[GRASS-QA] GRASS QA: hamish |nviz_init.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon May 11 15:59:17 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/visualization/nviz/src/nviz_init.c
          Function
Ngetargs(Begins at: 372, Ends at:420)
              |          New Metrics           |Old Metrics|
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |      26 |       |           OK |        26 |
LOC:          |      49 |       |           OK |        49 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Ninit(Begins at: 505, Ends at:537)
Complexity:   |       1 |     * |      WARNING |         1 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       8 |    ** | BABY-MONSTER |         8 |
LOC:          |      33 |     * |      WARNING |        33 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Ninitdata(Begins at: 541, Ends at:562)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      22 |       |           OK |        22 |
Conclusion:   | this function is a            OK           |
metrics are OK
make_red_yellow_ramp(Begins at: 422, Ends at:433)
ParamNBR:     |       4 |       |           OK |         4 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      12 |       |           OK |        12 |
metrics are OK
parse_command(Begins at: 23, Ends at:362)
Complexity:   |      37 |   *** |      MONSTER |        37 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      95 |   *** |      MONSTER |        95 |
LOC:          |     340 |   *** |      MONSTER |       340 |
Conclusion:   | this function is a       MONSTER           |
set_default_wirecolors(Begins at: 472, Ends at:503)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      32 |       |           OK |        32 |
metrics are OK
sort_surfs_mid(Begins at: 440, Ends at:470)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      31 |       |           OK |        31 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Mon May 11 16:14:14 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
