[GRASS-QA] GRASS QA: glynn |main.c map.c areas_io.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Sat Sep 12 00:03:30 EDT 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/display/d.legend/main.c
Function
main(Begins at: 38, Ends at:885)
| New Metrics |Old Metrics|
Complexity: | 130 | *** | MONSTER | 130 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 211 | *** | MONSTER | 211 |
LOC: | 848 | *** | MONSTER | 848 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/raster/r.mapcalc/map.c
Class
map(Begins at: 49, Ends at:65)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
row_cache(Begins at: 42, Ends at:47)
Class
sub_cache(Begins at: 35, Ends at:40)
Function
cache_get(Begins at: 189, Ends at:193)
Complexity: | 1 | * | WARNING | 1 |
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 5 | | OK | 5 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
cache_get_raw(Begins at: 130, Ends at:187)
Complexity: | 6 | | OK | 6 |
ParamNBR: | 3 | | OK | 3 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 58 | | OK | 58 |
Conclusion: | this function is a OK |
metrics are OK
cache_release(Begins at: 109, Ends at:128)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 20 | | OK | 20 |
metrics are OK
cache_setup(Begins at: 100, Ends at:107)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 8 | | OK | 8 |
metrics are OK
cache_sub_init(Begins at: 86, Ends at:98)
Complexity: | 2 | | OK | 2 |
LOC: | 13 | | OK | 13 |
metrics are OK
check_output_map(Begins at: 651, Ends at:654)
CalledNBR: | 2 | | OK | 2 |
LOC: | 4 | | OK | 4 |
metrics are OK
close_map(Begins at: 426, Ends at:454)
CalledNBR: | 8 | | OK | 8 |
LOC: | 29 | | OK | 29 |
metrics are OK
close_maps(Begins at: 635, Ends at:647)
Complexity: | 2 | * | WARNING | 2 |
close_output_map(Begins at: 673, Ends at:677)
ParamNBR: | 1 | ** | BABY-MONSTER | 1 |
CalledNBR: | 3 | * | WARNING | 3 |
Conclusion: | this function is a BABY-MONSTER |
compare_ints(Begins at: 197, Ends at:200)
metrics are OK
copy_cats(Begins at: 686, Ends at:696)
CalledNBR: | 3 | | OK | 3 |
LOC: | 11 | | OK | 11 |
metrics are OK
copy_colors(Begins at: 698, Ends at:708)
copy_history(Begins at: 710, Ends at:719)
LOC: | 10 | | OK | 10 |
metrics are OK
create_history(Begins at: 721, Ends at:761)
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 41 | | OK | 41 |
get_map_row(Begins at: 593, Ends at:633)
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 7 | * | WARNING | 7 |
CalledNBR: | 15 | | OK | 15 |
at least 2 values are close to an outlier please consider revising code!
init_cats(Begins at: 211, Ends at:222)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 1 | * | WARNING | 1 |
LOC: | 12 | | OK | 12 |
init_colors(Begins at: 202, Ends at:209)
metrics are OK
map_type(Begins at: 458, Ends at:484)
Complexity: | 11 | | OK | 11 |
LOC: | 27 | | OK | 27 |
metrics are OK
open_map(Begins at: 486, Ends at:579)
Complexity: | 27 | | OK | 27 |
CalledNBR: | 19 | | OK | 19 |
LOC: | 94 | | OK | 94 |
metrics are OK
open_output_map(Begins at: 656, Ends at:665)
metrics are OK
put_map_row(Begins at: 667, Ends at:671)
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 5 | * | WARNING | 5 |
at least 4 values are close to an outlier please consider revising code!
read_map(Begins at: 387, Ends at:424)
Complexity: | 12 | | OK | 12 |
ParamNBR: | 5 | | OK | 5 |
LOC: | 38 | | OK | 38 |
metrics are OK
read_row(Begins at: 365, Ends at:369)
ParamNBR: | 4 | * | WARNING | 4 |
setup_map(Begins at: 371, Ends at:385)
CalledNBR: | 2 | * | WARNING | 2 |
LOC: | 15 | * | WARNING | 15 |
setup_maps(Begins at: 581, Ends at:591)
metrics are OK
setup_region(Begins at: 24, Ends at:31)
translate_from_cats(Begins at: 300, Ends at:363)
Complexity: | 8 | | OK | 8 |
CalledNBR: | 13 | | OK | 13 |
LOC: | 64 | | OK | 64 |
metrics are OK
translate_from_colors(Begins at: 224, Ends at:275)
Complexity: | 17 | | OK | 17 |
LOC: | 52 | | OK | 52 |
metrics are OK
unopen_output_map(Begins at: 679, Ends at:682)
Complexity: | 1 | *** | MONSTER | 1 |
CalledNBR: | 1 | * | WARNING | 1 |
LOC: | 4 | ** | BABY-MONSTER | 4 |
Clone analysis:
File :grass/trunk/raster/r.to.vect/areas_io.c
Function
write_area(Begins at: 259, Ends at:378)
Complexity: | 20 | ** | BABY-MONSTER | 20 |
CalledNBR: | 33 | ** | BABY-MONSTER | 33 |
LOC: | 120 | ** | BABY-MONSTER | 120 |
write_bnd(Begins at: 82, Ends at:148)
Complexity: | 15 | ** | BABY-MONSTER | 15 |
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 67 | * | WARNING | 67 |
write_boundary(Begins at: 35, Ends at:77)
Complexity: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 7 | * | WARNING | 7 |
LOC: | 43 | ** | BABY-MONSTER | 43 |
write_smooth_bnd(Begins at: 155, Ends at:256)
Complexity: | 17 | * | WARNING | 17 |
CalledNBR: | 16 | | OK | 16 |
LOC: | 102 | * | WARNING | 102 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Sep 12 00:03:30 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
