[GRASS-QA] GRASS QA: neteler |stats.h c_ave.c c_count.c c_divr.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 4 18:12:22 EDT 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/include/stats.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/branches/develbranch_6/lib/stats/c_ave.c
          Function
c_ave(Begins at: 3, Ends at:24)
              |          New Metrics           |Old Metrics|
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      22 |       |           OK |        22 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/lib/stats/c_count.c
          Function
c_count(Begins at: 3, Ends at:15)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      13 |       |           OK |        13 |
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_divr.c
          Function
c_divr(Begins at: 4, Ends at:29)
LOC:          |      26 |       |           OK |        26 |
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_intr.c
          Function
c_intr(Begins at: 4, Ends at:35)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      32 |       |           OK |        32 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_kurt.c
          Function
c_kurt(Begins at: 3, Ends at:43)
LOC:          |      41 |       |           OK |        41 |
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_max.c
          Function
c_max(Begins at: 3, Ends at:22)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      20 |       |           OK |        20 |
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_maxx.c
          Function
c_maxx(Begins at: 3, Ends at:25)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      23 |       |           OK |        23 |
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_median.c
          Function
c_median(Begins at: 4, Ends at:12)
Complexity:   |       2 |       |           OK |         2 |
LOC:          |       9 |       |           OK |         9 |
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_min.c
          Function
c_min(Begins at: 3, Ends at:22)
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_minx.c
          Function
c_minx(Begins at: 4, Ends at:26)
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_mode.c
          Function
c_mode(Begins at: 4, Ends at:35)
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_percentile.c
          Function
c_perc90(Begins at: 36, Ends at:39)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
c_quart1(Begins at: 26, Ends at:29)
c_quart3(Begins at: 31, Ends at:34)
percentile(Begins at: 5, Ends at:24)
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       4 |       |           OK |         4 |
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_range.c
          Function
c_range(Begins at: 3, Ends at:26)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      24 |       |           OK |        24 |
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_reg.c
          Function
c_reg_c(Begins at: 81, Ends at:84)
c_reg_m(Begins at: 76, Ends at:79)
c_reg_r2(Begins at: 86, Ends at:89)
regression(Begins at: 7, Ends at:74)
Complexity:   |      17 |    ** | BABY-MONSTER |        17 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      68 |     * |      WARNING |        68 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_skew.c
          Function
c_skew(Begins at: 4, Ends at:44)
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_stddev.c
          Function
c_stddev(Begins at: 5, Ends at:15)
LOC:          |      11 |       |           OK |        11 |
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_sum.c
          Function
c_sum(Begins at: 3, Ends at:24)
Clone analysis:
          File :grass/branches/develbranch_6/lib/stats/c_var.c
          Function
c_var(Begins at: 3, Ends at:40)
LOC:          |      38 |       |           OK |        38 |
Clone analysis:
          File :grass/branches/develbranch_6/raster/r.series/main.c
          Class
input(Begins at: 55, Ends at:60)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
menu(Begins at: 24, Ends at:53)
          Function
build_method_list(Begins at: 62, Ends at:79)
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |      18 |       |           OK |        18 |
Conclusion:   | this function is a            OK           |
metrics are OK
main(Begins at: 81, Ends at:243)
Complexity:   |      19 |    ** | BABY-MONSTER |        19 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      56 |   *** |      MONSTER |        56 |
LOC:          |     163 |   *** |      MONSTER |       163 |
Conclusion:   | this function is a       MONSTER           |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Sep 04 18:12:22 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
