[GRASS-QA] GRASS QA: mmetz |Vect.h dig_defines.h dig_externs.h
dig_structs.h | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Mon Mar 16 05:51:41 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/Vect.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/include/vect/dig_defines.h
File :grass/trunk/include/vect/dig_externs.h
File :grass/trunk/include/vect/dig_structs.h
Class
Cat_index(Begins at: 223, Ends at:233)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 1 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 1 | 0 | 0 |
Class
Coor_info(Begins at: 161, Ends at:165)
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
Format_info(Begins at: 216, Ends at:220)
Class
Format_info_ogr(Begins at: 170, Ends at:214)
Class
Map_info(Begins at: 353, Ends at:418)
Class
P_area(Begins at: 454, Ends at:474)
Class
P_isle(Begins at: 476, Ends at:492)
Class
P_line(Begins at: 434, Ends at:452)
Class
P_node(Begins at: 420, Ends at:432)
Class
Plus_head(Begins at: 235, Ends at:351)
Class
Port_info(Begins at: 92, Ends at:113)
Class
bound_box(Begins at: 53, Ends at:61)
Class
cat_list(Begins at: 511, Ends at:518)
Class
dblinks(Begins at: 85, Ends at:89)
Class
dig_head(Begins at: 122, Ends at:158)
Class
field_info(Begins at: 75, Ends at:83)
Class
ilist(Begins at: 521, Ends at:526)
Class
line_cats(Begins at: 503, Ends at:509)
Class
line_pnts(Begins at: 494, Ends at:501)
Class
recycle(Begins at: 116, Ends at:120)
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Mon Mar 16 04:59:32 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
