at:464)
D_line_width(Begins at: 908, Ends at:911)
CalledNBR: | 0 | | OK | 0 |
D_move(Begins at: 838, Ends at:844)
ParamNBR: | 2 | ** | BABY-MONSTER | 2 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
D_move_abs(Begins at: 860, Ends at:863)
D_move_abs_clip(Begins at: 345, Ends at:349)
D_move_clip(Begins at: 339, Ends at:343)
D_polydots(Begins at: 876, Ends at:880)
ParamNBR: | 3 | | OK | 3 |
metrics are OK
D_polydots_clip(Begins at: 487, Ends at:517)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 31 | | OK | 31 |
metrics are OK
D_polygon(Begins at: 888, Ends at:892)
metrics are OK
D_polygon_clip(Begins at: 783, Ends at:792)
metrics are OK
D_polygon_cull(Begins at: 703, Ends at:712)
metrics are OK
D_polyline(Begins at: 882, Ends at:886)
metrics are OK
D_polyline_clip(Begins at: 615, Ends at:627)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 3 | * | WARNING | 3 |
D_polyline_cull(Begins at: 593, Ends at:605)
Complexity: | 4 | * | WARNING | 4 |
D_set_clip(Begins at: 264, Ends at:277)
LOC: | 14 | | OK | 14 |
alloc_dst(Begins at: 47, Ends at:56)
alloc_src(Begins at: 58, Ends at:67)
box_clip(Begins at: 794, Ends at:810)
CalledNBR: | 13 | | OK | 13 |
LOC: | 17 | | OK | 17 |
box_clip_ll(Begins at: 812, Ends at:825)
clip_plane(Begins at: 119, Ends at:155)
LOC: | 37 | | OK | 37 |
clip_polygon_plane(Begins at: 714, Ends at:752)
LOC: | 39 | | OK | 39 |
coerce(Begins at: 192, Ends at:198)
cull_polygon_plane(Begins at: 629, Ends at:672)
LOC: | 44 | | OK | 44 |
cull_polyline_plane(Begins at: 519, Ends at:562)
dealloc_src(Begins at: 69, Ends at:83)
LOC: | 15 | | OK | 15 |
dist_plane(Begins at: 109, Ends at:112)
CalledNBR: | 0 | * | WARNING | 0 |
do_clip(Begins at: 157, Ends at:180)
Complexity: | 9 | | OK | 9 |
CalledNBR: | 4 | * | WARNING | 4 |
LOC: | 24 | | OK | 24 |
do_convert(Begins at: 85, Ends at:107)
Complexity: | 5 | | OK | 5 |
LOC: | 23 | | OK | 23 |
do_ll_wrap(Begins at: 231, Ends at:250)
ParamNBR: | 7 | * | WARNING | 7 |
CalledNBR: | 2 | * | WARNING | 2 |
LOC: | 20 | | OK | 20 |
euclidify(Begins at: 200, Ends at:229)
CalledNBR: | 7 | | OK | 7 |
LOC: | 30 | | OK | 30 |
metrics are OK
interpolate(Begins at: 114, Ends at:117)
metrics are OK
line_clip(Begins at: 366, Ends at:390)
LOC: | 25 | | OK | 25 |
metrics are OK
line_clip_abs(Begins at: 416, Ends at:440)
metrics are OK
line_clip_ll(Begins at: 392, Ends at:414)
polygon_clip(Begins at: 754, Ends at:781)
CalledNBR: | 11 | | OK | 11 |
LOC: | 28 | | OK | 28 |
polygon_cull(Begins at: 674, Ends at:701)
metrics are OK
polyline_clip(Begins at: 607, Ends at:613)
metrics are OK
polyline_cull(Begins at: 564, Ends at:591)
metrics are OK
shift_angle(Begins at: 187, Ends at:190)
ParamNBR: | 1 | | OK | 1 |
metrics are OK
shift_count(Begins at: 182, Ends at:185)
Clone analysis:
This file has 12 potentially cloned functions:
D_polygon_clip D_polyline_cull D_polyline_clip alloc_src alloc_dst polyline_cull polygon_cull polyline_cull polygon_clip polygon_cull polygon_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of D_polygon_clip are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c D_polygon_cull
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of D_polygon_cull are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c D_polygon_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of D_polyline_clip are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c D_polyline_cull
