[GRASS-QA] GRASS QA: marisn |map_obj.c nviz_init.c
site_attr_commands.c site_highlight_commands.c | 15 clones | 0 monsters
|0 warnings
soccerlab.info at gmail.com
Thu Nov 5 13:10:33 EST 2009
Hello marisn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/visualization/nviz/src/map_obj.c
Function
Nget_site_list_cmd(Begins at: 372, Ends at:390)
| New Metrics |Old Metrics|
Complexity: | 3 | * | WARNING | 3 |
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 19 | | OK | 19 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Nget_surf_list_cmd(Begins at: 322, Ends at:340)
ParamNBR: | 4 | * | WARNING | 4 |
at least 2 values are close to an outlier please consider revising code!
Nget_vect_list_cmd(Begins at: 347, Ends at:365)
Nget_vol_list_cmd(Begins at: 397, Ends at:415)
Complexity: | 3 | *** | MONSTER | 3 |
ParamNBR: | 4 | ** | BABY-MONSTER | 4 |
CalledNBR: | 4 | *** | MONSTER | 4 |
LOC: | 19 | *** | MONSTER | 19 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Nliteral_from_logical_cmd(Begins at: 86, Ends at:189)
Complexity: | 18 | ** | BABY-MONSTER | 18 |
CalledNBR: | 32 | * | WARNING | 32 |
LOC: | 104 | * | WARNING | 104 |
Conclusion: | this function is a BABY-MONSTER |
Nlogical_from_literal_cmd(Begins at: 196, Ends at:209)
Complexity: | 2 | * | WARNING | 2 |
CalledNBR: | 2 | * | WARNING | 2 |
LOC: | 14 | * | WARNING | 14 |
at least 4 values are close to an outlier please consider revising code!
Nmap_obj_cmd(Begins at: 708, Ends at:772)
Complexity: | 28 | | OK | 28 |
CalledNBR: | 56 | | OK | 56 |
LOC: | 65 | | OK | 65 |
Nnew_map_obj_cmd(Begins at: 432, Ends at:698)
Complexity: | 39 | | OK | 39 |
CalledNBR: | 80 | | OK | 80 |
LOC: | 267 | | OK | 267 |
Conclusion: | this function is a OK |
metrics are OK
att_atoi(Begins at: 2110, Ends at:2126)
Complexity: | 7 | * | WARNING | 7 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 6 | * | WARNING | 6 |
LOC: | 17 | | OK | 17 |
delete_obj(Begins at: 951, Ends at:975)
CalledNBR: | 5 | | OK | 5 |
LOC: | 25 | | OK | 25 |
draw_obj(Begins at: 920, Ends at:944)
Complexity: | 7 | | OK | 7 |
ParamNBR: | 3 | * | WARNING | 3 |
get_att(Begins at: 1552, Ends at:1699)
Complexity: | 30 | | OK | 30 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 41 | | OK | 41 |
LOC: | 148 | | OK | 148 |
get_char_marker(Begins at: 2158, Ends at:2202)
Complexity: | 13 | | OK | 13 |
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 45 | * | WARNING | 45 |
at least 3 values are close to an outlier please consider revising code!
get_drawmode(Begins at: 844, Ends at:912)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 16 | | OK | 16 |
LOC: | 69 | | OK | 69 |
get_exag_guess(Begins at: 1470, Ends at:1489)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 3 | | OK | 3 |
LOC: | 20 | | OK | 20 |
metrics are OK
get_idnum(Begins at: 2072, Ends at:2085)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 1 | * | WARNING | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 14 | | OK | 14 |
get_int_marker(Begins at: 2208, Ends at:2248)
Complexity: | 11 | ** | BABY-MONSTER | 11 |
CalledNBR: | 11 | ** | BABY-MONSTER | 11 |
LOC: | 41 | * | WARNING | 41 |
get_logical_name(Begins at: 276, Ends at:315)
Complexity: | 8 | * | WARNING | 8 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 40 | | OK | 40 |
get_mask_mode(Begins at: 2020, Ends at:2034)
Complexity: | 2 | | OK | 2 |
LOC: | 15 | | OK | 15 |
get_nozero(Begins at: 1285, Ends at:1319)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 6 | * | WARNING | 6 |
LOC: | 35 | | OK | 35 |
get_res(Begins at: 983, Ends at:1035)
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 53 | | OK | 53 |
get_trans(Begins at: 1162, Ends at:1200)
LOC: | 39 | | OK | 39 |
get_type(Begins at: 2092, Ends at:2104)
Complexity: | 5 | ** | BABY-MONSTER | 5 |
CalledNBR: | 4 | ** | BABY-MONSTER | 4 |
LOC: | 13 | ** | BABY-MONSTER | 13 |
get_wirecolor(Begins at: 1127, Ends at:1155)
CalledNBR: | 7 | | OK | 7 |
LOC: | 29 | | OK | 29 |
isosurf(Begins at: 2255, Ends at:2299)
Complexity: | 18 | *** | MONSTER | 18 |
CalledNBR: | 34 | *** | MONSTER | 34 |
