[GRASS-QA] GRASS QA: martinl |vector.h level_two.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Sat Sep 5 13:29:12 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/vector.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/vector/Vlib/level_two.c
Function
Vect_get_centroid_area(Begins at: 312, Ends at:319)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 8 | | OK | 8 |
Conclusion: | this function is a OK |
metrics are OK
Vect_get_line_areas(Begins at: 231, Ends at:245)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 15 | | OK | 15 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Vect_get_line_nodes(Begins at: 206, Ends at:220)
Vect_get_node_coor(Begins at: 181, Ends at:195)
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 0 | | OK | 0 |
Vect_get_node_line(Begins at: 275, Ends at:282)
ParamNBR: | 3 | * | WARNING | 3 |
Vect_get_node_line_angle(Begins at: 293, Ends at:300)
Vect_get_node_n_lines(Begins at: 255, Ends at:264)
LOC: | 10 | | OK | 10 |
metrics are OK
Vect_get_num_areas(Begins at: 81, Ends at:84)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
LOC: | 4 | | OK | 4 |
metrics are OK
Vect_get_num_dblinks(Begins at: 117, Ends at:120)
metrics are OK
Vect_get_num_faces(Begins at: 93, Ends at:96)
metrics are OK
Vect_get_num_islands(Begins at: 105, Ends at:108)
metrics are OK
Vect_get_num_lines(Begins at: 69, Ends at:72)
metrics are OK
Vect_get_num_nodes(Begins at: 29, Ends at:32)
metrics are OK
Vect_get_num_primitives(Begins at: 42, Ends at:60)
Complexity: | 7 | * | WARNING | 7 |
LOC: | 19 | | OK | 19 |
Vect_get_num_updated_lines(Begins at: 129, Ends at:132)
metrics are OK
Vect_get_num_updated_nodes(Begins at: 154, Ends at:157)
metrics are OK
Vect_get_updated_line(Begins at: 142, Ends at:145)
metrics are OK
Vect_get_updated_node(Begins at: 167, Ends at:170)
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Sat Sep 05 13:29:12 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
