[GRASS-QA] GRASS QA: martinl |main.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Mon May 11 14:59:06 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.resamp.rst/main.c
Function
clean(Begins at: 578, Ends at:593)
| New Metrics |Old Metrics|
Complexity: | 13 | * | WARNING | 13 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 16 | | OK | 16 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
create_temp_file(Begins at: 542, Ends at:564)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 23 | | OK | 23 |
Conclusion: | this function is a OK |
metrics are OK
create_temp_files(Begins at: 566, Ends at:576)
Complexity: | 1 | *** | MONSTER | 1 |
CalledNBR: | 8 | *** | MONSTER | 8 |
LOC: | 11 | *** | MONSTER | 11 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
main(Begins at: 124, Ends at:540)
Complexity: | 44 | ** | BABY-MONSTER | 44 |
CalledNBR: | 167 | * | WARNING | 167 |
LOC: | 417 | | OK | 417 |
Conclusion: | this function is a BABY-MONSTER |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Mon May 11 15:14:03 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
