[GRASS-QA] GRASS QA: glynn |tools.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Thu Sep 10 12:06:54 EDT 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/gem/tools.c
Function
basename(Begins at: 33, Ends at:66)
| New Metrics |Old Metrics|
Complexity: | 7 | * | WARNING | 7 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 34 | | OK | 34 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
binaries_exist(Begins at: 690, Ends at:720)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 31 | | OK | 31 |
at least 2 values are close to an outlier please consider revising code!
check_filetype(Begins at: 737, Ends at:760)
CalledNBR: | 6 | | OK | 6 |
LOC: | 24 | | OK | 24 |
chop(Begins at: 86, Ends at:113)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 28 | | OK | 28 |
Conclusion: | this function is a OK |
metrics are OK
delete_str(Begins at: 190, Ends at:221)
Complexity: | 5 | | OK | 5 |
LOC: | 32 | | OK | 32 |
metrics are OK
dump_ascii(Begins at: 539, Ends at:556)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 18 | | OK | 18 |
metrics are OK
dump_html(Begins at: 597, Ends at:634)
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 38 | | OK | 38 |
dump_plain(Begins at: 563, Ends at:590)
CalledNBR: | 11 | * | WARNING | 11 |
dump_str(Begins at: 258, Ends at:267)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 10 | | OK | 10 |
metrics are OK
find_pos(Begins at: 230, Ends at:251)
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 22 | | OK | 22 |
get_package_name(Begins at: 273, Ends at:298)
CalledNBR: | 9 | | OK | 9 |
LOC: | 26 | | OK | 26 |
metrics are OK
insert_str(Begins at: 125, Ends at:180)
CalledNBR: | 23 | ** | BABY-MONSTER | 23 |
LOC: | 56 | * | WARNING | 56 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
is_text(Begins at: 474, Ends at:493)
LOC: | 20 | | OK | 20 |
metrics are OK
list_binaries(Begins at: 642, Ends at:683)
CalledNBR: | 15 | * | WARNING | 15 |
LOC: | 42 | * | WARNING | 42 |
at least 3 values are close to an outlier please consider revising code!
mkdir_s(Begins at: 73, Ends at:80)
Complexity: | 1 | | OK | 1 |
LOC: | 8 | | OK | 8 |
metrics are OK
nc_fgets(Begins at: 307, Ends at:333)
LOC: | 27 | | OK | 27 |
nc_fgets_html(Begins at: 339, Ends at:467)
Complexity: | 22 | *** | MONSTER | 22 |
CalledNBR: | 22 | * | WARNING | 22 |
LOC: | 129 | ** | BABY-MONSTER | 129 |
Conclusion: | this function is a MONSTER |
nc_fgets_nb(Begins at: 500, Ends at:532)
LOC: | 33 | | OK | 33 |
su(Begins at: 796, Ends at:823)
metrics are OK
vercmp(Begins at: 832, Ends at:858)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 0 | | OK | 0 |
wget_extension(Begins at: 766, Ends at:789)
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Sep 10 12:06:54 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