load_obj(Begins at: 1498, Ends at:1534)
Complexity: | 9 | *** | MONSTER | 9 |
CalledNBR: | 7 | *** | MONSTER | 7 |
LOC: | 37 | *** | MONSTER | 37 |
select_surf(Begins at: 1328, Ends at:1355)
CalledNBR: | 6 | | OK | 6 |
LOC: | 28 | | OK | 28 |
set_att(Begins at: 1711, Ends at:1965)
Complexity: | 33 | *** | MONSTER | 33 |
CalledNBR: | 60 | *** | MONSTER | 60 |
LOC: | 255 | *** | MONSTER | 255 |
set_drawmode(Begins at: 780, Ends at:837)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 58 | * | WARNING | 58 |
set_exag_obj(Begins at: 1440, Ends at:1463)
LOC: | 24 | | OK | 24 |
set_logical_name(Begins at: 216, Ends at:269)
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 54 | * | WARNING | 54 |
set_mask_mode(Begins at: 2042, Ends at:2063)
LOC: | 22 | | OK | 22 |
set_nozero(Begins at: 1242, Ends at:1278)
LOC: | 37 | | OK | 37 |
set_res(Begins at: 1042, Ends at:1085)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 44 | * | WARNING | 44 |
set_trans(Begins at: 1207, Ends at:1235)
CalledNBR: | 8 | | OK | 8 |
set_wirecolor(Begins at: 1092, Ends at:1119)
slice(Begins at: 2306, Ends at:2345)
Complexity: | 15 | ** | BABY-MONSTER | 15 |
CalledNBR: | 28 | ** | BABY-MONSTER | 28 |
surf_is_selected(Begins at: 1400, Ends at:1432)
LOC: | 33 | | OK | 33 |
sv_att_atoi(Begins at: 2132, Ends at:2152)
Complexity: | 9 | * | WARNING | 9 |
LOC: | 21 | | OK | 21 |
unselect_surf(Begins at: 1364, Ends at:1392)
unset_att(Begins at: 1972, Ends at:2013)
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 42 | * | WARNING | 42 |
Clone analysis:
This file has 15 potentially cloned functions:
Nget_vect_list_cmd Nget_vol_list_cmd Nget_vect_list_cmd Nget_site_list_cmd Nget_vol_list_cmd Nget_surf_list_cmd Nget_site_list_cmd Nget_vol_list_cmd Nget_surf_list_cmd Nget_vect_list_cmd Nget_site_list_cmd isosurf_att_atoi unselect_surf select_surf
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c clones of Nget_site_list_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c Nget_surf_list_cmd
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c Nget_vect_list_cmd
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c Nget_vol_list_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c clones of Nget_surf_list_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c Nget_site_list_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c clones of Nget_vect_list_cmd are:
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c clones of Nget_vol_list_cmd are:
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c clones of att_atoi are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c isosurf_att_atoi
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c clones of select_surf are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c unselect_surf
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c clones of unselect_surf are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c select_surf
File :grass/trunk/visualization/nviz/src/nviz_init.c
Function
Ngetargs(Begins at: 372, Ends at:420)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 26 | | OK | 26 |
LOC: | 49 | | OK | 49 |
Ninit(Begins at: 505, Ends at:537)
Complexity: | 1 | * | WARNING | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 8 | ** | BABY-MONSTER | 8 |
LOC: | 33 | * | WARNING | 33 |
Ninitdata(Begins at: 541, Ends at:562)
metrics are OK
make_red_yellow_ramp(Begins at: 422, Ends at:433)
CalledNBR: | 1 | | OK | 1 |
LOC: | 12 | | OK | 12 |
metrics are OK
parse_command(Begins at: 23, Ends at:362)
Complexity: | 37 | *** | MONSTER | 37 |
CalledNBR: | 95 | *** | MONSTER | 95 |
LOC: | 340 | *** | MONSTER | 340 |
set_default_wirecolors(Begins at: 472, Ends at:503)
LOC: | 32 | | OK | 32 |
metrics are OK
sort_surfs_mid(Begins at: 440, Ends at:470)
CalledNBR: | 2 | | OK | 2 |
LOC: | 31 | | OK | 31 |
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/visualization/nviz/src/site_attr_commands.c
Function
Nget_interpolated_values_cmd(Begins at: 974, Ends at:1050)
Complexity: | 14 | | OK | 14 |
ParamNBR: | 4 | *** | MONSTER | 4 |
CalledNBR: | 30 | | OK | 30 |
LOC: | 77 | | OK | 77 |
