[GRASS-QA] GRASS QA: martinl |open_ogr.c read_ogr.c write.c
write_ogr.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Nov 5 15:24:02 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/vector/Vlib/open_ogr.c
Function
V1_open_old_ogr(Begins at: 45, Ends at:104)
| New Metrics |Old Metrics|
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 17 | * | WARNING | 17 |
LOC: | 60 | * | WARNING | 60 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
V2_open_old_ogr(Begins at: 114, Ends at:190)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 22 | * | WARNING | 22 |
LOC: | 77 | * | WARNING | 77 |
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/vector/Vlib/read_ogr.c
Function
V1_read_next_line_ogr(Begins at: 142, Ends at:228)
Complexity: | 15 | ** | BABY-MONSTER | 15 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 19 | ** | BABY-MONSTER | 19 |
LOC: | 87 | * | WARNING | 87 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
V2_read_line_ogr(Begins at: 324, Ends at:402)
Complexity: | 12 | ** | BABY-MONSTER | 12 |
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 79 | * | WARNING | 79 |
V2_read_next_line_ogr(Begins at: 241, Ends at:249)
Complexity: | 2 | * | WARNING | 2 |
CalledNBR: | 1 | * | WARNING | 1 |
LOC: | 9 | * | WARNING | 9 |
at least 4 values are close to an outlier please consider revising code!
cache_feature(Begins at: 39, Ends at:124)
Complexity: | 16 | | OK | 16 |
CalledNBR: | 26 | | OK | 26 |
LOC: | 86 | | OK | 86 |
at least 1 values are close to an outlier please consider revising code!
read_line(Begins at: 262, Ends at:310)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 49 | * | WARNING | 49 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/write.c
Function
Vect_delete_line(Begins at: 205, Ends at:236)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 32 | | OK | 32 |
Conclusion: | this function is a OK |
metrics are OK
Vect_rewrite_line(Begins at: 145, Ends at:171)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 5 | | OK | 5 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 27 | | OK | 27 |
metrics are OK
Vect_write_line(Begins at: 99, Ends at:125)
ParamNBR: | 4 | | OK | 4 |
metrics are OK
delete_dummy(Begins at: 36, Ends at:41)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 6 | | OK | 6 |
metrics are OK
format(Begins at: 44, Ends at:48)
ParamNBR: | 0 | * | WARNING | 0 |
LOC: | 5 | | OK | 5 |
rewrite_dummy(Begins at: 30, Ends at:35)
write_dummy(Begins at: 24, Ends at:29)
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/Vlib/write_ogr.c
The system don't find class, method and function
in this file during analysis!
____________________________________________
Threshold grass key metrics values at Thu Nov 05 15:24:02 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