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of D_polyline_cull are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c D_polyline_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of alloc_dst are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c alloc_src
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of alloc_src are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c alloc_dst
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of polygon_clip are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c polyline_cull
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c polygon_cull
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of polygon_cull are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c polygon_clip
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/draw2.c clones of polyline_cull are:
File :grass/trunk/lib/display/raster.c
Function
D_cell_draw_end(Begins at: 203, Ends at:206)
D_cell_draw_setup(Begins at: 133, Ends at:149)
metrics are OK
D_draw_c_raster(Begins at: 56, Ends at:59)
D_draw_cell(Begins at: 78, Ends at:81)
D_draw_d_raster(Begins at: 46, Ends at:49)
D_draw_f_raster(Begins at: 51, Ends at:54)
D_draw_raster(Begins at: 39, Ends at:44)
LOC: | 6 | | OK | 6 |
D_draw_raster_RGB(Begins at: 151, Ends at:201)
ParamNBR: | 10 | * | WARNING | 10 |
CalledNBR: | 17 | | OK | 17 |
LOC: | 51 | | OK | 51 |
draw_cell(Begins at: 83, Ends at:116)
ParamNBR: | 4 | *** | MONSTER | 4 |
CalledNBR: | 9 | * | WARNING | 9 |
LOC: | 34 | * | WARNING | 34 |
Conclusion: | this function is a MONSTER |
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/display/raster2.c
Function
D_c_color(Begins at: 74, Ends at:77)
metrics are OK
D_color(Begins at: 68, Ends at:71)
D_color_of_type(Begins at: 134, Ends at:143)
metrics are OK
D_d_color(Begins at: 93, Ends at:96)
metrics are OK
D_f_color(Begins at: 112, Ends at:115)
metrics are OK
D_set_overlay_mode(Begins at: 50, Ends at:55)
metrics are OK
Clone analysis:
File :grass/trunk/lib/display/r_raster.c
File :grass/trunk/lib/display/tran_colr.c
Function
D_color_number_to_RGB(Begins at: 183, Ends at:215)
Complexity: | 10 | * | WARNING | 10 |
LOC: | 33 | | OK | 33 |
D_parse_color(Begins at: 123, Ends at:133)
LOC: | 11 | | OK | 11 |
metrics are OK
D_raster_use_color(Begins at: 146, Ends at:164)
LOC: | 19 | | OK | 19 |
metrics are OK
D_translate_color(Begins at: 27, Ends at:40)
metrics are OK
translate_or_add_color(Begins at: 58, Ends at:107)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 50 | * | WARNING | 50 |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/trunk/lib/display/window.c
Function
D_check_map_window(Begins at: 192, Ends at:201)
D_erase(Begins at: 255, Ends at:272)
LOC: | 18 | | OK | 18 |
metrics are OK
D_erase_window(Begins at: 246, Ends at:253)
LOC: | 8 | | OK | 8 |
metrics are OK
D_full_screen(Begins at: 280, Ends at:288)
LOC: | 9 | | OK | 9 |
metrics are OK
D_get_screen_window(Begins at: 65, Ends at:82)
metrics are OK
D_new_window(Begins at: 101, Ends at:106)
ParamNBR: | 5 | | OK | 5 |
metrics are OK
D_new_window_percent(Begins at: 125, Ends at:147)
ParamNBR: | 5 | * | WARNING | 5 |
D_remove_window(Begins at: 231, Ends at:235)
D_remove_windows(Begins at: 274, Ends at:278)
D_reset_screen_window(Begins at: 217, Ends at:220)
metrics are OK
D_set_window(Begins at: 43, Ends at:50)
metrics are OK
D_show_window(Begins at: 163, Ends at:175)
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Jun 30 13:56:04 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