Nsite_attr_get_field_not_emtpy_cats_cmd(Begins at: 438, Ends at:478)
LOC: | 41 | | OK | 41 |
Nsite_attr_get_field_values_cmd(Begins at: 386, Ends at:429)
Complexity: | 8 | | OK | 8 |
CalledNBR: | 10 | | OK | 10 |
LOC: | 44 | | OK | 44 |
Nsite_attr_get_fields_name_and_type_cmd(Begins at: 341, Ends at:371)
Nsite_attr_get_fields_name_cmd(Begins at: 269, Ends at:299)
metrics are OK
Nsite_attr_get_fields_type_cmd(Begins at: 306, Ends at:334)
metrics are OK
Nsite_attr_get_record_values_cmd(Begins at: 491, Ends at:537)
Complexity: | 9 | | OK | 9 |
LOC: | 47 | | OK | 47 |
Nsite_attr_get_value_cmd(Begins at: 553, Ends at:574)
CalledNBR: | 9 | * | WARNING | 9 |
attr_eval_color(Begins at: 1206, Ends at:1229)
ParamNBR: | 9 | * | WARNING | 9 |
attr_eval_color_string(Begins at: 1231, Ends at:1247)
attr_eval_entry(Begins at: 1175, Ends at:1188)
CalledNBR: | 0 | | OK | 0 |
attr_eval_entry_string(Begins at: 1190, Ends at:1204)
Complexity: | 4 | ** | BABY-MONSTER | 4 |
CalledNBR: | 3 | ** | BABY-MONSTER | 3 |
LOC: | 15 | * | WARNING | 15 |
attr_get_RRGGBB(Begins at: 927, Ends at:945)
Complexity: | 1 | | OK | 1 |
attr_get_char_RRGGBB(Begins at: 948, Ends at:959)
attr_get_int_BBGGRR(Begins at: 914, Ends at:924)
LOC: | 11 | | OK | 11 |
attr_interp_colors(Begins at: 1115, Ends at:1155)
ParamNBR: | 10 | * | WARNING | 10 |
CalledNBR: | 17 | | OK | 17 |
attr_interp_colors_string(Begins at: 1157, Ends at:1171)
attr_interp_entries(Begins at: 1078, Ends at:1104)
LOC: | 27 | * | WARNING | 27 |
attr_interp_entries_string(Begins at: 1106, Ends at:1113)
LOC: | 8 | | OK | 8 |
site_attr_close_map(Begins at: 606, Ends at:612)
LOC: | 7 | | OK | 7 |
site_attr_get(Begins at: 726, Ends at:734)
LOC: | 9 | | OK | 9 |
site_attr_init(Begins at: 626, Ends at:634)
metrics are OK
site_attr_init_tcl(Begins at: 189, Ends at:220)
metrics are OK
site_attr_open_map(Begins at: 586, Ends at:603)
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
LOC: | 18 | | OK | 18 |
site_attr_set(Begins at: 637, Ends at:708)
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 72 | * | WARNING | 72 |
site_attr_set_color(Begins at: 738, Ends at:807)
Complexity: | 11 | | OK | 11 |
CalledNBR: | 19 | | OK | 19 |
LOC: | 70 | | OK | 70 |
site_attr_set_fixed_color(Begins at: 869, Ends at:877)
site_attr_set_fixed_marker(Begins at: 889, Ends at:897)
site_attr_set_fixed_size(Begins at: 879, Ends at:887)
site_attr_set_size(Begins at: 809, Ends at:867)
CalledNBR: | 13 | | OK | 13 |
LOC: | 59 | | OK | 59 |
site_attr_unset(Begins at: 710, Ends at:724)
Complexity: | 4 | * | WARNING | 4 |
CalledNBR: | 3 | * | WARNING | 3 |
Clone analysis:
File :grass/trunk/visualization/nviz/src/site_highlight_commands.c
Function
Nsite_highlight_cmd(Begins at: 327, Ends at:381)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
LOC: | 55 | * | WARNING | 55 |
Nsite_highlight_get_default_cmd(Begins at: 664, Ends at:687)
Nsite_highlight_get_default_value_cmd(Begins at: 612, Ends at:635)
Nsite_highlight_list_cmd(Begins at: 384, Ends at:464)
Complexity: | 21 | *** | MONSTER | 21 |
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 81 | * | WARNING | 81 |
Nsite_highlight_set_default_cmd(Begins at: 641, Ends at:662)
Nsite_highlight_set_default_value_cmd(Begins at: 588, Ends at:610)
LOC: | 23 | | OK | 23 |
Nsite_unhighlight_all_cmd(Begins at: 547, Ends at:582)
LOC: | 36 | | OK | 36 |
Nsite_unhighlight_cmd(Begins at: 466, Ends at:495)
LOC: | 30 | | OK | 30 |
Nsite_unhighlight_list_cmd(Begins at: 497, Ends at:544)
Complexity: | 13 | ** | BABY-MONSTER | 13 |
LOC: | 48 | | OK | 48 |
site_highlight_get_geopoint(Begins at: 260, Ends at:269)
LOC: | 10 | | OK | 10 |
metrics are OK
site_highlight_get_geosite(Begins at: 242, Ends at:257)
LOC: | 16 | | OK | 16 |
metrics are OK
site_highlight_get_int_BBGGRR(Begins at: 172, Ends at:182)
metrics are OK
site_highlight_init_tcl(Begins at: 211, Ends at:238)
metrics are OK
site_highlight_loop(Begins at: 272, Ends at:322)
LOC: | 51 | * | WARNING | 51 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Nov 05 13:10:33 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
