[GRASS-QA] GRASS QA: martinl |main.c dominance.c richness.c
shannon.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Tue Jun 30 15:57:45 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/imagery/i.eb.evapfr/main.c
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/raster/r.li/r.li.dominance/dominance.c
Function
calculate(Begins at: 113, Ends at:317)
| New Metrics |Old Metrics|
Complexity: | 32 | *** | MONSTER | 32 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 29 | ** | BABY-MONSTER | 29 |
LOC: | 205 | *** | MONSTER | 205 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
calculateD(Begins at: 325, Ends at:526)
LOC: | 202 | *** | MONSTER | 202 |
calculateF(Begins at: 529, Ends at:732)
LOC: | 204 | *** | MONSTER | 204 |
dominance(Begins at: 67, Ends at:110)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 44 | * | WARNING | 44 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
main(Begins at: 33, Ends at:64)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 32 | | OK | 32 |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/raster/r.li/r.li.richness/richness.c
Function
calculate(Begins at: 108, Ends at:264)
Complexity: | 29 | *** | MONSTER | 29 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 157 | *** | MONSTER | 157 |
calculateD(Begins at: 267, Ends at:425)
LOC: | 159 | *** | MONSTER | 159 |
calculateF(Begins at: 429, Ends at:591)
LOC: | 163 | *** | MONSTER | 163 |
dominance(Begins at: 64, Ends at:104)
LOC: | 41 | | OK | 41 |
at least 2 values are close to an outlier please consider revising code!
main(Begins at: 31, Ends at:62)
Clone analysis:
File :grass/trunk/raster/r.li/r.li.shannon/shannon.c
Function
calculate(Begins at: 109, Ends at:309)
CalledNBR: | 28 | ** | BABY-MONSTER | 28 |
LOC: | 201 | *** | MONSTER | 201 |
calculateD(Begins at: 317, Ends at:517)
Complexity: | 31 | *** | MONSTER | 31 |
calculateF(Begins at: 520, Ends at:716)
LOC: | 197 | *** | MONSTER | 197 |
main(Begins at: 30, Ends at:61)
shannon(Begins at: 64, Ends at:106)
LOC: | 43 | * | WARNING | 43 |
Clone analysis:
File :grass/trunk/raster/r.li/r.li.simpson/simpson.c
Function
calculate(Begins at: 108, Ends at:295)
CalledNBR: | 27 | ** | BABY-MONSTER | 27 |
LOC: | 188 | *** | MONSTER | 188 |
calculateD(Begins at: 298, Ends at:483)
LOC: | 186 | *** | MONSTER | 186 |
calculateF(Begins at: 487, Ends at:677)
LOC: | 191 | *** | MONSTER | 191 |
simpson(Begins at: 64, Ends at:104)
Clone analysis:
File :grass/trunk/vector/v.generalize/main.c
Function
main(Begins at: 42, Ends at:501)
Complexity: | 65 | *** | MONSTER | 65 |
CalledNBR: | 156 | *** | MONSTER | 156 |
LOC: | 460 | *** | MONSTER | 460 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Jun 30 15:45:33 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
