[GRASS-QA] GRASS QA: hamish |main.c opencell.c misc.c | 6 clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Wed Mar 4 11:04:56 EST 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/imagery/i.cluster/main.c
Function
main(Begins at: 54, Ends at:357)
| New Metrics |Old Metrics|
Complexity: | 28 | *** | MONSTER | 28 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 171 | *** | MONSTER | 171 |
LOC: | 304 | *** | MONSTER | 304 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/gis/opencell.c
Function
G__check_fp_type(Begins at: 1035, Ends at:1087)
Complexity: | 9 | | OK | 9 |
CalledNBR: | 24 | | OK | 24 |
LOC: | 53 | | OK | 53 |
Conclusion: | this function is a OK |
metrics are OK
G__open_cell_old(Begins at: 147, Ends at:345)
Complexity: | 24 | | OK | 24 |
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 50 | * | WARNING | 50 |
LOC: | 199 | | OK | 199 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
G__open_raster_new(Begins at: 612, Ends at:787)
Complexity: | 20 | | OK | 20 |
CalledNBR: | 66 | | OK | 66 |
LOC: | 176 | | OK | 176 |
metrics are OK
G__reallocate_mask_buf(Begins at: 867, Ends at:881)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 15 | | OK | 15 |
metrics are OK
G__reallocate_null_buf(Begins at: 847, Ends at:860)
LOC: | 14 | | OK | 14 |
metrics are OK
G__reallocate_temp_buf(Begins at: 888, Ends at:902)
metrics are OK
G__reallocate_work_buf(Begins at: 824, Ends at:839)
CalledNBR: | 2 | | OK | 2 |
LOC: | 16 | | OK | 16 |
metrics are OK
G_cellvalue_format(Begins at: 500, Ends at:509)
Complexity: | 4 | | OK | 4 |
LOC: | 10 | | OK | 10 |
metrics are OK
G_get_raster_map_type(Begins at: 1020, Ends at:1025)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 6 | | OK | 6 |
metrics are OK
G_open_cell_new(Begins at: 399, Ends at:406)
LOC: | 8 | | OK | 8 |
metrics are OK
G_open_cell_new_random(Begins at: 420, Ends at:427)
metrics are OK
G_open_cell_new_uncompressed(Begins at: 439, Ends at:446)
metrics are OK
G_open_cell_old(Begins at: 98, Ends at:118)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 21 | | OK | 21 |
metrics are OK
G_open_fp_cell_new(Begins at: 528, Ends at:548)
metrics are OK
G_open_fp_cell_new_uncompressed(Begins at: 560, Ends at:578)
LOC: | 19 | | OK | 19 |
metrics are OK
G_open_raster_new(Begins at: 1109, Ends at:1116)
metrics are OK
G_open_raster_new_uncompressed(Begins at: 1129, Ends at:1136)
Complexity: | 2 | * | WARNING | 2 |
at least 1 values are close to an outlier please consider revising code!
G_raster_map_is_fp(Begins at: 951, Ends at:969)
CalledNBR: | 7 | | OK | 7 |
metrics are OK
G_raster_map_type(Begins at: 983, Ends at:1007)
Complexity: | 5 | *** | MONSTER | 5 |
CalledNBR: | 10 | *** | MONSTER | 10 |
LOC: | 25 | *** | MONSTER | 25 |
G_set_cell_format(Begins at: 479, Ends at:491)
Complexity: | 4 | ** | BABY-MONSTER | 4 |
CalledNBR: | 2 | *** | MONSTER | 2 |
LOC: | 13 | *** | MONSTER | 13 |
G_set_fp_type(Begins at: 919, Ends at:933)
metrics are OK
G_set_quant_rules(Begins at: 1153, Ends at:1179)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 27 | | OK | 27 |
metrics are OK
G_want_histogram(Begins at: 458, Ends at:463)
metrics are OK
allocate_compress_buf(Begins at: 798, Ends at:815)
LOC: | 18 | | OK | 18 |
metrics are OK
clean_check_raster_name(Begins at: 580, Ends at:609)
ParamNBR: | 3 | | OK | 3 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 30 | | OK | 30 |
metrics are OK
new_fileinfo(Begins at: 29, Ends at:51)
LOC: | 23 | | OK | 23 |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
G__reallocate_temp_buf G__reallocate_mask_buf G__reallocate_temp_buf G__reallocate_null_buf G__reallocate_mask_buf
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/opencell.c clones of G__reallocate_mask_buf are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/gis/opencell.c G__reallocate_null_buf
/var/project-manager/grass/grassSVN/grass/trunk/lib/gis/opencell.c G__reallocate_temp_buf
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/opencell.c clones of G__reallocate_null_buf are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/gis/opencell.c G__reallocate_mask_buf
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/opencell.c clones of G__reallocate_temp_buf are:
File :grass/trunk/raster/r.topmodel/misc.c
Function
basin_elevation(Begins at: 68, Ends at:81)
metrics are OK
depressionless(Begins at: 50, Ends at:65)
metrics are OK
gregion(Begins at: 23, Ends at:47)
Complexity: | 6 | * | WARNING | 6 |
LOC: | 25 | | OK | 25 |
run(Begins at: 4, Ends at:20)
LOC: | 17 | | OK | 17 |
metrics are OK
top_index(Begins at: 84, Ends at:109)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 26 | | OK | 26 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Mar 04 11:10:15 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
