[GRASS-QA] GRASS QA: martinl |do_header.c do_labels.c ps_clrtbl.c ps_fclrtbl.c ...| 1 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Jun 30 15:33:07 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/ps/ps.map/do_header.c
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/ps/ps.map/do_labels.c
          File :grass/trunk/ps/ps.map/ps_clrtbl.c
          File :grass/trunk/ps/ps.map/ps_fclrtbl.c
          File :grass/trunk/ps/ps.map/ps_vpoints.c
          File :grass/trunk/ps/ps.map/r_border.c
          File :grass/trunk/ps/ps.map/r_cell.c
          File :grass/trunk/ps/ps.map/r_colortable.c
          File :grass/trunk/ps/ps.map/r_plt.c
          File :grass/trunk/ps/ps.map/r_rgb.c
          File :grass/trunk/ps/ps.map/r_text.c
          File :grass/trunk/ps/ps.map/r_vlines.c
          File :grass/trunk/ps/ps.map/r_wind.c
          File :grass/trunk/raster/r.buffer/main.c
          File :grass/trunk/raster/r.buffer/read_map.c
          File :grass/trunk/raster/r.buffer/support.c
          Function
make_support_files(Begins at: 25, Ends at:60)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      36 |       |           OK |        36 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/raster/r.buffer/write_map.c
          Function
write_output_map(Begins at: 29, Ends at:91)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
CalledNBR:    |      22 |     * |      WARNING |        22 |
LOC:          |      63 |     * |      WARNING |        63 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :grass/trunk/raster/r.coin/print_hdr.c
          Function
print_coin_hdr(Begins at: 22, Ends at:85)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      32 |    ** | BABY-MONSTER |        32 |
LOC:          |      64 |     * |      WARNING |        64 |
Clone analysis:
          File :grass/trunk/raster/r.cross/cats.c
          Function
get_label(Begins at: 55, Ends at:64)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
set_cat(Begins at: 25, Ends at:53)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      29 |       |           OK |        29 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/raster/r.cross/cross.c
          Function
cross(Begins at: 25, Ends at:182)
Complexity:   |      31 |   *** |      MONSTER |        31 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      23 |    ** | BABY-MONSTER |        23 |
LOC:          |     158 |   *** |      MONSTER |       158 |
Conclusion:   | this function is a       MONSTER           |
Clone analysis:
          File :grass/trunk/raster/r.cross/main.c
          Function
cmp(Begins at: 191, Ends at:203)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
main(Begins at: 41, Ends at:189)
Complexity:   |      16 |    ** | BABY-MONSTER |        16 |
CalledNBR:    |      66 |   *** |      MONSTER |        66 |
LOC:          |     149 |   *** |      MONSTER |       149 |
Clone analysis:
          File :grass/trunk/raster/r.cross/renumber.c
          Function
renumber(Begins at: 25, Ends at:49)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      25 |       |           OK |        25 |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/raster/r.distance/distance.c
          Function
find_minimum_distance(Begins at: 27, Ends at:76)
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |      11 |   *** |      MONSTER |        11 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      50 |     * |      WARNING |        50 |
null_distance(Begins at: 78, Ends at:166)
CalledNBR:    |      27 |    ** | BABY-MONSTER |        27 |
LOC:          |      89 |     * |      WARNING |        89 |
Clone analysis:
          File :grass/trunk/raster/r.distance/edges.c
          Function
add_edge_cell(Begins at: 95, Ends at:136)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      42 |     * |      WARNING |        42 |
 at least 3 values are close to an outlier please consider revising code!
