[GRASS-QA] GRASS QA: cmbarton |main.c stash.h | 2 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Mar 13 02:30:05 EDT 2009
Hello cmbarton,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/raster/r.cost/main.c
          Function
main(Begins at: 73, Ends at:1048)
              |          New Metrics           |Old Metrics|
Complexity:   |     141 |   *** |      MONSTER |       141 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     293 |   *** |      MONSTER |       293 |
LOC:          |     976 |   *** |      MONSTER |       976 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
process_answers(Begins at: 1050, Ends at:1100)
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      51 |     * |      WARNING |        51 |
Conclusion:   | this function is a       WARNING           |
 at least 4 values are close to an outlier please consider revising code!
time_to_stop(Begins at: 1102, Ends at:1122)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      21 |       |           OK |        21 |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file has 2 potentially cloned functions:
  time_to_stop
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.cost/main.c clones of process_answers are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.walk/main.c  process_answers
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.cost/main.c clones of time_to_stop are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.walk/main.c  time_to_stop
          File :grass/branches/develbranch_6/raster/r.cost/stash.h
          Class
start_pt(Begins at: 33, Ends at:38)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
variables(Begins at: 42, Ends at:53)
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Fri Mar 13 01:37:16 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
