[GRASS-QA] GRASS QA: martinl |labels.c labels.c closecell.c main.c
...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Tue Jun 30 16:42:29 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/imagery/i.gensig/labels.c
Function
read_training_labels(Begins at: 5, Ends at:16)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 12 | | OK | 12 |
Conclusion: | this function is a OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/imagery/i.gensigset/labels.c
Function
metrics are OK
Clone analysis:
File :grass/trunk/lib/raster/closecell.c
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/raster/r.cross/main.c
Function
cmp(Begins at: 191, Ends at:203)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 13 | | OK | 13 |
metrics are OK
main(Begins at: 41, Ends at:189)
Complexity: | 16 | ** | BABY-MONSTER | 16 |
CalledNBR: | 66 | *** | MONSTER | 66 |
LOC: | 149 | *** | MONSTER | 149 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
File :grass/trunk/raster/r.in.poly/poly2rast.c
Function
poly_to_rast(Begins at: 8, Ends at:94)
Complexity: | 13 | ** | BABY-MONSTER | 13 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 28 | ** | BABY-MONSTER | 28 |
LOC: | 87 | * | WARNING | 87 |
Conclusion: | this function is a BABY-MONSTER |
Clone analysis:
File :grass/trunk/raster/r.reclass/main.c
Function
main(Begins at: 25, Ends at:146)
CalledNBR: | 53 | *** | MONSTER | 53 |
LOC: | 122 | ** | BABY-MONSTER | 122 |
Clone analysis:
File :grass/trunk/raster/r.stats/main.c
Function
main(Begins at: 42, Ends at:354)
Complexity: | 28 | *** | MONSTER | 28 |
CalledNBR: | 106 | *** | MONSTER | 106 |
LOC: | 313 | *** | MONSTER | 313 |
Clone analysis:
File :grass/trunk/raster/r.support/check.c
Function
check_stats(Begins at: 12, Ends at:77)
Complexity: | 10 | * | WARNING | 10 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 66 | * | WARNING | 66 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/trunk/raster/r.support/main.c
Function
main(Begins at: 33, Ends at:360)
Complexity: | 35 | *** | MONSTER | 35 |
CalledNBR: | 131 | *** | MONSTER | 131 |
LOC: | 328 | *** | MONSTER | 328 |
Clone analysis:
File :grass/trunk/raster/r.support.stats/check.c
Function
check_stats(Begins at: 29, Ends at:95)
CalledNBR: | 24 | ** | BABY-MONSTER | 24 |
LOC: | 67 | * | WARNING | 67 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Jun 30 16:30:17 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
