[GRASS-QA] GRASS QA: glynn |gisdefs.h raster.h debug.c G.h ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Jun 30 15:10:19 EDT 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/include/gisdefs.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/include/raster.h
          File :grass/trunk/lib/gis/debug.c
          Function
G_debug(Begins at: 46, Ends at:90)
              |          New Metrics           |Old Metrics|
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      45 |     * |      WARNING |        45 |
Conclusion:   | this function is a       WARNING           |
 at least 4 values are close to an outlier please consider revising code!
G_dump(Begins at: 103, Ends at:156)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      46 |   *** |      MONSTER |        46 |
LOC:          |      54 |     * |      WARNING |        54 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/gis/G.h
          Class
G__(Begins at: 49, Ends at:71)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
fileinfo(Begins at: 17, Ends at:47)
Clone analysis:
          File :grass/trunk/lib/gis/get_window.c
          Function
G__get_window(Begins at: 126, Ends at:156)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       4 |       |           OK |         4 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      31 |       |           OK |        31 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_get_default_window(Begins at: 115, Ends at:124)
Complexity:   |       2 |     * |      WARNING |         2 |
CalledNBR:    |       4 |     * |      WARNING |         4 |
LOC:          |      10 |     * |      WARNING |        10 |
 at least 3 values are close to an outlier please consider revising code!
G_get_window(Begins at: 47, Ends at:100)
Complexity:   |       7 |       |           OK |         7 |
ParamNBR:     |       1 |     * |      WARNING |         1 |
CalledNBR:    |      19 |       |           OK |        19 |
LOC:          |      54 |       |           OK |        54 |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/lib/gis/gisinit.c
          Function
G__check_gisinit(Begins at: 104, Ends at:111)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
G__gisinit(Begins at: 44, Ends at:72)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      12 |       |           OK |        12 |
LOC:          |      29 |       |           OK |        29 |
G__no_gisinit(Begins at: 83, Ends at:94)
LOC:          |      12 |       |           OK |        12 |
metrics are OK
gisinit(Begins at: 114, Ends at:146)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      33 |       |           OK |        33 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/gis/set_window.c
          Function
G_get_set_window(Begins at: 30, Ends at:36)
LOC:          |       7 |       |           OK |         7 |
metrics are OK
G_set_window(Begins at: 49, Ends at:152)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |     104 |    ** | BABY-MONSTER |       104 |
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
          File :grass/trunk/lib/gis/window_map.c
          Function
G__create_window_mapping(Begins at: 36, Ends at:113)
Complexity:   |      15 |       |           OK |        15 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      78 |       |           OK |        78 |
metrics are OK
G__init_window(Begins at: 319, Ends at:327)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
G_adjust_east_longitude(Begins at: 148, Ends at:156)
CalledNBR:    |       0 |       |           OK |         0 |
metrics are OK
G_adjust_easting(Begins at: 173, Ends at:182)
LOC:          |      10 |       |           OK |        10 |
metrics are OK
G_col_to_easting(Begins at: 242, Ends at:245)
LOC:          |       4 |       |           OK |         4 |
metrics are OK
G_easting_to_col(Begins at: 197, Ends at:202)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
G_northing_to_row(Begins at: 128, Ends at:131)
metrics are OK
G_row_repeat_nomask(Begins at: 343, Ends at:373)
Complexity:   |       5 |       |           OK |         5 |
metrics are OK
G_row_to_northing(Begins at: 222, Ends at:225)
metrics are OK
G_window_cols(Begins at: 305, Ends at:310)
Complexity:   |       1 |    ** | BABY-MONSTER |         1 |
LOC:          |       6 |     * |      WARNING |         6 |
G_window_rows(Begins at: 272, Ends at:277)
metrics are OK
Clone analysis:
          File :grass/trunk/lib/raster/auto_mask.c
          File :grass/trunk/lib/raster/closecell.c
          File :grass/trunk/lib/raster/color_read.c
          File :grass/trunk/lib/raster/format.c
          File :grass/trunk/lib/raster/G.h
          File :grass/trunk/lib/raster/gdal.c
          File :grass/trunk/lib/raster/get_row.c
          File :grass/trunk/lib/raster/get_row_colr.c
          File :grass/trunk/lib/raster/init.c
          File :grass/trunk/lib/raster/maskfd.c
          File :grass/trunk/lib/raster/opencell.c
          File :grass/trunk/lib/raster/put_row.c
          File :grass/trunk/lib/raster/R.h
          File :grass/trunk/lib/raster/range.c
          File :grass/trunk/lib/raster/set_window.c
          File :grass/trunk/lib/raster/window_map.c
____________________________________________
Threshold grass key metrics values at Tue Jun 30 14:58:08 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
