[GRASS-QA] GRASS QA: martinl |select.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Thu Nov 5 16:59:36 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/db/dbmi_client/select.c
Function
cmp(Begins at: 6, Ends at:16)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 11 | | OK | 11 |
Conclusion: | this function is a OK |
metrics are OK
cmpcat(Begins at: 18, Ends at:28)
metrics are OK
cmpcatkey(Begins at: 30, Ends at:40)
metrics are OK
cmpvaluedouble(Begins at: 55, Ends at:66)
LOC: | 12 | | OK | 12 |
metrics are OK
cmpvalueint(Begins at: 42, Ends at:53)
metrics are OK
cmpvaluestring(Begins at: 68, Ends at:74)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 7 | | OK | 7 |
metrics are OK
db_CatValArray_get_value(Begins at: 395, Ends at:409)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 15 | | OK | 15 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
db_CatValArray_get_value_double(Begins at: 443, Ends at:459)
CalledNBR: | 3 | | OK | 3 |
LOC: | 17 | | OK | 17 |
db_CatValArray_get_value_int(Begins at: 419, Ends at:433)
db_CatValArray_sort(Begins at: 350, Ends at:353)
ParamNBR: | 1 | | OK | 1 |
LOC: | 4 | | OK | 4 |
metrics are OK
db_CatValArray_sort_by_value(Begins at: 361, Ends at:385)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 25 | | OK | 25 |
db_select_CatValArray(Begins at: 227, Ends at:343)
Complexity: | 17 | ** | BABY-MONSTER | 17 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 44 | *** | MONSTER | 44 |
LOC: | 117 | ** | BABY-MONSTER | 117 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
db_select_int(Begins at: 87, Ends at:164)
Complexity: | 12 | * | WARNING | 12 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 26 | ** | BABY-MONSTER | 26 |
LOC: | 78 | * | WARNING | 78 |
Conclusion: | this function is a BABY-MONSTER |
db_select_value(Begins at: 177, Ends at:215)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 39 | | OK | 39 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Nov 05 16:59:36 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
