[GRASS-QA] GRASS QA: mmetz |plus_area.c | 6 clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Wed Mar 4 10:50:26 EST 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/vector/diglib/plus_area.c
Function
dig_add_area(Begins at: 161, Ends at:230)
| New Metrics |Old Metrics|
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 70 | * | WARNING | 70 |
Conclusion: | this function is a WARNING |
at least 4 values are close to an outlier please consider revising code!
dig_add_isle(Begins at: 610, Ends at:684)
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 75 | * | WARNING | 75 |
dig_angle_next_line(Begins at: 461, Ends at:538)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 78 | * | WARNING | 78 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
dig_area_add_isle(Begins at: 241, Ends at:267)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 27 | | OK | 27 |
at least 1 values are close to an outlier please consider revising code!
dig_area_del_isle(Begins at: 278, Ends at:309)
Complexity: | 6 | * | WARNING | 6 |
LOC: | 32 | | OK | 32 |
at least 2 values are close to an outlier please consider revising code!
dig_area_set_box(Begins at: 429, Ends at:443)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 15 | | OK | 15 |
dig_build_area_with_line(Begins at: 48, Ends at:145)
Complexity: | 15 | ** | BABY-MONSTER | 15 |
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 98 | ** | BABY-MONSTER | 98 |
dig_del_area(Begins at: 329, Ends at:418)
Complexity: | 10 | * | WARNING | 10 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 15 | * | WARNING | 15 |
LOC: | 90 | * | WARNING | 90 |
at least 3 values are close to an outlier please consider revising code!
dig_del_isle(Begins at: 722, Ends at:762)
CalledNBR: | 9 | | OK | 9 |
LOC: | 41 | | OK | 41 |
dig_isle_set_box(Begins at: 696, Ends at:710)
dig_node_angle_check(Begins at: 554, Ends at:593)
Complexity: | 4 | | OK | 4 |
LOC: | 40 | | OK | 40 |
Clone analysis:
This file has 6 potentially cloned functions:
dig_line_set_box dig_line_get_box dig_area_set_box dig_line_set_box dig_line_get_box
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_area.c clones of dig_area_set_box are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_area.c dig_isle_set_box
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_line.c dig_line_set_box
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_line.c dig_line_get_box
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_area.c clones of dig_isle_set_box are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_area.c dig_area_set_box
____________________________________________
Threshold grass key metrics values at Wed Mar 04 10:55:46 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