cmp(Begins at: 146, Ends at:151)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
find_edge_cells(Begins at: 32, Ends at:93)
Complexity:   |       7 |     * |      WARNING |         7 |
LOC:          |      62 |     * |      WARNING |        62 |
init_edge_list(Begins at: 138, Ends at:144)
LOC:          |       7 |       |           OK |         7 |
metrics are OK
print_edge_info(Begins at: 22, Ends at:30)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
sort_edge_list(Begins at: 153, Ends at:158)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.distance/labels.c
          Function
get_label(Begins at: 28, Ends at:33)
CalledNBR:    |       1 |       |           OK |         1 |
metrics are OK
read_labels(Begins at: 22, Ends at:26)
LOC:          |       5 |       |           OK |         5 |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.flow/io.c
          Function
close_files(Begins at: 173, Ends at:187)
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      15 |       |           OK |        15 |
metrics are OK
open_existing_cell_file(Begins at: 58, Ends at:69)
LOC:          |      12 |       |           OK |        12 |
metrics are OK
open_output_files(Begins at: 156, Ends at:171)
LOC:          |      16 |       |           OK |        16 |
open_segment_file(Begins at: 128, Ends at:154)
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      27 |       |           OK |        27 |
read_input_files(Begins at: 71, Ends at:126)
CalledNBR:    |      26 |    ** | BABY-MONSTER |        26 |
LOC:          |      56 |     * |      WARNING |        56 |
tmp_name(Begins at: 41, Ends at:54)
LOC:          |      14 |       |           OK |        14 |
metrics are OK
write_density_file(Begins at: 189, Ends at:226)
LOC:          |      38 |       |           OK |        38 |
Clone analysis:
          File :grass/trunk/raster/r.in.gridatb/adjcellhd.c
          Function
adjcellhd(Begins at: 4, Ends at:24)
LOC:          |      21 |       |           OK |        21 |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.in.gridatb/main.c
          Function
main(Begins at: 29, Ends at:76)
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      48 |     * |      WARNING |        48 |
Clone analysis:
          File :grass/trunk/raster/r.kappa/mask.c
          Function
append(Begins at: 92, Ends at:101)
metrics are OK
do_text(Begins at: 76, Ends at:89)
CalledNBR:    |       4 |       |           OK |         4 |
maskinfo(Begins at: 13, Ends at:45)
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      33 |       |           OK |        33 |
reclass_text(Begins at: 48, Ends at:73)
LOC:          |      26 |       |           OK |        26 |
Clone analysis:
          File :grass/trunk/raster/r.kappa/prt_hdr.c
          Function
prn_header(Begins at: 7, Ends at:46)
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      40 |       |           OK |        40 |
Clone analysis:
          File :grass/trunk/raster/r.kappa/prt_label.c
          Function
prt_label(Begins at: 6, Ends at:36)
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      31 |       |           OK |        31 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/column_shift.c
          Function
column_shift(Begins at: 7, Ends at:95)
Complexity:   |      29 |   *** |      MONSTER |        29 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/map.c
          Class
map(Begins at: 49, Ends at:65)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
row_cache(Begins at: 42, Ends at:47)
          Class
sub_cache(Begins at: 35, Ends at:40)
          Function
cache_get(Begins at: 189, Ends at:193)
Complexity:   |       1 |     * |      WARNING |         1 |
ParamNBR:     |       4 |       |           OK |         4 |
cache_get_raw(Begins at: 130, Ends at:187)
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |      11 |       |           OK |        11 |
LOC:          |      58 |       |           OK |        58 |
metrics are OK
cache_release(Begins at: 109, Ends at:128)
LOC:          |      20 |       |           OK |        20 |
metrics are OK
cache_setup(Begins at: 100, Ends at:107)
LOC:          |       8 |       |           OK |         8 |
