[GRASS-QA] GRASS QA: mmetz |map.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sat Mar 21 05:15:57 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/Vlib/map.c
          Function
Vect_copy(Begins at: 156, Ends at:285)
              |          New Metrics           |Old Metrics|
Complexity:   |      15 |     * |      WARNING |        15 |
ParamNBR:     |       4 |       |           OK |         4 |
CalledNBR:    |      60 |       |           OK |        60 |
LOC:          |     130 |       |           OK |       130 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Vect_copy_map_lines(Begins at: 44, Ends at:99)
Complexity:   |      10 |    ** | BABY-MONSTER |        10 |
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |      20 |   *** |      MONSTER |        20 |
LOC:          |      56 |    ** | BABY-MONSTER |        56 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Vect_copy_table(Begins at: 644, Ends at:650)
Complexity:   |       1 |     * |      WARNING |         1 |
ParamNBR:     |       6 |       |           OK |         6 |
CalledNBR:    |       1 |     * |      WARNING |         1 |
LOC:          |       7 |     * |      WARNING |         7 |
 at least 3 values are close to an outlier please consider revising code!
Vect_copy_table_by_cats(Begins at: 667, Ends at:720)
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      54 |       |           OK |        54 |
Conclusion:   | this function is a  BABY-MONSTER           |
Vect_copy_tables(Begins at: 567, Ends at:629)
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      22 |     * |      WARNING |        22 |
LOC:          |      63 |     * |      WARNING |        63 |
 at least 4 values are close to an outlier please consider revising code!
Vect_delete(Begins at: 430, Ends at:553)
Complexity:   |      16 |     * |      WARNING |        16 |
ParamNBR:     |       1 |    ** | BABY-MONSTER |         1 |
CalledNBR:    |      62 |     * |      WARNING |        62 |
LOC:          |     124 |     * |      WARNING |       124 |
Vect_rename(Begins at: 302, Ends at:420)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |      50 |   *** |      MONSTER |        50 |
LOC:          |     119 |    ** | BABY-MONSTER |       119 |
Vect_set_category_index_update(Begins at: 746, Ends at:749)
Complexity:   |       1 |    ** | BABY-MONSTER |         1 |
ParamNBR:     |       1 |     * |      WARNING |         1 |
CalledNBR:    |       0 |   *** |      MONSTER |         0 |
LOC:          |       4 |    ** | BABY-MONSTER |         4 |
Vect_set_release_support(Begins at: 731, Ends at:734)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a            OK           |
metrics are OK
copy_file(Begins at: 110, Ends at:141)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      32 |       |           OK |        32 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Sat Mar 21 04:24:52 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
