[GRASS-QA] GRASS QA: martinl |build.c close.c field.c open.c ...|
no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Nov 5 20:03:04 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/vector/Vlib/build.c
Function
Vect_build(Begins at: 73, Ends at:76)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 4 | | OK | 4 |
Conclusion: | this function is a OK |
metrics are OK
Vect_build_partial(Begins at: 128, Ends at:248)
Complexity: | 20 | | OK | 20 |
ParamNBR: | 3 | | OK | 3 |
CalledNBR: | 46 | | OK | 46 |
LOC: | 121 | | OK | 121 |
metrics are OK
Vect_get_built(Begins at: 86, Ends at:89)
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
metrics are OK
Vect_save_spatial_index(Begins at: 408, Ends at:440)
Complexity: | 3 | ** | BABY-MONSTER | 3 |
ParamNBR: | 1 | * | WARNING | 1 |
CalledNBR: | 14 | *** | MONSTER | 14 |
LOC: | 33 | ** | BABY-MONSTER | 33 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Vect_save_topo(Begins at: 257, Ends at:289)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 14 | | OK | 14 |
LOC: | 33 | | OK | 33 |
metrics are OK
Vect_spatial_index_dump(Begins at: 451, Ends at:462)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 3 | * | WARNING | 3 |
LOC: | 12 | | OK | 12 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Vect_topo_dump(Begins at: 300, Ends at:398)
Complexity: | 13 | | OK | 13 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 99 | | OK | 99 |
format(Begins at: 29, Ends at:33)
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 5 | | OK | 5 |
metrics are OK
prnmsg(Begins at: 48, Ends at:62)
Complexity: | 2 | ** | BABY-MONSTER | 2 |
CalledNBR: | 5 | * | WARNING | 5 |
LOC: | 15 | ** | BABY-MONSTER | 15 |
Conclusion: | this function is a BABY-MONSTER |
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/vector/Vlib/close.c
Function
Vect_close(Begins at: 64, Ends at:148)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 33 | ** | BABY-MONSTER | 33 |
LOC: | 85 | * | WARNING | 85 |
clo_dummy(Begins at: 30, Ends at:33)
metrics are OK
format(Begins at: 36, Ends at:40)
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/Vlib/field.c
Function
Vect_add_dblink(Begins at: 209, Ends at:261)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 53 | * | WARNING | 53 |
Vect_check_dblink(Begins at: 181, Ends at:193)
LOC: | 13 | | OK | 13 |
metrics are OK
Vect_default_field_info(Begins at: 273, Ends at:347)
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 27 | ** | BABY-MONSTER | 27 |
LOC: | 75 | * | WARNING | 75 |
Vect_get_dblink(Begins at: 360, Ends at:386)
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 27 | | OK | 27 |
Vect_get_field(Begins at: 400, Ends at:415)
LOC: | 16 | | OK | 16 |
metrics are OK
Vect_map_add_dblink(Begins at: 81, Ends at:110)
Complexity: | 5 | | OK | 5 |
LOC: | 30 | | OK | 30 |
Vect_map_check_dblink(Begins at: 167, Ends at:170)
metrics are OK
Vect_map_del_dblink(Begins at: 121, Ends at:156)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 36 | | OK | 36 |
Vect_new_dblinks_struct(Begins at: 41, Ends at:53)
metrics are OK
Vect_read_dblinks(Begins at: 427, Ends at:657)
Complexity: | 20 | ** | BABY-MONSTER | 20 |
CalledNBR: | 78 | *** | MONSTER | 78 |
LOC: | 231 | *** | MONSTER | 231 |
Vect_reset_dblinks(Begins at: 62, Ends at:65)
metrics are OK
Vect_set_db_updated(Begins at: 771, Ends at:778)
CalledNBR: | 5 | | OK | 5 |
LOC: | 8 | | OK | 8 |
metrics are OK
Vect_subst_var(Begins at: 718, Ends at:758)
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 41 | | OK | 41 |
Vect_write_dblinks(Begins at: 667, Ends at:708)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 42 | * | WARNING | 42 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/trunk/lib/vector/Vlib/open.c
Function
Vect__open_old(Begins at: 124, Ends at:396)
Complexity: | 31 | | OK | 31 |
ParamNBR: | 5 | | OK | 5 |
CalledNBR: | 102 | | OK | 102 |
LOC: | 273 | | OK | 273 |
metrics are OK
Vect_coor_info(Begins at: 608, Ends at:646)
Complexity: | 6 | *** | MONSTER | 6 |
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 11 | *** | MONSTER | 11 |
LOC: | 39 | *** | MONSTER | 39 |
Vect_maptype_info(Begins at: 656, Ends at:673)
Complexity: | 5 | * | WARNING | 5 |
CalledNBR: | 4 | * | WARNING | 4 |
LOC: | 18 | | OK | 18 |
Vect_open_new(Begins at: 514, Ends at:597)
Complexity: | 8 | | OK | 8 |
CalledNBR: | 43 | | OK | 43 |
LOC: | 84 | | OK | 84 |
metrics are OK
Vect_open_old(Begins at: 410, Ends at:413)
Complexity: | 1 | * | WARNING | 1 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 1 | *** | MONSTER | 1 |
LOC: | 4 | * | WARNING | 4 |
Vect_open_old_head(Begins at: 464, Ends at:468)
Vect_open_spatial_index(Begins at: 767, Ends at:832)
CalledNBR: | 8 | | OK | 8 |
LOC: | 66 | | OK | 66 |
Vect_open_topo(Begins at: 686, Ends at:757)
Complexity: | 7 | | OK | 7 |
CalledNBR: | 16 | | OK | 16 |
LOC: | 72 | * | WARNING | 72 |
Vect_open_update(Begins at: 427, Ends at:449)
Complexity: | 2 | * | WARNING | 2 |
CalledNBR: | 2 | * | WARNING | 2 |
LOC: | 23 | * | WARNING | 23 |
at least 3 values are close to an outlier please consider revising code!
Vect_open_update_head(Begins at: 482, Ends at:502)
LOC: | 21 | | OK | 21 |
Vect_set_open_level(Begins at: 96, Ends at:107)
fatal_error(Begins at: 59, Ends at:71)
metrics are OK
format(Begins at: 38, Ends at:42)
metrics are OK
open_old_dummy(Begins at: 32, Ends at:35)
metrics are OK
Clone analysis:
File :grass/trunk/lib/vector/Vlib/read.c
Function
Vect_area_alive(Begins at: 155, Ends at:161)
LOC: | 7 | | OK | 7 |
metrics are OK
Vect_isle_alive(Begins at: 172, Ends at:178)
metrics are OK
Vect_line_alive(Begins at: 121, Ends at:127)
metrics are OK
Vect_node_alive(Begins at: 138, Ends at:144)
metrics are OK
Vect_read_line(Begins at: 95, Ends at:110)
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 6 | | OK | 6 |
metrics are OK
Vect_read_next_line(Begins at: 70, Ends at:82)
metrics are OK
format(Begins at: 30, Ends at:34)
ParamNBR: | 0 | * | WARNING | 0 |
read_next_dummy(Begins at: 24, Ends at:27)
Clone analysis:
File :grass/trunk/lib/vector/Vlib/rewind.c
Function
Vect_rewind(Begins at: 62, Ends at:70)
LOC: | 9 | | OK | 9 |
metrics are OK
format(Begins at: 33, Ends at:37)
metrics are OK
rew_dummy(Begins at: 26, Ends at:29)
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Nov 05 20:03:03 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