metrics are OK
cache_sub_init(Begins at: 86, Ends at:98)
metrics are OK
check_output_map(Begins at: 651, Ends at:654)
LOC:          |       4 |       |           OK |         4 |
metrics are OK
close_map(Begins at: 426, Ends at:454)
metrics are OK
close_maps(Begins at: 635, Ends at:647)
Complexity:   |       2 |     * |      WARNING |         2 |
close_output_map(Begins at: 673, Ends at:677)
ParamNBR:     |       1 |    ** | BABY-MONSTER |         1 |
CalledNBR:    |       3 |     * |      WARNING |         3 |
compare_ints(Begins at: 197, Ends at:200)
metrics are OK
copy_cats(Begins at: 686, Ends at:696)
LOC:          |      11 |       |           OK |        11 |
metrics are OK
copy_colors(Begins at: 698, Ends at:708)
copy_history(Begins at: 710, Ends at:719)
metrics are OK
create_history(Begins at: 721, Ends at:761)
ParamNBR:     |       2 |     * |      WARNING |         2 |
LOC:          |      41 |       |           OK |        41 |
get_map_row(Begins at: 593, Ends at:633)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       7 |     * |      WARNING |         7 |
CalledNBR:    |      15 |       |           OK |        15 |
init_cats(Begins at: 211, Ends at:222)
ParamNBR:     |       1 |     * |      WARNING |         1 |
init_colors(Begins at: 202, Ends at:209)
metrics are OK
map_type(Begins at: 458, Ends at:484)
Complexity:   |      11 |       |           OK |        11 |
metrics are OK
open_map(Begins at: 486, Ends at:579)
Complexity:   |      27 |       |           OK |        27 |
CalledNBR:    |      19 |       |           OK |        19 |
LOC:          |      94 |       |           OK |        94 |
metrics are OK
open_output_map(Begins at: 656, Ends at:665)
metrics are OK
put_map_row(Begins at: 667, Ends at:671)
LOC:          |       5 |     * |      WARNING |         5 |
 at least 4 values are close to an outlier please consider revising code!
read_map(Begins at: 387, Ends at:424)
Complexity:   |      12 |       |           OK |        12 |
ParamNBR:     |       5 |       |           OK |         5 |
metrics are OK
read_row(Begins at: 365, Ends at:369)
setup_map(Begins at: 371, Ends at:385)
CalledNBR:    |       2 |     * |      WARNING |         2 |
LOC:          |      15 |     * |      WARNING |        15 |
setup_maps(Begins at: 581, Ends at:591)
metrics are OK
setup_region(Begins at: 24, Ends at:31)
translate_from_cats(Begins at: 300, Ends at:363)
Complexity:   |       8 |       |           OK |         8 |
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      64 |       |           OK |        64 |
metrics are OK
translate_from_colors(Begins at: 224, Ends at:275)
Complexity:   |      17 |       |           OK |        17 |
LOC:          |      52 |       |           OK |        52 |
metrics are OK
unopen_output_map(Begins at: 679, Ends at:682)
Complexity:   |       1 |   *** |      MONSTER |         1 |
CalledNBR:    |       1 |     * |      WARNING |         1 |
LOC:          |       4 |    ** | BABY-MONSTER |         4 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/map3.c
          Function
check_output_map(Begins at: 569, Ends at:572)
metrics are OK
close_map(Begins at: 361, Ends at:380)
metrics are OK
close_maps(Begins at: 557, Ends at:565)
metrics are OK
close_output_map(Begins at: 605, Ends at:611)
metrics are OK
compare_ints(Begins at: 160, Ends at:163)
metrics are OK
copy_cats(Begins at: 620, Ends at:630)
metrics are OK
copy_colors(Begins at: 632, Ends at:642)
metrics are OK
copy_history(Begins at: 644, Ends at:646)
LOC:          |       3 |       |           OK |         3 |
metrics are OK
create_history(Begins at: 648, Ends at:650)
metrics are OK
get_map_row(Begins at: 523, Ends at:555)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
init_cats(Begins at: 183, Ends at:194)
metrics are OK
init_colors(Begins at: 165, Ends at:181)
LOC:          |      17 |       |           OK |        17 |
metrics are OK
map_type(Begins at: 384, Ends at:420)
Complexity:   |      12 |     * |      WARNING |        12 |
LOC:          |      37 |       |           OK |        37 |
open_map(Begins at: 422, Ends at:513)
Complexity:   |      26 |     * |      WARNING |        26 |
CalledNBR:    |      17 |       |           OK |        17 |
