[GRASS-QA] GRASS QA: wolf |labels.c labels.h | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Thu Sep 10 13:29:02 EDT 2009
Hello wolf,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/vector/v.label.sa/labels.c
Function
box_overlap(Begins at: 1239, Ends at:1254)
| New Metrics |Old Metrics|
Complexity: | 5 | | OK | 5 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 16 | | OK | 16 |
Conclusion: | this function is a OK |
metrics are OK
box_overlap2(Begins at: 1263, Ends at:1285)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 23 | | OK | 23 |
metrics are OK
box_trans_rot(Begins at: 814, Ends at:844)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 31 | | OK | 31 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
candidate_compare(Begins at: 771, Ends at:784)
Complexity: | 3 | | OK | 3 |
LOC: | 14 | | OK | 14 |
metrics are OK
label_avedist(Begins at: 852, Ends at:885)
CalledNBR: | 5 | | OK | 5 |
LOC: | 34 | | OK | 34 |
metrics are OK
label_candidate_overlap(Begins at: 1146, Ends at:1231)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 15 | * | WARNING | 15 |
LOC: | 86 | * | WARNING | 86 |
at least 3 values are close to an outlier please consider revising code!
label_candidates(Begins at: 336, Ends at:364)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 29 | | OK | 29 |
at least 1 values are close to an outlier please consider revising code!
label_flatness(Begins at: 893, Ends at:984)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 29 | ** | BABY-MONSTER | 29 |
LOC: | 92 | ** | BABY-MONSTER | 92 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
label_line_candidates(Begins at: 489, Ends at:762)
Complexity: | 18 | ** | BABY-MONSTER | 18 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 77 | *** | MONSTER | 77 |
LOC: | 274 | *** | MONSTER | 274 |
Conclusion: | this function is a MONSTER |
label_lineover(Begins at: 1020, Ends at:1099)
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 80 | * | WARNING | 80 |
at least 4 values are close to an outlier please consider revising code!
label_point_candidates(Begins at: 370, Ends at:483)
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 114 | ** | BABY-MONSTER | 114 |
label_pointover(Begins at: 993, Ends at:1012)
CalledNBR: | 4 | | OK | 4 |
LOC: | 20 | | OK | 20 |
metrics are OK
label_skyline(Begins at: 234, Ends at:329)
CalledNBR: | 28 | ** | BABY-MONSTER | 28 |
LOC: | 96 | ** | BABY-MONSTER | 96 |
labels_init(Begins at: 42, Ends at:226)
Complexity: | 23 | *** | MONSTER | 23 |
CalledNBR: | 96 | *** | MONSTER | 96 |
LOC: | 185 | *** | MONSTER | 185 |
min_dist_2_lines(Begins at: 1108, Ends at:1139)
CalledNBR: | 2 | | OK | 2 |
LOC: | 32 | | OK | 32 |
skyline_trans_rot(Begins at: 786, Ends at:803)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 18 | | OK | 18 |
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/vector/v.label.sa/labels.h
Class
_label(Begins at: 44, Ends at:69)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
_label_candidate(Begins at: 74, Ends at:93)
Class
_label_intersection(Begins at: 98, Ends at:104)
Class
_label_point(Begins at: 34, Ends at:40)
Class
params(Begins at: 109, Ends at:130)
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Sep 10 13:29:02 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
