[GRASS-QA] GRASS QA: martinl |raster.h raster_metadata.c ps_fclrtbl.c main.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Jun 30 17:51:47 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/include/raster.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/lib/raster/raster_metadata.c
          File :grass/trunk/ps/ps.map/ps_fclrtbl.c
          Function
PS_fcolortable(Begins at: 17, Ends at:242)
              |          New Metrics           |Old Metrics|
Complexity:   |      25 |   *** |      MONSTER |        25 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      50 |   *** |      MONSTER |        50 |
LOC:          |     226 |   *** |      MONSTER |       226 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/raster/r.info/main.c
          Function
compose_line(Begins at: 420, Ends at:434)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      15 |       |           OK |        15 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
format_double(Begins at: 413, Ends at:417)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       5 |       |           OK |         5 |
Conclusion:   | this function is a            OK           |
metrics are OK
main(Begins at: 39, Ends at:410)
Complexity:   |      45 |   *** |      MONSTER |        45 |
CalledNBR:    |     132 |   *** |      MONSTER |       132 |
LOC:          |     372 |   *** |      MONSTER |       372 |
Clone analysis:
          File :grass/trunk/raster/r.los/main.c
          Function
main(Begins at: 63, Ends at:427)
Complexity:   |      40 |   *** |      MONSTER |        40 |
CalledNBR:    |     128 |   *** |      MONSTER |       128 |
LOC:          |     365 |   *** |      MONSTER |       365 |
Clone analysis:
          File :grass/trunk/raster/r.param.scale/close_down.c
          Function
close_down(Begins at: 14, Ends at:127)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
CalledNBR:    |      36 |    ** | BABY-MONSTER |        36 |
LOC:          |     114 |    ** | BABY-MONSTER |       114 |
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
          File :grass/trunk/raster/r.support/main.c
          Function
main(Begins at: 33, Ends at:360)
Complexity:   |      35 |   *** |      MONSTER |        35 |
CalledNBR:    |     131 |   *** |      MONSTER |       131 |
LOC:          |     328 |   *** |      MONSTER |       328 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Jun 30 17:39:33 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
