[GRASS-QA] GRASS QA: hamish |nviz_init.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Mon May 11 15:50:43 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/visualization/nviz/src/nviz_init.c
Function
Ngetargs(Begins at: 373, Ends at:421)
| New Metrics |Old Metrics|
Complexity: | 6 | | OK | 6 |
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 26 | | OK | 26 |
LOC: | 49 | | OK | 49 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Ninit(Begins at: 506, Ends at:538)
Complexity: | 1 | * | WARNING | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 8 | ** | BABY-MONSTER | 8 |
LOC: | 33 | * | WARNING | 33 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Ninitdata(Begins at: 542, Ends at:563)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 22 | | OK | 22 |
Conclusion: | this function is a OK |
metrics are OK
make_red_yellow_ramp(Begins at: 423, Ends at:434)
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 12 | | OK | 12 |
metrics are OK
parse_command(Begins at: 23, Ends at:363)
Complexity: | 37 | *** | MONSTER | 37 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 95 | *** | MONSTER | 95 |
LOC: | 341 | *** | MONSTER | 341 |
Conclusion: | this function is a MONSTER |
set_default_wirecolors(Begins at: 473, Ends at:504)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 32 | | OK | 32 |
metrics are OK
sort_surfs_mid(Begins at: 441, Ends at:471)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 31 | | OK | 31 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Mon May 11 16:05:40 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
