[GRASS-QA] GRASS QA: mmetz |poly.c rbtree.c break_polygons.c | no
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Tue Mar 24 05:43:48 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/vector/diglib/poly.c
Function
dig_find_area_poly(Begins at: 93, Ends at:116)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 24 | | OK | 24 |
Conclusion: | this function is a OK |
metrics are OK
dig_get_poly_points(Begins at: 34, Ends at:86)
Complexity: | 7 | * | WARNING | 7 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 53 | * | WARNING | 53 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/vector/diglib/rbtree.c
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/vector/Vlib/break_polygons.c
Function
Vect_break_polygons(Begins at: 62, Ends at:352)
Complexity: | 37 | | OK | 37 |
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 66 | | OK | 66 |
LOC: | 291 | | OK | 291 |
metrics are OK
srch(Begins at: 39, Ends at:42)
Complexity: | 1 | *** | MONSTER | 1 |
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 0 | *** | MONSTER | 0 |
LOC: | 4 | *** | MONSTER | 4 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Mar 24 04:53:23 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
