[GRASS-QA] GRASS QA: glynn |main.c put_grid.c pv.h | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 11 23:49:13 EDT 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.out.vrml/main.c
          Function
do_coordcnv(Begins at: 218, Ends at:242)
              |          New Metrics           |Old Metrics|
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      25 |       |           OK |        25 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
init_coordcnv(Begins at: 193, Ends at:216)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      24 |       |           OK |        24 |
main(Begins at: 28, Ends at:168)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
CalledNBR:    |      49 |   *** |      MONSTER |        49 |
LOC:          |     141 |   *** |      MONSTER |       141 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/raster/r.out.vrml/put_grid.c
          Function
vrml_put_grid(Begins at: 10, Ends at:160)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      59 |   *** |      MONSTER |        59 |
LOC:          |     151 |   *** |      MONSTER |       151 |
Clone analysis:
          File :grass/trunk/raster/r.out.vrml/pv.h
The system don't find class, method and function
 in this file during analysis!
____________________________________________
Threshold grass key metrics values at Fri Sep 11 23:49:14 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
