[GRASS-QA] GRASS QA: neteler |tools.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Sep 10 12:29:23 EDT 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/gem/tools.c
          Function
basename(Begins at: 33, Ends at:66)
              |          New Metrics           |Old Metrics|
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      34 |       |           OK |        34 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
binaries_exist(Begins at: 690, Ends at:720)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      31 |       |           OK |        31 |
 at least 2 values are close to an outlier please consider revising code!
check_filetype(Begins at: 737, Ends at:760)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      24 |       |           OK |        24 |
chop(Begins at: 86, Ends at:113)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      28 |       |           OK |        28 |
Conclusion:   | this function is a            OK           |
metrics are OK
delete_str(Begins at: 190, Ends at:221)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      32 |       |           OK |        32 |
metrics are OK
dump_ascii(Begins at: 539, Ends at:556)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      18 |       |           OK |        18 |
metrics are OK
dump_html(Begins at: 597, Ends at:634)
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      38 |       |           OK |        38 |
dump_plain(Begins at: 563, Ends at:590)
CalledNBR:    |      11 |     * |      WARNING |        11 |
dump_str(Begins at: 258, Ends at:267)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
find_pos(Begins at: 230, Ends at:251)
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      22 |       |           OK |        22 |
get_package_name(Begins at: 273, Ends at:298)
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      26 |       |           OK |        26 |
metrics are OK
insert_str(Begins at: 125, Ends at:180)
CalledNBR:    |      23 |    ** | BABY-MONSTER |        23 |
LOC:          |      56 |     * |      WARNING |        56 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
is_text(Begins at: 474, Ends at:493)
LOC:          |      20 |       |           OK |        20 |
metrics are OK
list_binaries(Begins at: 642, Ends at:683)
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      42 |     * |      WARNING |        42 |
 at least 3 values are close to an outlier please consider revising code!
mkdir_s(Begins at: 73, Ends at:80)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
nc_fgets(Begins at: 307, Ends at:333)
LOC:          |      27 |       |           OK |        27 |
nc_fgets_html(Begins at: 339, Ends at:467)
Complexity:   |      22 |   *** |      MONSTER |        22 |
CalledNBR:    |      22 |     * |      WARNING |        22 |
LOC:          |     129 |    ** | BABY-MONSTER |       129 |
Conclusion:   | this function is a       MONSTER           |
nc_fgets_nb(Begins at: 500, Ends at:532)
LOC:          |      33 |       |           OK |        33 |
su(Begins at: 796, Ends at:823)
metrics are OK
vercmp(Begins at: 832, Ends at:858)
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |       0 |       |           OK |         0 |
wget_extension(Begins at: 766, Ends at:789)
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Sep 10 12:29:23 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
