[GRASS-QA] GRASS QA: benducke |level_two.c | no clones | 0 monsters
	|0 warnings
    soccerlab.info at gmail.com
    Fri Sep  4 10:37:34 EDT 2009
Hello benducke,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/lib/vector/Vlib/level_two.c
          Function
Vect_get_centroid_area(Begins at: 312, Ends at:319)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       8 |       |           OK |         8 |
Conclusion:   | this function is a            OK           |
metrics are OK
Vect_get_line_areas(Begins at: 231, Ends at:245)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      15 |       |           OK |        15 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Vect_get_line_nodes(Begins at: 206, Ends at:220)
Vect_get_node_coor(Begins at: 181, Ends at:195)
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       0 |       |           OK |         0 |
Vect_get_node_line(Begins at: 275, Ends at:282)
ParamNBR:     |       3 |     * |      WARNING |         3 |
Vect_get_node_line_angle(Begins at: 293, Ends at:300)
Vect_get_node_n_lines(Begins at: 255, Ends at:264)
LOC:          |      10 |       |           OK |        10 |
metrics are OK
Vect_get_num_areas(Begins at: 81, Ends at:84)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
Vect_get_num_dblinks(Begins at: 117, Ends at:120)
metrics are OK
Vect_get_num_faces(Begins at: 93, Ends at:96)
metrics are OK
Vect_get_num_islands(Begins at: 105, Ends at:108)
metrics are OK
Vect_get_num_lines(Begins at: 69, Ends at:72)
metrics are OK
Vect_get_num_nodes(Begins at: 29, Ends at:32)
metrics are OK
Vect_get_num_primitives(Begins at: 42, Ends at:60)
Complexity:   |       7 |     * |      WARNING |         7 |
LOC:          |      19 |       |           OK |        19 |
Vect_get_num_updated_lines(Begins at: 129, Ends at:132)
metrics are OK
Vect_get_num_updated_nodes(Begins at: 154, Ends at:157)
metrics are OK
Vect_get_updated_line(Begins at: 142, Ends at:145)
metrics are OK
Vect_get_updated_node(Begins at: 167, Ends at:170)
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Fri Sep 04 10:37:34 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
