[GRASS-QA] GRASS QA: mmetz |main.c rmdac.c rmline.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Fri Mar 27 11:46:01 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/vector/v.clean/main.c
Function
main(Begins at: 25, Ends at:398)
| New Metrics |Old Metrics|
Complexity: | 62 | *** | MONSTER | 62 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 175 | *** | MONSTER | 175 |
LOC: | 374 | *** | MONSTER | 374 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/vector/v.clean/rmdac.c
Function
rmdac(Begins at: 22, Ends at:72)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 23 | ** | BABY-MONSTER | 23 |
LOC: | 51 | * | WARNING | 51 |
Conclusion: | this function is a BABY-MONSTER |
Clone analysis:
File :grass/trunk/vector/v.clean/rmline.c
Function
remove_zero_line(Begins at: 23, Ends at:65)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 43 | * | WARNING | 43 |
Conclusion: | this function is a WARNING |
at least 4 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Mar 27 10:51:57 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
