[GRASS-QA] GRASS QA: martinl |main.c main.c | no clones | 0
	monsters |0 warnings
    soccerlab.info at gmail.com
    Sat Sep  5 06:43:11 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/raster/r.neighbors/main.c
          Class
menu(Begins at: 32, Ends at:41)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
main(Begins at: 64, Ends at:333)
              |          New Metrics           |Old Metrics|
Complexity:   |      33 |   *** |      MONSTER |        33 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      99 |   *** |      MONSTER |        99 |
LOC:          |     270 |   *** |      MONSTER |       270 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/raster/r.resamp.stats/main.c
          Function
build_method_list(Begins at: 44, Ends at:61)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      18 |       |           OK |        18 |
Conclusion:   | this function is a            OK           |
metrics are OK
find_method(Begins at: 63, Ends at:72)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
main(Begins at: 238, Ends at:383)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      69 |   *** |      MONSTER |        69 |
LOC:          |     146 |   *** |      MONSTER |       146 |
resamp_unweighted(Begins at: 82, Ends at:150)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      69 |     * |      WARNING |        69 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
resamp_weighted(Begins at: 152, Ends at:236)
CalledNBR:    |      23 |    ** | BABY-MONSTER |        23 |
LOC:          |      85 |     * |      WARNING |        85 |
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Sep 05 06:43:11 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
