[GRASS-QA] GRASS QA: glynn |gisdefs.h set_window.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Tue Jun 30 15:24:47 EDT 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/gisdefs.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/gis/set_window.c
Function
G_get_set_window(Begins at: 30, Ends at:36)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | |
ParamNBR: | 1 | | OK | |
CalledNBR: | 3 | | OK | |
LOC: | 7 | | OK | |
Conclusion: | this function is a OK |
metrics are OK
G_set_window(Begins at: 49, Ends at:152)
Complexity: | 10 | * | WARNING | |
CalledNBR: | 15 | * | WARNING | |
LOC: | 104 | ** | BABY-MONSTER | |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Jun 30 15:12:36 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