LOC:          |      92 |       |           OK |        92 |
open_output_map(Begins at: 574, Ends at:596)
Complexity:   |       3 |   *** |      MONSTER |         3 |
CalledNBR:    |       5 |     * |      WARNING |         5 |
LOC:          |      23 |    ** | BABY-MONSTER |        23 |
put_map_row(Begins at: 598, Ends at:603)
metrics are OK
read_map(Begins at: 324, Ends at:359)
ParamNBR:     |       6 |     * |      WARNING |         6 |
read_row(Begins at: 66, Ends at:105)
ParamNBR:     |       5 |    ** | BABY-MONSTER |         5 |
setup_map(Begins at: 320, Ends at:322)
setup_maps(Begins at: 515, Ends at:521)
metrics are OK
setup_region(Begins at: 20, Ends at:28)
metrics are OK
translate_from_cats(Begins at: 263, Ends at:318)
LOC:          |      56 |       |           OK |        56 |
metrics are OK
translate_from_colors(Begins at: 196, Ends at:238)
Complexity:   |      17 |     * |      WARNING |        17 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
LOC:          |      43 |     * |      WARNING |        43 |
unopen_output_map(Begins at: 613, Ends at:616)
Complexity:   |       1 |    ** | BABY-MONSTER |         1 |
LOC:          |       4 |     * |      WARNING |         4 |
write_row(Begins at: 107, Ends at:156)
Complexity:   |      14 |       |           OK |        14 |
CalledNBR:    |      12 |       |           OK |        12 |
LOC:          |      50 |       |           OK |        50 |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xabs.c
          Function
f_abs(Begins at: 15, Ends at:68)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
LOC:          |      54 |     * |      WARNING |        54 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xacos.c
          Function
f_acos(Begins at: 21, Ends at:49)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xadd.c
          Function
f_add(Begins at: 11, Ends at:77)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
LOC:          |      67 |     * |      WARNING |        67 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xand.c
          Function
f_and(Begins at: 11, Ends at:40)
Complexity:   |       9 |     * |      WARNING |         9 |
LOC:          |      30 |       |           OK |        30 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xand2.c
          Function
f_and2(Begins at: 18, Ends at:47)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xasin.c
          Function
f_asin(Begins at: 21, Ends at:49)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xatan.c
          Function
f_atan(Begins at: 22, Ends at:65)
LOC:          |      44 |     * |      WARNING |        44 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xbitand.c
          Function
f_bitand(Begins at: 11, Ends at:39)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xbitnot.c
          Function
f_bitnot(Begins at: 11, Ends at:36)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xbitor.c
          Function
f_bitor(Begins at: 11, Ends at:39)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xbitxor.c
          Function
f_bitxor(Begins at: 11, Ends at:39)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xcoor.c
          Function
f_x(Begins at: 14, Ends at:34)
f_y(Begins at: 36, Ends at:54)
LOC:          |      19 |       |           OK |        19 |
f_z(Begins at: 56, Ends at:71)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xcos.c
          Function
f_cos(Begins at: 20, Ends at:48)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xdiv.c
          Function
f_div(Begins at: 11, Ends at:80)
Complexity:   |      17 |    ** | BABY-MONSTER |        17 |
LOC:          |      70 |     * |      WARNING |        70 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xdouble.c
          Function
c_double(Begins at: 66, Ends at:77)
metrics are OK
f_double(Begins at: 14, Ends at:64)
LOC:          |      51 |     * |      WARNING |        51 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xeq.c
          Function
f_eq(Begins at: 11, Ends at:71)
LOC:          |      61 |     * |      WARNING |        61 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xeval.c
          Function
c_eval(Begins at: 66, Ends at:74)
metrics are OK
