[GRASS-QA] GRASS QA: martinl |N_les.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Thu Nov 5 13:55:05 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/gpde/N_les.c
Function
N_add_spvector_to_les(Begins at: 263, Ends at:287)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 25 | | OK | 25 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
N_alloc_les(Begins at: 120, Ends at:123)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
LOC: | 4 | | OK | 4 |
Conclusion: | this function is a OK |
metrics are OK
N_alloc_les_A(Begins at: 150, Ends at:153)
metrics are OK
N_alloc_les_Ax(Begins at: 135, Ends at:138)
metrics are OK
N_alloc_les_Ax_b(Begins at: 165, Ends at:168)
metrics are OK
N_alloc_les_param(Begins at: 198, Ends at:249)
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 52 | * | WARNING | 52 |
at least 4 values are close to an outlier please consider revising code!
N_alloc_nquad_les(Begins at: 55, Ends at:58)
N_alloc_nquad_les_A(Begins at: 87, Ends at:90)
N_alloc_nquad_les_Ax(Begins at: 71, Ends at:74)
N_alloc_nquad_les_Ax_b(Begins at: 103, Ends at:106)
N_alloc_spvector(Begins at: 29, Ends at:42)
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 14 | | OK | 14 |
metrics are OK
N_free_les(Begins at: 387, Ends at:428)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 42 | * | WARNING | 42 |
at least 2 values are close to an outlier please consider revising code!
N_free_spvector(Begins at: 363, Ends at:376)
CalledNBR: | 3 | | OK | 3 |
metrics are OK
N_print_les(Begins at: 312, Ends at:354)
Complexity: | 13 | ** | BABY-MONSTER | 13 |
LOC: | 43 | * | WARNING | 43 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Nov 05 13:55:05 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
