[GRASS-QA] GRASS QA: hamish |main.c com_line.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Thu Nov 5 14:39:13 EST 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.watershed/front/main.c
Function
main(Begins at: 25, Ends at:438)
| New Metrics |Old Metrics|
Complexity: | 32 | *** | MONSTER | 32 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 147 | *** | MONSTER | 147 |
LOC: | 414 | *** | MONSTER | 414 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
write_hist(Begins at: 441, Ends at:458)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 18 | | OK | 18 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/raster/r.watershed/shed/com_line.c
Function
basin_com_add(Begins at: 432, Ends at:445)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 14 | | OK | 14 |
com_add(Begins at: 447, Ends at:456)
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 10 | | OK | 10 |
com_line_Gwater(Begins at: 8, Ends at:416)
Complexity: | 76 | | OK | 76 |
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 258 | | OK | 258 |
LOC: | 409 | | OK | 409 |
com_line_add(Begins at: 418, Ends at:430)
Complexity: | 2 | *** | MONSTER | 2 |
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 6 | *** | MONSTER | 6 |
LOC: | 13 | *** | MONSTER | 13 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Nov 05 14:39:13 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