f_eval(Begins at: 13, Ends at:64)
LOC:          |      52 |     * |      WARNING |        52 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xexp.c
          Function
f_exp(Begins at: 17, Ends at:54)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xfloat.c
          Function
c_float(Begins at: 66, Ends at:77)
metrics are OK
f_float(Begins at: 14, Ends at:64)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xge.c
          Function
f_ge(Begins at: 11, Ends at:64)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xgraph.c
          Function
c_graph(Begins at: 14, Ends at:28)
metrics are OK
f_graph(Begins at: 30, Ends at:100)
Complexity:   |      19 |    ** | BABY-MONSTER |        19 |
CalledNBR:    |      25 |    ** | BABY-MONSTER |        25 |
LOC:          |      71 |     * |      WARNING |        71 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xgt.c
          Function
f_gt(Begins at: 11, Ends at:64)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xif.c
          Function
c_if(Begins at: 272, Ends at:304)
f_if(Begins at: 244, Ends at:270)
f_if_d(Begins at: 169, Ends at:242)
Complexity:   |      24 |   *** |      MONSTER |        24 |
LOC:          |      74 |     * |      WARNING |        74 |
f_if_f(Begins at: 94, Ends at:167)
f_if_i(Begins at: 14, Ends at:92)
Complexity:   |      26 |   *** |      MONSTER |        26 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      79 |     * |      WARNING |        79 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xint.c
          Function
c_int(Begins at: 66, Ends at:77)
metrics are OK
f_int(Begins at: 14, Ends at:64)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xisnull.c
          Function
c_isnull(Begins at: 55, Ends at:65)
metrics are OK
f_isnull(Begins at: 12, Ends at:53)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xle.c
          Function
f_le(Begins at: 11, Ends at:64)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xlog.c
          Function
f_log(Begins at: 23, Ends at:60)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xlt.c
          Function
f_lt(Begins at: 11, Ends at:64)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xmax.c
          Function
f_max(Begins at: 13, Ends at:99)
Complexity:   |      27 |   *** |      MONSTER |        27 |
LOC:          |      87 |     * |      WARNING |        87 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xmedian.c
          Function
dcmp(Begins at: 34, Ends at:44)
metrics are OK
f_median(Begins at: 46, Ends at:153)
Complexity:   |      22 |       |           OK |        22 |
CalledNBR:    |      14 |       |           OK |        14 |
LOC:          |     108 |       |           OK |       108 |
metrics are OK
fcmp(Begins at: 22, Ends at:32)
CalledNBR:    |       0 |     * |      WARNING |         0 |
LOC:          |      11 |    ** | BABY-MONSTER |        11 |
icmp(Begins at: 14, Ends at:20)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xmin.c
          Function
f_min(Begins at: 13, Ends at:99)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xmod.c
          Function
f_mod(Begins at: 11, Ends at:85)
LOC:          |      75 |     * |      WARNING |        75 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xmode.c
          Function
dcmp(Begins at: 14, Ends at:24)
metrics are OK
f_mode(Begins at: 54, Ends at:143)
Complexity:   |      22 |   *** |      MONSTER |        22 |
LOC:          |      90 |     * |      WARNING |        90 |
mode(Begins at: 26, Ends at:52)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xmul.c
          Function
f_mul(Begins at: 11, Ends at:77)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xne.c
          Function
f_ne(Begins at: 11, Ends at:64)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xneg.c
          Function
f_neg(Begins at: 11, Ends at:63)
LOC:          |      53 |     * |      WARNING |        53 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xnot.c
          Function
c_not(Begins at: 38, Ends at:51)
metrics are OK
f_not(Begins at: 11, Ends at:36)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xnull.c
          Function
f_null(Begins at: 11, Ends at:26)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xor.c
