[GRASS-QA] GRASS QA: neteler |labels.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Sep 2 17:24:02 EDT 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/vector/v.label.sa/labels.c
          Function
box_overlap(Begins at: 1239, Ends at:1254)
              |          New Metrics           |Old Metrics|
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      16 |       |           OK |        16 |
Conclusion:   | this function is a            OK           |
metrics are OK
box_overlap2(Begins at: 1263, Ends at:1285)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      23 |       |           OK |        23 |
metrics are OK
box_trans_rot(Begins at: 814, Ends at:844)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      31 |       |           OK |        31 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
candidate_compare(Begins at: 771, Ends at:784)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      14 |       |           OK |        14 |
metrics are OK
label_avedist(Begins at: 852, Ends at:885)
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      34 |       |           OK |        34 |
metrics are OK
label_candidate_overlap(Begins at: 1146, Ends at:1231)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      86 |     * |      WARNING |        86 |
 at least 3 values are close to an outlier please consider revising code!
label_candidates(Begins at: 336, Ends at:364)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      29 |       |           OK |        29 |
 at least 1 values are close to an outlier please consider revising code!
label_flatness(Begins at: 893, Ends at:984)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      29 |    ** | BABY-MONSTER |        29 |
LOC:          |      92 |    ** | BABY-MONSTER |        92 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
label_line_candidates(Begins at: 489, Ends at:762)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      77 |   *** |      MONSTER |        77 |
LOC:          |     274 |   *** |      MONSTER |       274 |
Conclusion:   | this function is a       MONSTER           |
label_lineover(Begins at: 1020, Ends at:1099)
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      80 |     * |      WARNING |        80 |
 at least 4 values are close to an outlier please consider revising code!
label_point_candidates(Begins at: 370, Ends at:483)
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |     114 |    ** | BABY-MONSTER |       114 |
label_pointover(Begins at: 993, Ends at:1012)
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      20 |       |           OK |        20 |
metrics are OK
label_skyline(Begins at: 234, Ends at:329)
CalledNBR:    |      28 |    ** | BABY-MONSTER |        28 |
LOC:          |      96 |    ** | BABY-MONSTER |        96 |
labels_init(Begins at: 42, Ends at:226)
Complexity:   |      23 |   *** |      MONSTER |        23 |
CalledNBR:    |      96 |   *** |      MONSTER |        96 |
LOC:          |     185 |   *** |      MONSTER |       185 |
min_dist_2_lines(Begins at: 1108, Ends at:1139)
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      32 |       |           OK |        32 |
skyline_trans_rot(Begins at: 786, Ends at:803)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      18 |       |           OK |        18 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Sep 02 17:24:02 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
