[GRASS-QA] GRASS QA: martinl |field.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Thu Nov 5 19:04:44 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/vector/Vlib/field.c
Function
Vect_add_dblink(Begins at: 209, Ends at:261)
| New Metrics |Old Metrics|
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 53 | * | WARNING | 53 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Vect_check_dblink(Begins at: 181, Ends at:193)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 13 | | OK | 13 |
Conclusion: | this function is a OK |
metrics are OK
Vect_default_field_info(Begins at: 273, Ends at:347)
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 27 | ** | BABY-MONSTER | 27 |
LOC: | 75 | * | WARNING | 75 |
Vect_get_dblink(Begins at: 360, Ends at:386)
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 27 | | OK | 27 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Vect_get_field(Begins at: 400, Ends at:415)
CalledNBR: | 2 | | OK | 2 |
LOC: | 16 | | OK | 16 |
metrics are OK
Vect_map_add_dblink(Begins at: 81, Ends at:110)
Complexity: | 5 | | OK | 5 |
LOC: | 30 | | OK | 30 |
Vect_map_check_dblink(Begins at: 167, Ends at:170)
Complexity: | 1 | | OK | 1 |
LOC: | 4 | | OK | 4 |
metrics are OK
Vect_map_del_dblink(Begins at: 121, Ends at:156)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 36 | | OK | 36 |
Vect_new_dblinks_struct(Begins at: 41, Ends at:53)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
metrics are OK
Vect_read_dblinks(Begins at: 427, Ends at:657)
Complexity: | 20 | ** | BABY-MONSTER | 20 |
CalledNBR: | 78 | *** | MONSTER | 78 |
LOC: | 231 | *** | MONSTER | 231 |
Conclusion: | this function is a MONSTER |
Vect_reset_dblinks(Begins at: 62, Ends at:65)
CalledNBR: | 0 | | OK | 0 |
metrics are OK
Vect_set_db_updated(Begins at: 771, Ends at:778)
CalledNBR: | 5 | | OK | 5 |
LOC: | 8 | | OK | 8 |
metrics are OK
Vect_subst_var(Begins at: 718, Ends at:758)
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 41 | | OK | 41 |
Vect_write_dblinks(Begins at: 667, Ends at:708)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 42 | * | WARNING | 42 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Nov 05 19:04:45 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