          Function
f_or(Begins at: 11, Ends at:40)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xor2.c
          Function
f_or2(Begins at: 18, Ends at:47)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xpow.c
          Function
f_pow(Begins at: 27, Ends at:97)
ipow(Begins at: 14, Ends at:25)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xres.c
          Function
f_ewres(Begins at: 14, Ends at:29)
f_nsres(Begins at: 31, Ends at:46)
f_tbres(Begins at: 48, Ends at:63)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xround.c
          Function
c_round(Begins at: 98, Ends at:109)
metrics are OK
f_round(Begins at: 46, Ends at:96)
round(Begins at: 23, Ends at:42)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xshiftl.c
          Function
f_shiftl(Begins at: 11, Ends at:37)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xshiftr.c
          Function
f_shiftr(Begins at: 11, Ends at:37)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xshiftru.c
          Function
f_shiftru(Begins at: 11, Ends at:37)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xsin.c
          Function
f_sin(Begins at: 20, Ends at:48)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xsqrt.c
          Function
f_sqrt(Begins at: 16, Ends at:44)
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xsub.c
          Function
f_sub(Begins at: 11, Ends at:69)
LOC:          |      59 |     * |      WARNING |        59 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/xtan.c
          Function
f_tan(Begins at: 21, Ends at:49)
Clone analysis:
          File :grass/trunk/raster/r.mfilter/apply.c
          Function
apply_filter(Begins at: 9, Ends at:50)
Clone analysis:
          File :grass/trunk/raster/r.mfilter/execute.c
          Function
execute_filter(Begins at: 6, Ends at:120)
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |     115 |    ** | BABY-MONSTER |       115 |
Clone analysis:
          File :grass/trunk/raster/r.mfilter/perform.c
          Function
perform_filter(Begins at: 9, Ends at:102)
CalledNBR:    |      36 |    ** | BABY-MONSTER |        36 |
LOC:          |      94 |    ** | BABY-MONSTER |        94 |
Clone analysis:
          File :grass/trunk/raster/r.out.gridatb/adjcellhd.c
          Function
adjcellhd(Begins at: 4, Ends at:18)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.out.gridatb/file_io.c
          Function
rdwr_gridatb(Begins at: 6, Ends at:106)
CalledNBR:    |      41 |   *** |      MONSTER |        41 |
LOC:          |     101 |    ** | BABY-MONSTER |       101 |
Clone analysis:
          File :grass/trunk/raster/r.out.vrml/put_grid.c
          Function
vrml_put_grid(Begins at: 10, Ends at:160)
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      59 |   *** |      MONSTER |        59 |
LOC:          |     151 |   *** |      MONSTER |       151 |
Clone analysis:
          File :grass/trunk/raster/r.param.scale/close_down.c
          Function
close_down(Begins at: 14, Ends at:127)
LOC:          |     114 |    ** | BABY-MONSTER |       114 |
Clone analysis:
          File :grass/trunk/raster/r.param.scale/write_cols.c
          Function
write_cols(Begins at: 19, Ends at:36)
LOC:          |      18 |       |           OK |        18 |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.quant/main.c
          Function
main(Begins at: 31, Ends at:188)
Complexity:   |      28 |    ** | BABY-MONSTER |        28 |
CalledNBR:    |      68 |   *** |      MONSTER |        68 |
Clone analysis:
          File :grass/trunk/raster/r.quant/read_rules.c
          Function
read_range(Begins at: 9, Ends at:42)
LOC:          |      34 |       |           OK |        34 |
read_rules(Begins at: 66, Ends at:166)
Complexity:   |      23 |    ** | BABY-MONSTER |        23 |
CalledNBR:    |      35 |    ** | BABY-MONSTER |        35 |
report_range(Begins at: 44, Ends at:64)
Clone analysis:
          File :grass/trunk/raster/r.recode/read_rules.c
          Function
read_rules(Begins at: 46, Ends at:128)
CalledNBR:    |      50 |   *** |      MONSTER |        50 |
LOC:          |      83 |     * |      WARNING |        83 |
report_range(Begins at: 9, Ends at:44)
update_rules(Begins at: 142, Ends at:157)
