[GRASS-QA] GRASS QA: benducke |dig_structs.h | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 4 10:14:53 EDT 2009
Hello benducke,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/include/vect/dig_structs.h
          Class
Cat_index(Begins at: 223, Ends at:233)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      1 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      1 |      0 |      0 |
          Class
Coor_info(Begins at: 161, Ends at:165)
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
Format_info(Begins at: 216, Ends at:220)
          Class
Format_info_ogr(Begins at: 170, Ends at:214)
          Class
Map_info(Begins at: 353, Ends at:418)
          Class
P_area(Begins at: 454, Ends at:474)
          Class
P_isle(Begins at: 476, Ends at:492)
          Class
P_line(Begins at: 434, Ends at:452)
          Class
P_node(Begins at: 420, Ends at:432)
          Class
Plus_head(Begins at: 235, Ends at:351)
          Class
Port_info(Begins at: 92, Ends at:113)
          Class
bound_box(Begins at: 53, Ends at:61)
          Class
cat_list(Begins at: 511, Ends at:518)
          Class
dblinks(Begins at: 85, Ends at:89)
          Class
dig_head(Begins at: 122, Ends at:158)
          Class
field_info(Begins at: 75, Ends at:83)
          Class
ilist(Begins at: 521, Ends at:526)
          Class
line_cats(Begins at: 503, Ends at:509)
          Class
line_pnts(Begins at: 494, Ends at:501)
          Class
recycle(Begins at: 116, Ends at:120)
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Fri Sep 04 10:14:53 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
