[GRASS-QA] GRASS QA: martinl |main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Mar 19 13:15:40 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/vector/v.surf.idw/main.c
          Class
Point(Begins at: 30, Ends at:34)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
cell_list(Begins at: 71, Ends at:75)
          Class
list_Point(Begins at: 35, Ends at:40)
          Function
calculate_distances(Begins at: 444, Ends at:491)
              |          New Metrics           |Old Metrics|
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      48 |     * |      WARNING |        48 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
calculate_distances_noindex(Begins at: 493, Ends at:530)
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |      38 |       |           OK |        38 |
 at least 1 values are close to an outlier please consider revising code!
main(Begins at: 52, Ends at:406)
Complexity:   |      39 |   *** |      MONSTER |        39 |
CalledNBR:    |      80 |   *** |      MONSTER |        80 |
LOC:          |     355 |   *** |      MONSTER |       355 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
newpoint(Begins at: 408, Ends at:442)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      35 |       |           OK |        35 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Mar 19 12:24:14 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