metrics are OK
update_type(Begins at: 130, Ends at:140)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.recode/recode.c
          Function
do_recode(Begins at: 22, Ends at:77)
process_row_dd(Begins at: 167, Ends at:176)
metrics are OK
process_row_df(Begins at: 156, Ends at:165)
metrics are OK
process_row_di(Begins at: 145, Ends at:154)
metrics are OK
process_row_fd(Begins at: 134, Ends at:143)
metrics are OK
process_row_ff(Begins at: 123, Ends at:132)
metrics are OK
process_row_fi(Begins at: 112, Ends at:121)
metrics are OK
process_row_id(Begins at: 101, Ends at:110)
metrics are OK
process_row_if(Begins at: 90, Ends at:99)
metrics are OK
process_row_ii(Begins at: 79, Ends at:88)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.report/header.c
          Function
divider(Begins at: 128, Ends at:140)
metrics are OK
header(Begins at: 16, Ends at:126)
CalledNBR:    |      53 |   *** |      MONSTER |        53 |
LOC:          |     111 |    ** | BABY-MONSTER |       111 |
lcr(Begins at: 166, Ends at:180)
max(Begins at: 142, Ends at:145)
metrics are OK
newline(Begins at: 158, Ends at:164)
metrics are OK
pbuf(Begins at: 8, Ends at:14)
metrics are OK
trailer(Begins at: 147, Ends at:156)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.report/parse.c
          Function
match(Begins at: 270, Ends at:278)
parse_command_line(Begins at: 6, Ends at:196)
CalledNBR:    |      56 |   *** |      MONSTER |        56 |
LOC:          |     191 |   *** |      MONSTER |       191 |
parse_layer(Begins at: 232, Ends at:268)
CalledNBR:    |      21 |     * |      WARNING |        21 |
parse_units(Begins at: 198, Ends at:230)
CalledNBR:    |      10 |     * |      WARNING |        10 |
Clone analysis:
          File :grass/trunk/raster/r.report/prt_report.c
          Function
construct_cat_label(Begins at: 291, Ends at:319)
metrics are OK
construct_val_str(Begins at: 259, Ends at:289)
print_report(Begins at: 5, Ends at:257)
Complexity:   |      45 |   *** |      MONSTER |        45 |
CalledNBR:    |      37 |   *** |      MONSTER |        37 |
LOC:          |     253 |   *** |      MONSTER |       253 |
Clone analysis:
          File :grass/trunk/raster/r.report/stats.c
          Function
die(Begins at: 95, Ends at:100)
metrics are OK
get_stats(Begins at: 8, Ends at:93)
Complexity:   |      23 |   *** |      MONSTER |        23 |
CalledNBR:    |      39 |   *** |      MONSTER |        39 |
LOC:          |      86 |     * |      WARNING |        86 |
Clone analysis:
          File :grass/trunk/raster/r.stats/global.h
          File :grass/trunk/raster/r.surf.contour/read_cell.c
          Function
free_cell(Begins at: 33, Ends at:37)
metrics are OK
read_cell(Begins at: 4, Ends at:31)
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      28 |       |           OK |        28 |
Clone analysis:
          File :grass/trunk/raster/r.surf.fractal/write_rast.c
          Function
write_rast(Begins at: 20, Ends at:80)
Clone analysis:
          File :grass/trunk/raster/r.topmodel/global.h
          Class
file(Begins at: 89, Ends at:92)
          Class
flg(Begins at: 131, Ends at:139)
          Class
idxstats(Begins at: 55, Ends at:59)
          Class
input(Begins at: 74, Ends at:80)
          Class
map(Begins at: 83, Ends at:86)
          Class
misc(Begins at: 95, Ends at:129)
          Class
params(Begins at: 62, Ends at:71)
Clone analysis:
          File :grass/trunk/raster/r.univar/globals.h
          File :grass/trunk/raster/r.watershed/ram/Gwater.h
          File :grass/trunk/raster/r.watershed/seg/Gwater.h
          File :grass/trunk/vector/v.to.rast/do_areas.c
          Function
compare(Begins at: 136, Ends at:146)
metrics are OK
do_areas(Begins at: 22, Ends at:84)
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
sort_areas(Begins at: 87, Ends at:133)
LOC:          |      47 |     * |      WARNING |        47 |
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/vector/v.to.rast/do_areas.c clones of compare are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/histogram.c  cmp
____________________________________________
Threshold grass key metrics values at Tue Jun 30 15:20:55 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
